Question about Philips 55PW9363 55" Rear Projection HDTV-Ready Television
Philips projection tv has double images on the corners and on one side of screen
  • Philips Master
  • 3,459 Answers
Your TV most likely has a convergence failure. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
philips
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your conphilips projection tv has double images on the - 0667c5f.pngips are bad and should be replaced. This is a common problem.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Posted on Jun 20, 2009
My magnavox tv has double letters in both red and green images on the bottom 2 inches of the screen
Your convergence has failed. This is a very common problem on most projection tv sets. You can read about it here on fixya using this link
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 09, 2013 | Philips Magnavox 51MP392H Rear Projection...
Red images with green projected to the right with a green halo on upper and lower left corners
This set needs a fluid change. Between the face of the picture tubes and projection lens there is a layer of coolant fluid. The fluid has turned a milky brown color and is degrading the picture. The tubes have to be removed in order to do this properly. I would suggest you contact a repair shop and have them check it out for you as this can be very complicated. Thanks for using fixya and I hope this helps you out.
Nov 04, 2009 | Philips 43P8341 43" Rear Projection...
Blurry picture on left side double image right side is ok....
Ur convergence is dead,need convergence kit.
U know how to solder right?Tries these websites for convergence kit.Tv Repair World.com,Shopjimmy.com,Ebay.com or Partstore.com
Sep 25, 2009 | Zenith IQB50M90W 50" Rear Projection...
Samsung HCN4727W Rear Projection TV, green screen, audio works
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai2_bing.gif,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jul 10, 2009 | Samsung HL-R4667W Rear Projection...
Blue shadows on my philips projection tv
You have possibly contaminated fluid in your blue picture tube if it has a hazy look.Blacks and whites look bluish and whites have a blue bloom to them.The other problem could be bad convergence amps.This would be double image around letters on the screen.
Jan 13, 2009 | Philips Magnavox 51MP392H Rear Projection...
Philips 46-inch Rear Projection with bowed image?? slight distortion
You have a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
One or more colors can't be adjusted when when using the convergence menu.
Screen is bowed in but stationary.
Solution:
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kit for your exact model. The kit inlcludes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc. Everything you need to fix it yourself. Its an easy fix.
Jul 02, 2008 | Philips 46PP9302 46" Rear Projection...
60" Phillips HDTV Rear Projection
You need new convergence ICs two of them numbers STK392-110 they are available at the following link and they provide free installation instructions with pictures as well as free online tech support while you do the repair which takes about an hour. Heres the link.
http://servicemanuals.vstore.ca/
Apr 07, 2008 | Philips Magnavox 9P6034C 60" Rear...
Cracked screen and down screen
If the double images are located at the bottom on one side, you might have cracked the mirror inside the set and it has been displaced making the picture in that area bad (especially if the rest of the picture is OK)
Dec 28, 2007 | Philips 60PP9202 60" Rear Projection...
Philips 55PW9363 55" Rear Projection HDTV-Ready Television Logo
604 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
