Question about Sylvania 9" Dual Screen Portable DVD Player, SDVD9002
How to replace the laser in a sylvania portable dvd player sdvd9002
Won't read the disc I get a message that says no disc
SOURCE: Sylvania DVR90VE DVD Recorder / VCR - formatting DVD-RW
This unit only supports 2X -RW discs or 4X -R discs.
Posted on Oct 28, 2007
  • 135 Answers
SOURCE: Sylvania DVR90VF will not play home burned DVD-R disc
Search for DVD43 on the net. It's a free download. It works 99.99% of the time.
Posted on Jun 26, 2008
SOURCE: unable to "dub" my 8mm tapes onto DVD-R using my Sylvania DV90VE
From comments posted on the Internet by other Sylvania users with a similar problem, I  learned that I had to use a 4X DVD-R (the ones I had been trying to record on were 16X). And I found that Office Depot sells the sometimes hard-to-find 4X format, so that's where I'm headed right after lunch.  Thanks.
Posted on Dec 15, 2008
  • 272 Answers
SOURCE: Cannot read DVD+R discs generated with Nero 8.0
The DVD-R format was developed by Pioneer in 1997[1]. It is supported by most DVD players, and is approved by the DVD Forum. DVD+R is a later version and not supported by a lot of machines. Swith to -R, should work, I use Nero 9 upgraded from * and have absolutely no problem as long as I use DVD-R discs, lots of problems with DVD+R though. Good Luck!
Posted on May 10, 2009
freetek
  • 5568 Answers
SOURCE: I'm having an odd problem with my Sylvania
> Do I need to update the firmware?
If you are lucky; Sylvania is a branch of Funai which is the 'bottom of the barrel' on quality so it may be just another case of Funai-ism.
Other brands belonging to Funai:
Symphonic, Emerson, Aventura, Durabrand, ESA, Magnavox, INSIGNIA, Philips and Misakai
I earned part of my income from servicing consumer electronics some years ago and historically, Funai gear has been among the worst built.
Posted on Dec 28, 2009
I have a Sylvania 32 inch DVD not reading the DVDs what's wrong???
How To Fix a Portable DVD Player That Is Not Reading or ...
? 17:12
https://www.youtube.com/watch?v=ucNedtR256g
Jan 18, 2015 - Uploaded by orly lando argallon
How To Fix a Portable DVD Player That Is Not Reading or Loading Discs. ... 2:32. How To Clean A DVD ...Missing: inch
Amazon.com: Sylvania SDVD9805/SDVD9805-C 9-Inch ...
www.amazon.com/Sylvania-SDVD9805-SDVD9805...
Amazon.com, Inc.
Rating: 2.9 - ‎916 reviews
Sylvania SDVD9805/SDVD9805-C 9-Inch Twin Dual Screen DVD Player. Sorry .... 5.0 out of 5 stars32+ hour car trip ... One remote does not work on both, only works for the one it came with. .... Garbage, 3 months in the first of the two DVD players stoppedreading the DVD's so we only used the one and now 5 months in the ...
Sylvania SDVD9805/SDVD9805-C 9-Inch Twin Dual Screen ...
Amazon.com, Inc.Find helpful customer reviews and review ratings for Sylvania SDVD9805/SDVD9805-C 9-Inch Twin Dual Screen DVD Player at Amazon.com. Read honest and ...
Jan 20, 2016 | Sylvania Televison & Video
Sylvania SDVD7027 7-Inch Portable DVD Player won't read DVD
The DVD player maybe faulty and it could be still under warranty.
Take it back to the shop where you bought it to have it repaired ot replaced under warranty.
Oct 22, 2012 | Curtis Sylvania Sdvd7027 7-Inch Portable...
No disc
Get a Q-Tip and rubbing alcohol, gently clean the laser lens and allow several minutes to dry. If there is no change the whole laser pickup assembly will need to be replaced, not cost effective to repair, cheaper to replace the player.
Jun 16, 2012 | Sylvania SDVD7015 7 in Portable DVD Player
Bush portable DVD player will not load my disc
Hello
Just put in an audio CD disc or an MP3 disc, and see whether it reads them or not. If the player can read these discs, and only refuses to read DVD discs, make sure that the laser pickup unit of it is faulty, and should be replaced with same type and number. If none of them reads, there are two possibilities, the first one is of laser pickup disc itself and the second one is the strip wire [a flat flexible cable connected between laser pickup unit and the mainboard of the player] is faulty. First replace the strip wire. If it helps you, it's OK. If not replace the laser pickup unit also. The strip wire can be bought from most of the electronic spare part shops at your town. When buying laser pickup unit, its number must be noted, and exact replacement should be done. Otherwise, it won't match with the main board. OK.
Nov 08, 2011 | Televison & Video
My sylvania portable DVD player won't read discs the display says No Disc after the spin. What do I do?
I had same problem with a sylvania portable DVD: no disc. After cleaning the laser didn't work, I took the unit apart, and found that there is a small gear that moves the laser back and forth across the disc.. The gear could easily be misaligned with a rough bump along the drive.. All I did was realign the gear to the center where the disc was. Inside, there was even a small lever to pull back on to do this.. I also noticed a small Ribbon cable connecting the laser to the main board. Again, seemed nimble. I detached the ribbon, cleaned the connectors with alcohol and reattached. Happy to say, it works perfectly now. :). Good luck.
Oct 10, 2011 | Sylvania SDVD7027BL Portable DVD Player
Unknow Disk - Please check disk again ERROR MESSAGE. Have tried previous burn disks the work no problems in the DVD player..... BUT disks I have burn as of today keep coming up with the above error...
The problem is you need to replace the laser assembly if the disc is spinning and not being read, or if the disc isnt spinning, you need to replace the mpeg printed circuit board attached to the laser assembly. Good Luck.
Jul 18, 2009 | GPX PDL805 Portable DVD Player
I get the message "bad disc" with every disc I put in the player.
ok best bet is that your laser (what reads the discs) in your laptop is dirty, use a cd/dvd cleaning disc to clean the laser, can buy them from most computing, music shops
Jun 29, 2009 | Polaroid Portable DVD Player PDM-0822BD
Sylvania 9" Dual Screen Portable DVD Player, SDVD9002 Logo
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
