Question about Bernina Activa 130
Threading How do you thread sewing machine
SOURCE: threading the bobbin
It could also be the tension of the thread while you are threading the needle through the upper system. Keep a slight tension on that thread while doing it. Otherwise, make sure that the bobbin thread is 'coming' from the right position on the spindle.
Posted on Nov 15, 2008
SOURCE: Threading a Bernina 900
Place the thread spool on one of the two thread guides. Bring the thread across to the notch on top of the machine guide it to the left and down the front of the machine. Directly under that threader close to the needle wrap it down under and go back to the top right to left then go to the top lever in the up position use your wheel to the right , wrap from right to left going down and threading. Wrapping just means placing around. Now for the bobbin. take casing out wit bobbin thread counter clockwise place in casing and release handle of casing put in machine making sue it is locked in. THen go fishing.
Posted on Dec 13, 2008
  • 23 Answers
SOURCE: My upper thread has stopped picking up the bobbin thread
Try changing the needle again. I have had some cause me trouble even if new. And make sure the bobbin is in the right way.
Posted on Feb 13, 2010
taran_2005
  • 10515 Answers
SOURCE: bernina aurora 430 sewing machine
If the needle has simply ceased to go up and down, I'm afraid that it is an internal component that has come loose or broken.This is not something that a DIYer should attempt to repair.
The internal workings of Bernina machines are at minimum complex finely tuned machines.
I am an experienced handy man and there isn't much that I'm afraid of tearing into. I must admit that I cringe at the thought of my Mom calling me needing one of her her sewing machine worked on. She has about 5 different ones. From an old black Singer to a new Pfaff computerised unit that does it all.I am sorry, but it is best if you have a service center do this repair.As the machine is under warranty, they would be able to repair it without any charge.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Nov 24, 2010
  • 13 Answers
SOURCE: The machine is threaded correctly
First I would replace the needle. Next, completely rethread the machine, making sure the thread is passing through the take-up lever. Next, remove the bobbin and reinsert it. This is a good time to also give the machine a quick cleaning, in case lint or thread is building up anywhere. Then try sewing again on scrap fabric and adjust your tension.
I hope this helps!
Posted on Apr 01, 2011
I have been given a Stitchmaster 1978 sewing machine but can’t see to get the top threading correct. I do not have a manual and can’t find one online! Any advice gratefully received.
You can try looking at some web sites & videos for threading sewing machines. Most machines thread similarly so you may find something close to your machine. Remember to ALWAYS RAISE the presser foot when threading the top thread.
Stitchmaster sewing machine threading Google Search
Feb 12, 2018 | Sewing Machines
Threading vintage sewing machine
hi Kenneth.
you do not give make or model.so not sure if this link will help you but have a look.
Threading vintage sewing machine Google Search
or this link will show you how.
Nov 21, 2017 | Sewing Machines
Threading a nelco 5102
Machines generally thread similarly. Just be sure to ALWAYS RAISE the presser foot when threading the top thread.
Nelco JA 38 Sewing Machine Threading Diagram
Nelco Sewing Machine Manuals Instruction and Repair Manuals
Jul 29, 2017 | Sewing Machines
After threading the machine, start to sew and the thread breaks it seems that it gets caught in step 4 in Threading The Machine in the manual.
Not knowing the make & model of the machine limits out ability to help. What is Step 4? When threading the top thread, ALWAYS RAISE the presser foot. Verify that the thread path is correct--mis-threading is a frequent cause of broken thread.
Sewing Machine Problem 1 Thread Breakage
Sewing Machine Thread Keeps Breaking
Why Is My Thread Breaking How to Avoid Thread Breakage at Your Sewing...
Mar 16, 2017 | Sewing Machines
Why the thread cracked with when i sticked with the machine
Thread breakage could occur for several reasons.
First, try a brand new needle.
Second, use only good quality thread--NOT old thread or bargain bin varieties.
Third, when threading the upper thread, be sure to ALWAYS RAISE the presser foot throughout the threading process.
Verify that the thread path is correct (consult the owner's manual). Incorrect threading will usually break the thread.
Check that the upper thread tension is set at the midway point between the high & low numbers.
Why Does My Top Thread Keep Breaking Sewing Machine
NMSU Checklist of Common Machine Troubles
Why Does My Thread Keep Breaking While Sew
Aug 27, 2016 | Brother ES2000 Computerized Sewing Machine
I have a model 1409A White sewing machine and I'm having issues with threading it. Something is going on with the needle and the bobbin. How do I fix it?
Thread the machine with the presser foot up - this opens the tension for the thread to enter and be controlled as you sew.
Threading with the presser foot down, closes the tension and the thread cannot enter during the threading process and you get loose, loopy stitches that appear to be an issue with the bobbin.
Feb 25, 2010 | White Sewing 1409 Mechanical Sewing...
Need threading diagram for model #1766
Go sewusa.com for a free threading diagram.
Feb 20, 2010 | White Sewing 1766 Mechanical Sewing...
Threading a sewing machine
What do you mean you are unable to pull the bobbin thread through, elaboration would help solve the problem...
I suspect I'm having the same problem with you if it's anything to do with the top thread looping around in the bobbin holder.
Damn machine!
Nov 07, 2007 | Janome Mini Compact
6022 necchi sewing machine
There is a site that has instructions with how to thread the machine properly. Click here for the www.sewusa.com threading section
Nov 03, 2007 | Necchi 3537 Mechanical Sewing Machine
Sewing Machines Logo
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Chris Wetmore
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
