Question about YouTube Videos
Bearing torque, what do i torque bearing to?
I replaced the rear wheel bearing on a 1998 sebring convertible. What do i torque the wheel bearing to?
    Top Expert:
  • YouTube Master
  • 14,161 Answers
Posted on Nov 29, 2015
Severe vibration from engine
If it makes the mirror blur without driving the wheels, then I would say main bearing issues.
Jun 08, 2017 | 1998 Ford Explorer
Torque settings for rear wheel bearing, 1998 Escort 1.8 TDI Ghia
If you mean the rear spindle castle nut, tighten until wheel will not turn, then back off until it spins freely. The rear wheel hub retainer is 188-254 ft lbs or 255-345 Nm.
Feb 28, 2011 | 1998 Ford Escort
Procedure for replacing rear whl brgs on a 2003 escape awd
4-Wheel Drive
  1. Before servicing the vehicle, refer to the Precautions Section.
  2. Remove or disconnect the following:
    • Negative battery cable
    • Rear wheel
    • Rear brake shoes
    • Rear halfshaft nut and loosen the halfshaft from the hub
    • Wheel hub and place it in a vise
    • Inner wheel bearing race from the hub
    • Antilock Brake System (ABS) sensor bracket and move the sensor aside, if equipped
    • Parking brake cable from the steering knuckle
    • Brake line from the wheel cylinder and support the knuckle
    • Lower shock absorber nut
    • Lower ball joint by holding the ball joint stud
    • Upper ball joint
    • Coil spring while noting the location of the insulator
    • Steering knuckle cam
    • Steering knuckle
    • Snapring and press out the outer wheel bearing race from the knuckle
      Rear hub and bearing
      Click to Enlarge
To install:
  1. Install or connect the following:
    • New wheel bearing into the steering knuckle
    • Snapring to the knuckle
    • Wheel hub
    • Steering knuckle cam and hand tighten the bolt
    • Coil spring
    • Shock absorber lower nut. Torque the nut to 85 ft. lbs. (115 Nm) for 2002-04 models; 129 ft. lbs. (175 Nm).
    • Upper ball joint. Torque the nut to 76 ft. lbs. (103 Nm).
    • Lower ball joint. Torque the nut to 76 ft. lbs. (103 Nm). Align the steering knuckle cam and torque the bolt to 85 ft. lbs. (115 Nm).
    • Brake line to the wheel cylinder. Torque the brake line bracket bolt to 15 ft. lbs. (20 Nm) and the brake line fastener to 11 ft. lbs. (15 Nm).
    • Parking brake cable to the backing plate. Torque the bolt to 16 ft. lbs. (22 Nm).
    • ABS sensor bracket. Torque the bolt to 80 inch lbs. (9 Nm), if equipped
    • Halfshaft nut. Torque the nut to 214 ft. lbs. (290 Nm).
    • Brake shoes
    • Rear wheel
  2. Fill and bleed the brake system.
  3. Check and adjust the wheel alignment as needed.
2-Wheel Drive
    • Rear wheel
    • Rear brake drum
    • Wheel hub nut
    • Wheel hub
    • Snapring
    • Wheel bearing outer race from the knuckle
      Rear hub removal
      Inner wheel bearing removal-rear hub/bearing
      Rear wheel bearing removal-2wd
      Rear wheel bearing removal-4wd
To install:
  • Wheel bearing in to the knuckle
  • Snapring
  • Wheel hub into the wheel bearing
  • Wheel hub nut. Torque the nut to 214 ft. lbs. (290 Nm).
  • Brake drum
  • Rear wheel
    Rear wheel bearing installation
    hope this helps if so send testimonial comment or even any other questions you have
Jan 16, 2011 | Ford Escape Cars & Trucks
Trying to fine the Weel Lug Nut torque on a 2008 Chrysler Sebring Convertible Limited with 3.5L V-6 and Aluminum Wheels.
Thanks for asking.... most people just use the German torque spec..... "Gut-n-Tight"
100 ft-lbs
and then Re-Check torque after 50 miles!!!
Cheers
Jun 04, 2010 | 2008 Chrysler Sebring Convertible
2001 Sebring LXI convertable. Loud rumbling noise that increases as accelerating increases. Sounds like a rumble strip on the highway. I changed the tires with no change in the noise.
Bad hub bearing. Drive the car on a straght EMPTY road .@30 mph or when noise is audible, **** the wheel left than right (similar to a race car warming. tires) and listen if there is a change in the sound if so its a front bearing if not it should be a rear bearing .Jack the rear of the vehicle up and spin the tire holding onto the strut. Feel and listen for a vibration or noise. This should pinpoint that elusive noise.Let me know Good hunting
Apr 11, 2009 | 1998 Buick Park Avenue
YouTube Videos Logo
57 people viewed this question
Top YouTube Computers & Internet Experts
Rizwan Hanif
Level 1 Expert
Michael Terence...
Michael Terence...
Are you a YouTube Computer and Internet Expert? Answer questions, earn points and help others
