Question about Canon PowerShot SX210 IS Digital Camera
Canon cameras powershot SX210 memory card error
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 44 Answers
Get another SD card
Posted on Mar 08, 2015
  • 3 Answers
SOURCE: memory card error after inserting SDHC card on powershot A620
the a 620 only goes up to 2 gb no higher
Posted on Jan 28, 2009
  • 51 Answers
SOURCE: Camera reading memory card error, cannot get it to work. Tried removeing the card and replacing batteries. Checked and it is not locked.
try formatting the card once on a pc and then plug it in your camera....if that does not help either, you'll have to try a different card.
Posted on May 20, 2009
  • 11967 Answers
SOURCE: Canon powershot SD1200 IS says Memory Card Error
You probably just need to format the card in the camera. This will completely erase it so download any pictures you want to save first.
Posted on Oct 21, 2009
John Conner
  • 30 Answers
SOURCE: Memory card error message
Cards are coming in different formats and it might be possible that you brought a card which is not suitable or functional with your camera. The other reason could be that we are having options to lock our memory card in digital camera and you might have taken out your earlier card without unlocking it. The system might be broken from inside and this could be a reason that you are still getting a message that memory card is locked. It seems possible based on problem you are sharing.
Posted on May 29, 2010
  • 173 Answers
SOURCE: How do I solve error
The following is an answer taken from site: http://answers.yahoo.com/question/index?qid=20101220203847AAmODI4
"You can try a hard restart:
- put fresh batteries in the camera but no memory card;
- double click the on/off button so the camera turns on, then off;
- hit the button again and, hopefully, it will start normally.
If this doesn't help, call Canon tech support. E-series error codes may indicate hardware or firmware issues that need professional repair. In the U.S. the Canon customer support phone number is: 1-800-OK-CANON."
Hope this will help. Best of luck.
Posted on Jan 08, 2011
Memory card error
There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common cause is having the tiny slide switch on the side of the card in the wrong position. The second most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out. There are also other common causes if the above didn't help, with troubleshooting steps for this problem listed here.
Oct 22, 2011 | Canon PowerShot SX210 IS Digital Camera
My cam says "memory card
If the camera displays Memory card error or No Memory Card when a memory card is inserted or any of the above error messages, make sure that the card is inserted properly. If this is the case, you may wish to Format the memory card in the camera using the Setup Menu option [Format] as shown below. Please be aware that formatting the memory card will remove any images currently stored on the card along with any other data. This can also be caused when images shot with another camera are stored on the memory card.
If after formatting the card in the camera the error persists, try another memory card. If this occurs with only the one card it is likely that the memory card is defective, if the error persists over more than one card the camera may require service. If the card appears to be defective you may wish to contact the memory card manufacturer.
Thank you!!
Sep 04, 2011 | Canon PowerShot SX210 IS Digital Camera
Can i transfer pictures from my camera without use of memory stick or third party wires .is this camera capabl of sending pictures from camera to p.c by email
No and no. You need either a memory card or a wire. There are memory cards that will connect via a wireless connection, but that still requires you to have a memory card.
Jun 15, 2011 | Canon PowerShot SX210 IS Digital Camera
Hi. I have a 16GB memory card. I checked it several times with h2testw software and it's working fine. After I shoot about 4GB I start getting "unidentified image" when I try to see the...
The canon PowerShot SX210 IS only supports memory cards up to 4GB in size. Larger ones will work, but because of the format type the camera uses, it won't be able to read correctly past 4 GB.
May 05, 2011 | Canon PowerShot SX210 IS Digital Camera
I am using the camera for 2 monthes and now its says memory card error. i didnt changed the memory card SDHC what sould i do
Welcome to Fixya. Getting a card error means that:
* memory card is not yet formatted for camera use
* memory card requires cleaning
* using a incompatible memory card
* camera malfunction
Here are some troubleshooting steps that you can do it by yourself. However if the error message still persist, you should contact your Canon service center.
Memory Card not formatted
You have to format the memory card. Some memory card can't be formatted using a PC's, or formatted by another digital camera. I suggest that you have to format the memory card using the camera itself.
Memory Card requires cleaning
Use a dry and soft cloth in cleaning the memory card and the memory acrd slot.
Using a clean pencil eraser can also be useful in cleaning the memory card but you have to be careful, slightly rub the eraser on the memory card.
Incompatible memory card
Please use a compatible memory card
Camera malfunction
In this case you have to contact you service center. It will be a big help if you can check if your camera is still under warranty to get a free service.
Please let me know if you have any questions and if this solution was helpful.
Thank you for using FixYa.
Apr 20, 2011 | Canon PowerShot SX210 IS Digital Camera
How do I solve error e32 on my canon powershot sx210?
Jan 08, 2011 | Canon PowerShot SX210 IS Digital Camera
I can not download the photos from a canon powershot SX210 IS to the computer.. The canon utilities camerawindow show the photos but when i try to download them it appears an error.. i don`t know...
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Oct 29, 2010 | Canon PowerShot SX210 IS Digital Camera
In the process of buying a samsung l301 camera. how many photos can you take?
I would recommend you to buy Nikon Coolpix S4000 Nikon's Coolpix S4000 creates touching memories by combining 12.0 effective megapixels, 4x wide-angle Zoom-Nikkor glass lens and an amazing 3.0-inch High Resolution HVGA (460k-dot) touch-panel LCD with sensitive touch. The Coolpix S4000 also features HD (720p) movies for high quality movie recording. The Coolpix S4000, with Nikon's EXPEED image processing concept, 4-way VR Image Stabilization System and Smart Portrait System enables you to get incredible pictures, incredibly easy. Nikon's Scene Auto Selector automatically analyses the scene you are taking and adjusts the scene mode for you. All you have to do is compose, then touchYou can check out more detailed review for Nikon Coolpix S4000. http://hubpages.com/hub/Nikon-Coolpix-S4000-12-MP-Digital-Camera
Jan 30, 2010 | Samsung Digimax 301 Digital Camera
I am buying a Canon SD970 IS digital camera. What
I would recommend you to buy Canon PowerShot SX210IS 14.1 MP Digital Camera with 14x Wide Angle Optical Image Stabilized Zoom and 3.0-Inch LCD. Decidedly slim and sleekly refined, the PowerShot SX210 IS packs a feature set that reads like a wish list. The 14.1 Megapixel CCD joins a 14x 28mm Wide-Angle Zoom for imaging power to spare. Frame your shots in the bright 3.0-inch widescreen PureColor System LCD, with the Low Light mode for sharp images in dimly-lit situations. It also captures stunning HD movies with Dynamic mode for enhanced image stabilization when shooting movies using wide-angle settings. Capture smooth HD video (720p) with stereo sound for a truly natural, high-quality HD experience. The PowerShot SX210 IS not only goes wherever you do, but takes your photography and video to a whole new place, too. You can check out more detailed review for PowerShot SX210 IS http://hubpages.com/hub/Canon-PowerShot-SX210IS-Digital-Camera
Nov 16, 2009 | Canon PowerShot SD890 IS / IXUS 970 IS...
Canon PowerShot SX210 IS Digital Camera Logo
83 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
