Question about 3M LS950 Laminating System - laminator
Document stuck in roller area - 3M LS950 Laminating System - laminator
How do I fix a Canon MP460 printer that feeds multiple sheets at a time, even for a one-page document, causing a paper jam?
Assumed you have cleaned out the feeding slot and sprockets that turn the feeder wheels. Often there's some piece of paper or gunk. One option that likely applies to most printers -- from another HP online source: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00190540&cc=us&dlc=en&lc=en
  1. Look for paper that might have jammed inside the product. Use a flashlight to carefully view the areas around the rollers. Remove all traces of paper found.
  2. Wipe the rubber paper-feed rollers with a lint-free cloth lightly moistened with distilled or bottled water. Rotate the rollers up carefully to clean all the way around.
  1. Look for the paper pick roller farther inside the rear access area. The paper pick roller
    IMPORTANT : The paper pick roller is a bit more difficult to reach; however, it is the most important part to clean. Make sure to clean it thoroughly. If this roller is not clean, the issue will likely continue.
  2. Clean the paper pick roller with a cotton swab moistened with distilled or bottled water. Apply a moderate amount of pressure to make sure that you remove all debris. Clean the roller thoroughly all the way around. Figure 8: Clean the paper pick roller
    [img border="0" src="http://h10025.www1.hp.com/ewfrf-JAVA/Doc/images/855/c01996641.gif" alt="Photo of cleaning the paper pick roller." title="Photo of cleaning the paper pick roller.">
  3. Make sure that the rollers on the rear access door or duplexer are clean and in good condition. If any are missing, stuck, or loose, replace the rear access door or duplexer with a new one. Figure 9: Rear access door rollers
    [img border="0" src="http://h10025.www1.hp.com/ewfrf-JAVA/Doc/images/968/c01977887.gif" alt="Graphic of the rear access door and paper rollers" title="Graphic of the rear access door and paper rollers">
  4. Allow the rollers to dry completely, and then replace the rear access door or duplexer. Slide the rear access door or duplexer into place, and then gently push it in until it clicks or snaps into place.
Jul 29, 2014 | Canon PIXMA MP460 All-In-One InkJet...
Brother MFC 9440CN - I am getting "Document Jam"
Take the cover off of the ADF, rub clean the rollers with a damp cloth. Make sure there is no paper stuck in the area Also, check that the sensor flags are activating. just move them back and they should bounce back to normal position. Cleaning should do the trick.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Thanks, Joe
Jan 21, 2011 | Brother MFC-9440CN Laser Printer
When printing paper gets stuck. Not rolling thourh
LANIER COPIER PROBLEM SIMILAR TO RICOH COPIER PROBLEM AND IF THE PAPER GOT STUCK ,FIRST YOU MUST SEE AT WHICH
LEVEL/IS IT CRUMBLEB OR JUST MESHED THROUGH OR JUST UNABLE TO PASSED OUT FROM TRAY.
IF PASSED OUT FROM TRAY BUT STUCK AT DUPLEX AREA ,THAT MEANS YOUR FINGER AND MYLAR/RUBBER ROLLER MUST BENDED OR NO GRIP SO YOU HAVE TO REPLACED IT.
IF STUCK FROM THE TRAY, EITHER YOU DID NOT NOT " FAN" THE PAPER BEFORE USE AS NO AIR BETWEEN THE PAPAERSOR HAVE TO REPLACE THE PAD AND UPLIFT ROLLER RUBBER[1 PIECE ONLY PER TRAY]
IF STUCK AT FUSER AREA,JUST CHECK THE UPPER & LOWER ROLLER, THERE SHOULD BE THE ROLLERS NOT MEET TOGETHER. NEE MORE CLARIFICATION
Mar 31, 2010 | Lanier Office Equipment & Supplies
Document feeder will no longer work . It is sluggish and will not longer roll the document through the feeder as if the rollers are stuck?
The rollers may be clogged up with paper fibers. Open the ADF door and see if you can get to the feed rollers. If you can try cleaning them with a Qtip lightly moistened with distilled water. Let them totally dry before trying. The rollers should be sticky/grippy when in good shape.
Mar 18, 2010 | HP Officejet Pro L7680 All-In-One Printer
Whats the scan platform
Scan platform in english is Were you shove the stuff to send ;) ie dirty feed roller, paper detect switch stuck or fragments of paper in original feeding paper path area or feeding stuff too thick or stiff, or if multi document issue it is the pad or roller that sits under the main feed roller...al this is nothiong to do with paper tray full of blanks it is the original feeler area on top..
Same error should occur doing local copy, check feed section/roller
Cheers hope that helps
Nov 19, 2009 | Canon FAX-L1000 Plain Paper Laser
Canon image class 6550 adf area document to long error
You orginal feed rollers may be worn out. when this happens, the paper slips and the machine thinks the paper is too long.
You need to have the ADF rollers replaced.
Jul 06, 2009 | Canon imageCLASS MF6550 All-In-One Laser...
Documents not feeding
There is usually a switch sensor lever in the area where paper is loaded into the document feeder area(near the document feed roller check to see if its not stuck or damaged
Jan 31, 2008 | Sharp AL 1631 Copier
NOISE OR PAPER GETTING STUCK IN FAX MACHINE WHILE SENDING FAX
look in or around scanner area to see if there is any foriegn material trapped in paper handling area.
This is area where the original document feeds through
Jan 22, 2008 | Brother IntelliFAX 2800 Laser Fax
ADF noise and rollers not moving
Dear Hs87 If there is no paper stuck/jam inside the printer and if the motor works fine, plz check again all the threats, there might be a broken threat or untight threat Thanks
Jul 02, 2007 | Canon PIXMA MP830 All-In-One InkJet...
3M LS950 Laminating System - laminator Logo
75 people viewed this question
Top 3M Office Equipment & Supplies Experts
jasbo
jasbo
Are you a 3M Office Equipment and Supply Expert? Answer questions, earn points and help others
