Question about Samsung PCL5415RB 54" Rear Projection Television
The red and blue dont line up,double image gone,but colr is off
  • 6,784 Answers
This will happen if the convergence board is malfunctioning. you will need to replace this failing board if possible.
Posted on Jun 19, 2009
I have a Panasonic HDTV and suddenly the colours went double!
hi, if you know little fixing tip's? here's my tip's sound's like converging ic's,gone bad. on the left board there's two a touched to a big heat sink.but before you start'.there's three wire connected to the board written. red .blue.and green.check for burn film resistor's on line red. replaced it with the same.good luck.
Feb 02, 2010 | Panasonic Televison & Video
Red green blue signals are not lined up. There
Convergence problem. Replace the convergence ICs and check the low ohm feed resistors as well.
Jan 03, 2010 | Televison & Video
Double images red blue green lines
My picture screen has double images red,blue,green. The screen looks 3D
Dec 28, 2009 | Sony KP-53HS30 53" Rear Projection...
Image worse after replacing convergence chips
Sounds to me like you have your red (pR) and blue (pB) connections on your component video cables crossed.
I havent seen the previous post so I could be way off.
Nov 24, 2009 | JVC AV-48WP30 48" Rear Projection...
Color seems off possible bowing of the image at top and bottom
that's right my friend, you have a convergence problem, you need to replace the stk's and it is possible that you have some burned resistors. if can't do it yourself  you are looking $250.00 repair
good luck
Jun 07, 2009 | Samsung PCL5415RB 54" Rear Projection...
Cant get the redd green an blue projectors to line up correctly
you need to have the set reconverged,,,call a repairman to come out and reset the colors
Mar 01, 2009 | RCA HD52W56 52" Rear Projection HDTV
Color is mostly yellow and blue with double images
you have lost the convergence IC`s in your set, this really isn`t a diy repair unless you are very proficient in un-soldering and re-soldering components, once replaced there will be an alignment procedure as well that will require the service manual also, if you have more questions feel free to ask away, video-tek
Feb 04, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Replaced Convergence but pictures still display with double images
i went to converge my mitsubishi ws 73903 and the blue line wont go down to match the other ones
Oct 09, 2008 | Mitsubishi WS-73903 65" Rear Projection...
Color convergence red and blue will not line up/ double images
Repair involves some dis-assembly...replace convergence IC's
and inspect current limiting resistors for over-heat damage...
part # STK392-110 sub to upgrade STK394-160 Hitachi part # CZ 01341....you will need two....good solder technique required.
....................................................................................T.
Feb 08, 2008 | Hitachi 43UWX10B 43" Rear Projection...
Samsung HCM5525W TV red blue outlines on images
The Samsung has bad convergence IC's most likly. This should be repair ONLY by a trained technician as a TV set is not a place to experiment or tinker with because of the extremly high voltage inside. This repair should cost you in the range of 250 to 400 bucks . Good Luck
Jul 31, 2006 | Samsung HCM5525W 55" Rear Projection...
Samsung PCL5415RB 54" Rear Projection Television Logo
91 people viewed this question
Henry  Thomas
Henry Thomas
