Question about Sharp PG-D3050W DLP Projector
Vertical image roll on projector
Projector connected to PC through dual video card, only projectors rolls - not always
5 Suggested Answers
  • 3 Answers
SOURCE: Sharp XR10X Screen size
depending on the age of your computer, some of the older video cards in XP only will allow you to show video in 600x800 resolution. When you want to show video go ahead and change both of your display properties (both the primary and the secondary) to 600x800. See if that works.
If that is not what you are refering to go right click on your desktop and look for the properties or settings of your graphics card. it may say graphics properties . In that area there will be tons of options like (when showing video only show it on the secondary monitor) play around with the different settings on your graphics card.
Good luck
Posted on Sep 04, 2008
projdoc
  • 2237 Answers
SOURCE: connecting my xbox 360 to a sharp projector
video plug to yellow video in jack, audio to red and white.
Posted on Jul 29, 2009
projdoc
  • 2237 Answers
SOURCE: Image not being displayed through projector
make sure the resolution matches. the projector uses 640x480.
Posted on Aug 04, 2009
  • 231 Answers
SOURCE: When I send the PC out to the projection, it does
are both projectos same models? if not try changing resolution on display
Posted on Apr 13, 2010
Como desarmar un mini split carrier
You tried three notebooks, but did they have the same video adapters? Try a notebook with a different video adapter. i would say your video adapter isn't good enough to put out a dual display. you might need to get a laptop with a better video card
Jan 23, 2014 | NEC Office Equipment & Supplies
Please help! I have an optoma projector EP780 which has vertical lines mainly white and black. However when displaying an image their are also some colours. What do I need to do?
If you are connected to a PC make sure the monitor resolution matches that of the projectors native resolution like 800x600 or 1024x768. Also check it using a different video source like DVD or cable using an s-video or yellow rca cable. It may be the VGA ot DVI connector has some bad pin connections in it.
Apr 12, 2011 | Office Equipment & Supplies
When I connect the projector to my PC after the COMPAQ image goes away, it displays "Check Video Cable". What does that mean?
you may need to turn on dual monitor on your computer. sometimes just restarting the PC while connected will do it as well.
Mar 13, 2011 | Compaq MP1600 Multimedia Projector
When the projector warms up the picture starts to roll intermitently.
It is possible that your projector has the syncronisation fault in the video processor section. There is a possiblity that the chip is faulty or the corresponding allied cirrcuits have sprung up with some passive component weakness. What you can do is to open the set and warm up the areas near the main chip . Switch on the projector and if you notice the roll had stopped try do it to specific components and finally to the main IC .Replace when you are confirmed but attempt only if you are experienced or seek help to replace. Hope this helps. Good day
Aug 10, 2010 | Sony VPL CS1 Multimedia Projector
May 27, 2009 | SharpVision XV-S96U Multimedia Projector
Laptop computer connected to projector.
When the projector displays the background image and the lcd displays the desktop as normal you can drag the open windows to the left or right and display them on the projector. it sounds like this laptop has an internal video card. If you right click on the desktop it might give you options to configure the display settings for the video card. Not sure how you will get to it if it does not show up on the right click menu. Probably through the start menu or in the control panel there should be somewhere to change the settings for the video card. This will no be under the display settings though.
But once you find your dual display options you will be able to change it to make both displays the same
Jan 21, 2009 | Dell Latitude D600 Notebook
Thin vertical line appears on projector
I have found that vertical lines that suddenly appear from projectors are due to poorly connected cables. Sut off your projector and wait for the fan to go off. Then unplug the connectors from the computer to the projector and secure them again, making sure to go all the way. Hope this helps.
Nov 25, 2008 | Office Equipment & Supplies
Rolling picture
Have you tested the source machine on another TV or projector. The picture might be rolling before it gets to the projector so you need to verify whether it is the source machine or the content then you might be able to determine if it is the actual projector. Sounds like the vertical sync has got lost somewhere.
Hope that helps. Also we can supply lamps for this model if you ever need.
Re your Sharp XV 9000S We are able to supply replacement lamp+housing delivered (excluding local your local taxes) for $US342 as we ship internationally and also the same with our revolutionary ICE Digital Daytime projection screens.
http://www.youtube.com/watch?v=HvZ2DlVJ790 http://www.youtube.com/watch?v=qL_44xfK9y8 Regards Kevin Andreassend ICE AV Technology Ltd http://www.digitaldaytime.com iceavtech@gmail.com +64-9-414 2348
Jul 13, 2008 | SharpVision XV-Z9000U Multimedia Projector
Large white vertical bar thru picture during projection
Two reset attempts to factory settings seems to have been the fix.
Feb 01, 2008 | Toshiba TDP-S8 Multimedia Projector
Rolling line
If this is seen when you are connecting to a cable box or satellite box like DirecTV through or other such device your issue is most likely a DC ground loop. Here are some suggestions:
Video Projector ground loop
1) If you have horizontal hum bars when your projector is connected to a set-top box or other equipment that are on a different circuit or are grounded causing a ground potential between the source and the projector
2) Hum bars are the result of a ground loop, usually caused by cable television that has not been properly grounded
Try this to verify:
1) Disconnect your cable television coax from the wall by unscrewing it.
2) Run your Projector and verify that you are no longer getting the lines.
If you have verified that the issue was a ground loop by testing the solution requires a DC
Ground Blocker style device similar to the below options:
1) Go to http://www.cablesandconnectors.com/02100-02.HTM (part number 2118)
2) Purchase a DC GROUD BLOCKER & ISOLATION TRANSFORMER either from the above or similar electronics store location.
3) Other examples and ground loop explanations for both Video & Audio can be found at the following link for information about ground loop; scroll to Why Ground Loop is a Problem:
http://www.epanorama.net/documents/groundloop/index.html
4) Other commercial antenna signal isolators are available on the web or simply see your local Radio Shack
5) Connect the isolator device chosen to your set-top box and hook it back up.
You will be back-up and running in no time.
Dec 29, 2007 | ASK Proxima Proxima DP2000S Data Video...
Sharp PG-D3050W DLP Projector Logo
12 people viewed this question
Top Sharp Computers & Internet Experts
Tony
Jason Harris
Jason Harris
Mark Dewar
Are you a Sharp Computer and Internet Expert? Answer questions, earn points and help others
