Question about JVC Audio Players & Recorders
Jvc thm606 subwoofer speaker cable pinout - JVC Audio Players & Recorders
4 Suggested Answers
Cyphet
SOURCE: JVC 8 pin pinout - speaker cable
Looking at the connector, there are 3 rows of pins.
Starting with the first row closest to the alignment mark:
[Power On],[Center Speaker],[Sub Woofer]
[Surround Right],[Speaker Ground],[Surround Left]
[Right],[Left]
If you are trying to connect two JVC units, you will need an 8-pin cable that has the SAME pins connected on each side. You will need to test this using a multimeter set to ohms or 'connectivity'.
There are other 8-pin cables out there like the one for apple networking, but they use a crossover pinout where pin 1 on one end = pin 3 on the other end. This is bad. JVC needs pin 1 to = pin 1.
This is a standard connector/pinout setup that JVC uses, so connecting a TH-C3 to a TH-C50 works fine. There is a bunch of intermixing that you can get away with. The only thing to keep an eye on is the power in watts that one unit sends and the other recieves. Worst case is that the speakers are quiter than expected or that you can turn the volume up so high that it can damage the speakers. In all cases, you should get desired volume somewhere on the dial.
If you are trying to wire the speaker set custom, then you will need to take note that an '8-pin' connector is actually a 9-wire connector. Along with the above pinout, you will need to add Case Ground, which is the metal circle that surrounds the pins. To make the speakers turn on, you will need to apply 12v to the Power On pin and ground the 12v source to the Case Ground outer ring.
The system takes 3 to 4 seconds to fully turn on after this connection is made. Speakers should be wired using the center pin for speaker ground and each other pin respectful to each speaker.
Posted on Dec 10, 2008
  • 6 Answers
SOURCE: Info on the SW9800 Subwoofer
I need that junction box too, som one have?Please
Posted on Sep 11, 2009
  • 137 Answers
SOURCE: does anyone have the pinout for the subwoofer
PIN 1 L. PIN 2 R. PIN 3 SL. PIN 4 GRD. PIN 5 SR.PIN 6 SW.PIN 7 C. PIN 8 P.ON
Posted on Apr 16, 2010
Tip
DELL A425 SUBWOFFER PINOUT
CABLE PIN OUT
PIN 1 SPEAKER 1 PIN 5 SPEAKER 2 PIN 3 INPUT 1
PIN 4 INPUT 2 PIN 8 EXTERNAL VOLUME CONTROL PIN 2-5-7-9 GRD
PIN 8 MUST TO GROUNDED FOR MAXIMUM VOLUME OUTPUT
on Jun 25, 2014 | Dell Zylux Powered Subwoofer - P/n A425
I have a jvc th-m606 receiver and I don't have a subwoofer for it, is there a different way for me to get audio output or a different subwoofer I can use?
You would have to make a cable that goes from the 8 pin mini din of the jvc unit to each individual speaker. A wiring diagram can be found online each pin on your 8 pin goes to a speaker , and one is for power. Find a wiring diagram and find a cheap electric store that can make the cable for you. I had the same problem...
Aug 10, 2012 | JVC TH-M606 System
Does anyone have the pinout for the subwoofer cable
Apr 15, 2010 | JVC TH-C40 System
My JVC SP-PWM508 no longer functions.
I am looking for the cable connecting the sub woofer and the main system(CD Player)
Mar 14, 2010 | JVC SP-PW100 Subwoofer
[Right],[Left]
Apr 01, 2008 | JVC TH-C50 System
HK395 Speakers/Subwoofer Cable
Jul 26, 2007 | Dell HK395 Computer Speakers
23 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Henry  Thomas
Henry Thomas
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
