Question about Haier Hvtm12pbb 12bottle Wine Cooler Black
Just stopped working
Noticed that the unit was off and was plugged in. Unplugged unit, cleaned filter, plugged back in-did not come on. Is there a reset button on the unit?
2 Suggested Answers
  • 4736 Answers
SOURCE: unplugged the window unit when
Unfortunately, Haier for whatever reason does not list any error codes or what they indicate in their Owner's Manuals. You will need to contact Haier's Customer Support Dept 1-877-337-3639 to get an indication of what that error code means and how to solve the issue.
I hope this helps you and thanks for choosing FixYa.
Posted on Jul 24, 2011
MY WINDOW UNIT JUST STOPPED WORKING AND NOW IT IS READING E1. HOW DO I GET IT TO WORK AGAIN?
E1-Automatic filter clean reminder.
Turn the air conditioner OFF and unplug it. NOTE: The air conditioner must be unplugged for the automatic filter clean timer to reset.
Clean the filter. See the Care and Cleaning section in your use&care manual. After cleaning, replace the filter and plug the air conditioner back in.
Aug 08, 2011 | Haier hwr10xc6 Air Conditioner
Just stopped working. When I turn unit on the power light comes on for about 2 seconds then goes off, nothing else happens. Any ideas?
It may simply be that the water collection bucket is not installed properly or the air intake filter is clogged.
Turn the Master ON/OFF Switch to OFF and unplug the unit from the wall outlet. Remove the air intake filter and clean it, if necessary. While the unit is unplugged and OFF, remove the water collection bucket and reinstall it. Making sure that the bucket fits "squarely" from top to bottom, in the bucket holder. It must make contact with the bucket safety removal switch, to activate the unit. Once you have reinstalled the bucket, make sure the bottom of the bucket is not tilting downward.
If you cleaned the filter, be sure it is totally dry, before reinstalling it. Then plug the unit back in, turn the Master ON/OFF Switch to ON and if everything was done correctly, the unit should start and run. DO NOT OPERATE THE UNIT, WITHOUT THE AIR INTAKE FILTER INSTALLED.
Hope this helped you to troubleshoot and solve the problem.
Jun 18, 2011 | Maytag Dehumidifiers
Filter light beeping n flashing on a rinnai 556 ftr
Tara, generally that means the filter needs to be removed and cleaned. However, the electric part of the unit must be turned OFF and unplugged, before the filter is removed for cleaning, The unit should remain that way, until the filter is replaced. Then plug the unit back in, turn the Master ON/OFF Switch to ON and the unit will revert back to its original factory settings. From there, you can set it however you like.
Hope this helped you solve the problem. Please let me know. Thanks.
Jun 03, 2011 | Heating & Cooling
I cleaned my Ecoquest, it was working fine, how no power
Assuming that the unit was working fine before you cleaned it. Did you remove the back lower panel while cleaning it? It the panel that holds the electrical socket and fuse. If you did, check to see if the electrical connector is seated to the main board. Also check if the keyboard connector (the one that looks like a telephone jack) is plugged into the main board. Also, check if you model has a switch on the back that it is set to the on position. And press the power switch on the front keypad to see if that make the unit work. That all I can think that might have gone wrong.
Jun 30, 2010 | Ecoquest Fresh Air Air Purifier
Lg dle3777w dryer filter light remains on and dryer is not working even after cleaning the filter.
I'm sure you solved the problem but as i had the same problem on my electric LG front loader and saw no response i figured I would leave one for anybody else in the future. My girlfriend told me the dryer would not start and as i looke i saw the panel would not power up, I unplugged the power cord for 5 minutes and the LG reset and the panel was on and reading clean filter after checking the filter which appeared clean I tried to restart the dryer at which time it powered off. I again unplugged the dryer and replugged it and again the display read clean filter. I then gtabbed a phillips #2 and unscrewed the filter lint sceen which had a total of 4 scews in the interior of the dryer holding the filter housing unit. Youll see a piece of the housing unit remains screwed into the washer hooked up to two electrical plugs. Seperate both plugs from the unit and unscrew it and remove the unit youll notice two silver strips on the unit and I'm guessing will be covered with a small amount of lint. Clean the unit with a brush and damp cloth inside and out reattach the unit screw first and housing unit and turn on. If the dryer again turns off unplug and youll see the clean filter light. Simply push the custom program light or anything similar and the panel should start working again. I hope this helps someone.
Aug 08, 2009 | LG DLE3777 Electric Dryer
The Kenmore air filter will not turn on.
Check the switch and make sure that it is getting power. You can also disconnect the connectors to the swiitch plug the unit back in and touch them together if that works then you know the switch is bad
Feb 14, 2009 | Kenmore EnviroSense 85501 Air Purifier
My haier 5cu.ft. freezer stop freezing
Sounds like the unit has quit, or check the wall outlet to insure there is power there.
Nov 23, 2008 | Haier 5 cu. ft. / 142 liter Chest Freezer...
Electrolux Centralux Vacuum
If the light came on when you plugged it in, then you have power to the unit. You can take a coin and short across the two pins where the small, low voltage wires connect to the unit. Just remove the two wires, they should just pull off, and touch the two pins together with the coin. The unit should come on. If it doesn't, and the light is on, you may have a bad motor or a bad relay on the board inside the unit. Another thing to check is the filter. It has to be installed properly or the unit will not run. The top of the filter depresses a switch so that the unit cannot be operated without a filter in place. Good Luck!
Jul 20, 2008 | Electrolux Centralux Vacuum
LE comes up on the display window halfway through cicle.
IE is a water inlet error. It could be that your water valves are plugged as you suspect. What you can do is put the unit into a test mode and check your valves to see that they are working once you have checked your hoses and connections.
Make sure unit is empty and never try this with anything inside.
press and hold Spin Speed and Soil Level then press on and release
press the start button to advance
1 time tumbles
2 low spin
3 high spin
4 prewash valve (once spinning has stopped valve will turn on)
5 main wash
6 hot water
7 bleach, should be a lesser flow as it has a restrictor
8 tumble counter clockwise
9 temp in tub
10 drain
11 off
if your hoses are clean and the filters, and your water pressure is good, you may have a bad valve.
note, before it starts the door lock will engage.
Sgt 48
Jun 12, 2008 | LG WM1814CW Front Load Washer
Clean Filter Red light
I cleaned the filters as well earlier and the red filter light still blincked to clean the filters. Then I pushed the power button for about 10 seconds continously and then turned it on and the light turned off.
May 22, 2008 | Brookstone Pure-Ion UV Air Purifier
Haier Hvtm12pbb 12bottle Wine Cooler Black Logo
27 people viewed this question
Top Haier Furniture Experts
John Tripp
John Tripp
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a Haier Furniture Expert? Answer questions, earn points and help others
