Question about Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool calypso no control panel lights or function, replaced machine control board four months ago for same problem. Gone bad already?
  • 6,784 Answers
Yes, this particular brand is notorious for this. the actual control boards were reconfigured to no avail.
Unfortunately, you will need to replace this failed control once more.
Posted on Jun 19, 2009
Whirlpool Calypso Washing Machine "Cl or Ca"
The control board is reading too high of an amp draw from the motor,Most likely a bad drive motor.
Sep 01, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
I have a calypso whirlpool washer code ce came up and it wont drain
CE is a communication error between the control board on the control panel, and the motor control board. in most cases this is covered under the warranty from whirlpool but in some cases it is not. in any event the motor control board must be replaced.
Nov 09, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
CE ERROR CODE
ce is communication error could be a bad connection between the 2 boards.( i doubt that) or the drive motor protection open. or the motor controller is bad. there is a notn replacable fuse on some of thos boards. check to see if it is open. Make sure you unplug machine.if it is open replace motor control board. Part #8541034
Oct 25, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso Wash Motion machine is 3 years old and the board is frozen. Model #GVW9959KQ2. We have had the board changed and still frozen. This is the 3rd problem with this machine and no one can...
We ordered a new computer panel for the machine but the machine still does not work. The panel comes on when the machine is plugged in but stuck on the same cycle, estimate time of wash, etc. Now Whirlpool says it's probably the touch pad but that is an additional $127 plus the $122 for the authorized technician. We are already out $300. It is obviously a lemon.
Jul 23, 2008 | Whirlpool Washing Machines
DIM LIGHTS ON CONTOL PANEL
I had the same problem dim lights nothing happens when buttons pushed. I went through the trouble sheet that was in the drying and it pointed me to a bad control board. After replacing the control board it work. Awsome huh. Not it did the same thing a few hours later. I was able to unplug and replug and it worked for a bit and stopped again well after a few times of that it stopped all together. I was kinda upset after spending 135 bucks on that. I didnt want to put any more money into this machine. I took the machine apart and checked all the connections and wires. Removed the front panel and took all the ribbon cables off and made sure those were good too, (didnt short out) everthing checked out. For grins i replaced the 30 amp circuit breaker. The voltage was there but maybe its not getting the amps. I put the drying togeter enough to see what it dose. I didnt want to risk the chance of messing up the control board i bought while doing this so i used the OLD ONe. ( board was sitting on the dryer tub not bolted down). Well low and behold it works. I have been testing it for about 3 hours now. turning it off and on. change the setings on the dryer and so far it is still working. Before it would have messed up already.
Jun 30, 2008 | Whirlpool GEW9250 Electric Dryer
Kenmore Elite Extra Heavy Duty Calypso Top Load Washing Machine
I had this problem and did not have the time to fix it myself so I called Sears. The "tech" looked at his laptop, called his "supervisor" a couple of times and told my wife that both control boards needed replaced at a cost of over $500. The manuals, with testing procedures for the inclined, are on the inside, front cover.
The CE error is a communications failure and on mine it required replacement of the AVS board. I bought the part at a local supply house and replaced it myself for about $175.
Jan 23, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Code CE
CE stands for Communication error. The Calypso has 2 circuit boards inside that touchpad area. One is the motor control board and the other is the machine control board. They are not "talking" to each other for some reason. The boards are warranted for 5 years on most machines. This machine is the subject of a class action lawsuit. Just Google Whirlpool Calypso sit back and start reading.
Dec 06, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
232 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
