Sony str kg700
There's a high pitched noise while listning to my sony ? is it broke or is there something wrong in the settings ?
rogrrabbit
  • 986 Answers
SOURCE: I HAVE A SONY STR-KG700 5.1 SISTEM, AND SOON I`LL
I would just buy a transformer for the unit 220 to 120. That way when you move back your good to go.
Posted on Jun 14, 2009
  • 49 Answers
SOURCE: can't get surround sound when watching tv
just dont put the jacks in from the tv plug satelite jacks in (use optic cable) dvd use orange digital cable and so on if u do it this way and have the same issues then i would 100% say its a reviever issue
(hope u kept the recipt)
Posted on Sep 27, 2009
dunnbiker
  • 8546 Answers
SOURCE: I have a Sony STR-DE435 that won't turn on
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'nekkid'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as another possible root cause for intermittent shutdown.
Posted on Sep 08, 2011
dunnbiker
  • 8546 Answers
SOURCE: There is an intermittent, high-pitched
I've had variable track lighting cause a similar problem and only with analog sources. Is it only with track lights on?
Posted on Sep 22, 2011
gopakumarg43
  • 74383 Answers
SOURCE: High Pitched Noise Coming from Sony STR-DH510 LCD Screen - how to fix?
Hello
The problem is with its backlight inverter board. there are some step-up transformeres [small ones] fitted on board. If any one's core bacome loose this fault will occur. Just open the TV and listen to which one makes hi-pitch noise. Replace it, if you can buy it from the electronic market at your town. In most cases, the inverter board needs replacement.
This board can locate on the right or left side of the panel, fitted vertically.
http://www.dataentryjobs.us/67948.html
Posted on Feb 18, 2012
Need a schematic diagram for Sony STR-KG700
str z 2062 checking multimeter method
Dec 23, 2013 | Radio Communications
Hello
Feb 17, 2012 | Sony Audio Players & Recorders
I have a Sony STR-DG520 5.1 receiver. My problem is that I can hear a high pitched background whine from all the speakers, even if the volume is set to zero or muted! If I switch the audio source off, the...
do u have the unit earth grounded? sounds like AC hum, most amps have a ground lug, make sure that is grouned and the power plug to o the amp has a good ground.
Jun 15, 2010 | Sony STR-DG520 Receiver
Green and red ligts flash when powerd up also
hello there's a couple of things that could be wrong .the high pitch noise could be the convegance chip shorted out these are 2 big black chips connected to a metal frame called a heatsink the other could be the lamp burn't out
shaun
Oct 21, 2009 | Sony Grand WEGA KF50SX300 50" Television
RCA 57 inch hdtv Model#HD56W58 has sound but no picture.
WOW...had a high pitch noise, came and went...got worse as time wore on. Would shut off the set, times it cleared times it didn't. Warranty folks set out a TV repairman--said he had worked for RCA exclusively for years...anyway, explained that the 1k hertz noise was a known issue with the HD56W58 and that RCA’s published fix was "nail polish" applied on some board, had something to due with power and vibration...long story "presto" noise gone...but after 6 or so months we began to hear it again—say it ain’t so, but yes the high pitch was back. Same repairman, this time bigger problem...along with noise, the network card is broke and Fry’s Electronics (Irving, TX—hear that Corporate HQ at San Jose…your Irving store needs to be leased in and tote the company line...where's the customer satisfaction???) is balking at a “equal” replacement, they see it as take the less than equal product or get store credit…good luck & wish me luck with the equal replacement they tout when pushing the warranty.
Mar 15, 2009 | RCA HD56W58 56" TV
Pelonis HO-0128 makes strange noise
Nothing wrong with it. This is a normal sound made as the oil heats. As the heater heats up, the sounds should subside.
Nov 19, 2008 | Pelonis WM-HO202C Oil Filled Radiator...
Can't get surround sound when watching tv
your RCA on your tv is acting like its in mono..it may be a problem with the jacks.  alternatively..you can buy a splitter and split teh side that sounds stronger (L) or (R) with a male to 2 female spliter out of the tv then back into l/r input on your reciever... It wont give you surround stereo...but it will soudn a whole lot better.
Nov 08, 2008 | Sony STR-DG800 Receiver
 Grubhead
Grubhead
