Ecoquest Flair Air Purifier
Problem for Ecoquest Flair Air Purifier
CENTRAL AIR UNIT IS NOT BLOWING INSIDE BUT THE
By dalewilson on Jun 19, 2009
CENTRAL AIR UNIT IS NOT BLOWING INSIDE BUT THE COMPRESSOR OUTSIDE IS RUNNING. WHEN I GO DOWN TO THE BASEMENT TO CHECK THE FILTER-THE BOTTOM OF THE UNIT AND THE FILTER IS WATER LOGGED. ORIGINALLY IT WAS BLOWING WARM AIR FROM THE VENTS INSIDE, BUT NOW NOTHING
HELP!HELP!HELP! IT'S 98* IN HERE.
Best Solution
posted on Jun 19, 2009
Very Helpful)
herodog909
Rank: Guru
Rating: 89%, 88 votes
There may be a leak. You might try shutting it down and taking a look inside. On the other end, there may be something wrong with your components inside. The compressor outside is to provide coolant. Inside, the fans actually cool the air. Make sure all doors are on the blower downstairs, and if all else fails, call a technician. Good luck!
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Ecoquest Flair Air Purifier
Questions and Unsolved Problems for Ecoquest Flair Air Purifier
Do you recommend Ecoquest Flair Air Purifier?
Answer
Answer
just needs cleaned or serviced where do i get this done at
Answer
absolutely nothing happens when i turn it on, it says to check fuse. how do i figure out where the... (More)
Answer
when the unit is on should you see a red light in center i used to but no longer see it.
Answer
Fan doesn't run at all on Flair air purifier, don't see a fuse anywhere that may have popped, no... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Ecoquest Flair Air Purifier:
Top Air Purifier Experts
Rank: Guru Guru
Solutions: 2511
Experience: ASE Certified Master Car and Truck Mechanic Certified AC mechanic Cert. AWS Cert. welder Contract me
Ask Me
Find more Air Purifier Experts
Top Air Conditioner Repair
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
