Question about Nokia N70 Cellular Phone
MEMORY CARD SLOT FOR N70 CAN'T READ / CANT TRACE MY MEMORY CARD
I VE A PROBLEM WITH MY N70 MEMORY CARD SLOT. AFTER INSERT MY MEMORY CARD, I CANT OPEN / VIEW THE MEMORY CARD FROM FILE MANAGER AND ALSO I CANT VIEW MY PICTURE GALLERY WHICH IS INSIDE THE MEMORY CARD.
WHEN USING CARD READER, MY MEMORY STILL CAN BE READ/VIEW.
PLS ADVISE.
  • leojrecho Jun 19, 2009
    Means my memory card has corrupted or? but why i still can view and open my memory card using the card reader?
    Problem Solver:
  • 11 Answers
1. Is the memory card origina? What's the capacity?
If the capacity of card exceed the limitedness, the phone will not read it. Pls check your memory card.
2. Try to wipe the card with an eraser.
3. NOTE:Pls do not use the memory card when the battery is running down.
For that: The memory card was in use by the phone's media player when the battery died. This caused the memory card to be locked in a session that didn't exist anymore, which caused the phone to ignore the card.
You may put the card into another phone, and it turned out the entire card was corrupt. You have to format it and it may work again.
Ofcourse, you have to sync all your files again....
Other suggestions, you can find here: http://www.1010store.com/forum/viewtopic.php?f=2&t=179&p=384#p384
Posted on Jun 19, 2009
    President:
  • Nokia Master
  • 688 Answers
Your card may need to be formatted for use in the phone. The phone supports FAT32 file system go to Menu - Tools/Setting - MemoryCard - Options - Format Mem Card and click YES
WARNING: Back up you card on your computer first because formatting you will lose your contents
  • Steve Brown
    Steve Brown Jun 19, 2009
    it has to do with possibly the card is not formatted to work in you phone.
    your card reader works because it will read the format of the card and your phone won't.
    Take all the files and copy them to your computer and format the card in your phone. Then transfer your files to your phone with activsync or nokia phone tools or whatever you use.
I forget the password of the memory card(nokaia
well if your phone does not have a file manager place the mem card in one that has one then use the file explorer go to drive c or whatever drive represents the card find a file called mmcstore rename it to a .txt file open it on the phone or if it cant send it to a pc the password would be in it
NB: pls vote
Oct 24, 2009 | Nokia N70 Cellular Phone
Memory Card Not detected in My MOTOROKR E6
if i gave master reset.. it's asking for Security code. I don't have that code. How to set it.
Jun 30, 2009 | Motorola Mobility ROKR E6 Smartphone
Cant open Images saved on memory
you have asked to solve a problem in your nokia.some viruses will block or break some files,when u open .the only remedial measure is,u should formate your memory card using ur mobile then take away that memory card from ur mobile.finally you shall formate ur phone memory using the following code,*#7370#,ur mobile will ask a passward,u should typ 12345.the phone will restart,insert ur memory card.during this operation u will loss all the contacts in ur mobile .for more help,contact sjegathese@yahoo.com.
May 29, 2009 | Nokia N70 Cellular Phone
N70 memory card problem
if you have a memory card reader then I would make sure that the copper strips are cleaned and that its seated firmly and also if you try the memory card reader on a different usb port.
If its an internal one then maybe get an external memory card reader and see if that helps as the internal memory card reader may not be working - to check if its working or not I would right click on my computer --> manage --> disk management and see if it has any drive letter assigned to the memory card - if not right click on it and assign it a drive letter.
Also you can get a utility called USBDLM here
http://www.uwe-sieber.de/usbdlm_e.html
which should help you assign the same drive letter to each memory card whenever you insert it into your computer ( read the read me file for how to set this up which will require altering the inf file in the usbdlm directory )
May 07, 2009 | Nokia N70 Cellular Phone
Hw do i install a software in to my memory card in nokia n70?
first of all insert the memory card in your phone then open the memory card through the file manager.Then remove it and connect it to the pc through the card reader.Copy all the software to the Others folder. Insert the memory card once again and switsh on the phone .Go through the file manager and open the others folder of your card. There you will find the copied softwares .Just click on it and it will guide you through the installation
Nov 13, 2008 | Nokia N70 Cellular Phone
Memory card is corrupted
have you tried with any other memory card .............if you are not able to recognize the memory card there is chance that the slot where memory card is placed might have damaged so contact the service center to get the problem solved ...............
Aug 28, 2008 | Nokia N70 Cellular Phone
N70 - after software update memory card is locked
The default security code for Nokia is 12345.
You can recover the password for MMC card. The best way is to download a file manager to your phone. I use Best Fileman for my N70, from http://www.smartphoneware.com/ It’s for series 60and 40. The trial version should be enough, it’s only £5.60 anyway.
In the file manager (when installed on your phone) you’ll find under- C:\System\mmcstore -the file you’re looking for, you have to rename the file- mmcstore.txt -then send it to another mobile (best way) or your PC via Bluetooth or USB, open it on the other phone or PC, and your password will be revealed.
Rename that file- mmcstore.txt -to just- mmcstore -there might be another file named- mmcstore.txt -to view your password rename one or the other- mmcstore1.txt -one is for your phone PIN number the other your MMC card.
Clear enough?
Apr 08, 2008 | Nokia N70 Cellular Phone
Nokia N70 wont acknowledge memory card?
Note: This device uses a Reduced Size Dual Voltage
(1.8/3V) MultiMediaCard (RS-MMC). To ensure
interoperability, use only dual voltage RS-MMCs. Check
the compatibility of an RS-MMC with its manufacturer or
provider.
Use only compatible Reduced Size MultiMediaCards
(RS-MMC) with this device. Other memory cards, such as
Secure Digital (SD) cards, do not fit in the memory card
slot and are not compatible with this device. Using an
incompatible memory card may damage the memory card
as well as the device, and data stored on the incompatible
card may be corrupted.
You cannot use the memory
card if the door of the
memory card slot is open.
Format a memory card
When a memory card is reformatted, all data on the card
is permanently lost.
Some memory cards are supplied preformatted and others
require formatting. Consult your retailer to find out if you
must format the memory card before you can use it.
To format a memory card, select Options > Format mem.
card
. Select Yes to confirm. When formatting is complete,
enter a name for the memory card, and select OK.
Apr 03, 2008 | Nokia N70 Cellular Phone
Memory Card Password
You can recover the password. The best way is to download a file manager to your phone. I use Best Fileman for my N70, from http://www.smartphoneware.com/ It's for series 60. The trial version should be enough, it's only £5.60 anyway.
In the file manager (when installed on your phone) you'll find under- C:\System\mmcstore -the file you're looking for, you have to rename the file- mmcstore.txt -then send it to another mobile (best way) or your PC via bluetooth or USB, open it on the other phone and your password will be revealed.
Clear enough?
Mar 23, 2008 | Cell Phones
Memory card is not accessible in N70 MUSIC EDITION
buy a new one .but next time when u want to format ,connect to pc suite via pc and then select memory card and delete file by file but never delete an instal program otherwise it will be corrupt again.so if u want to delete instal promgram ,go to tool / application manager and delete it from here.
Feb 21, 2008 | Nokia N70 Cellular Phone
Nokia N70 Cellular Phone Logo
1,453 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
