Question about Garden
Manual for a unico tiller
What size drive belts one for forward and one for reverse
KMusselmann
  • 247 Answers
SOURCE: NEED THE BELT SIZE FOR TILLER ,MODEL NUMBER
Well I cannot find the size but I did find the part # and a place to order the part. Hope this helps
Kurt
Part # 754-0434
Can get from the following
http://www.buymtdonline.com/webapp/wcs/stores/servlet/Home_YardMachines_10101_19502_-1
Posted on Apr 17, 2009
SOURCE: both belts shredded. Atlas garden tiller model 12 -5100
I bought a repair manual from Clymer and found the belt sizes for my Atlas 12.5022 tiller. The manual lists a 1/2 inch by by 36 inch forward belt and 1/2 inch by 32 inch reverse belt for the model 12-5100. Good luck. Don't bother to buy the Clyme manual. It isn't very complete.
Bob Mortimer
mortimer5918@bellsouth.net
Posted on Apr 27, 2009
Typus
  • 69 Answers
SOURCE: Roper tiller 26 inch front tine Pulley/belt diagram
I am not sure either, but I think that it would be alot cheeper to buy a new tiller, than to use your strenght fixing a old tiller that you didn't bother to keep the instructions for (no, I am not trying to be harsh. I am trying to be nice. and I am not sure about it coming with instructions, they usually do.)
29259605.jpgSorry, that is the closest picture that I can get.
Here is a link that may help. (IDK, because it is blocked where I am at.) http://www.google.com/aclk?sa=l&ai=CqcKEPGEMSvvXJJyotgeEiOyLB_jqoUWYtdrOBMib0rsYEAMoB1DU-N7X_P____8BYMmOo4qkpMQRoAGUt9H9A8gBAaoEIU_Q6ppHU85NtRLlGbCSz8M4YQ7k6yZkGAMPo_XJ9i4rSQ&num=3&sig=AGiWqtyvlB5FasgaU109ezFuPnc-65WzHg&q=http://www.fixya.com/support/roper%3Fcmpid%3DG3372595023
Posted on May 14, 2009
harlan301
  • 205 Answers
SOURCE: Tiller goes For./Rev. but wont drive forward with tines engaged
check the sher bolt on the tine to drive shaft. ill need model and ser number off the unit before i can go further with helping you thy changed them around a lot
Posted on Oct 13, 2009
SOURCE: Yardman Rear Tine Tiller tines won't turn. Belt
The problem lies in the shift lever in the gearbox. A poor initial design that was upgraded twice. The shift fork arms have spread enough for pins to come out of the groove they run in when the tiller is shifted to the last position. (Bending back into position would only be a temporary fix as would not be any stronger.) To replace shift lever, the gearbox cover has to be opened. Seperating the cover can be somewhat challenging. When prying cover apart try to not damage the cover gasket. Gearbox grease is very thick, so gasket's real purpose is to keep water and contaminants out. Leave all gearing and chains in place. The shift lever part number is 618-0245B. Or use assembly kit number 753-0869 (contains shift lever 618-0245B, position indicator, and roll pin.) Part will run in the $56-$68 range and can be found through MTD as well as Cub Cadet. Also can get through Sears PartsDirect.
Posted on Dec 13, 2009
Where can I purchase forward and reverse drive belts for a Rally model D5500GR tiller? Part numbers 4833H (forward belt), 2614J (reverse belt).
That's a real common belt fits craftsman and abunch of others you purchase it at any Small equipment parts dealer my favorite is www.jackssmallengine.com Repair website, but their are dozens of others www.searspartsdirect.com Ebay and Amazon also have sellers
Apr 18, 2016 | Garden
I need to no the belt size for the v belt on a scott rearline tiiler the model number is 6070s
This is what I found
Forward belt is a 1/2 by 27 (L4270 or 4L270, Oregon 75-427 )
Reverse belt is a 3/8 by 30 (L3300 or Gates FHP 3300)
May 30, 2014 | Ardisam 5.5 Hp Rear Tine Rototiller
Transmission will not come out of reverse
what year is it does it have Belt Driven or chain drive ? do you put it gear with lever does it have handle to put it in gear ?is ther something stuck on the blades ? does it turn either Way ?
May 26, 2014 | Garden
I have a 40+ year year old TB Horse tiller I need to know how to tighten up the slack in th belts and adjust the reverse disk. I was only 8-9 when my mom bought it for my dad. the main number I saw was a...
Do you know what Horse Power your tiller is? I have a manual for a 7 HP Briggs Troy-bilt that I bought in 89. I presume that you replaced the original belts with new ones?
May 14, 2011 | Troy bilt Horse Roto Tiller Parts Manual...
I just bought a used Pony tiller. It runs good, but after tilling for a couple no hours the forward and tines just stopped. Had not hit anything. It goes in reverse and the tines work in reverse, but I...
Check under the metal or plastic cover just behind the engine. This covers the forward and reverse belts. Your belt either broke, jumped off fthe pulley, or needs a tension adjustment.
Frank
Jul 04, 2009 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Tiller will not till in forward motion.
sounds like your drive belt is worn or the handle bar adjustment is too tall and your handle is not adjusted.
Apr 26, 2009 | Troy-Bilt Pony Garden Tiller
Need a belt diagram
Forward belt is a 1/2 by 27 (L4270)
Reverse belt is a 3/8 by 30 (L3300)
Apr 09, 2009 | Ardisam 5.5 Hp Rear Tine Rototiller
Both belts shredded. Atlas garden tiller model 12 -5100
Bob Mortimer
Mar 24, 2009 | Garden
New belts on Garden Star Tiller but now no neutral
It may be your belt tension or you may have the wrong belt it may be to short.
Mar 14, 2009 | Garden
Garden Logo
64 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
