Please i like to know where can I get your database forms?
2 Suggested Answers
  • 108 Answers
SOURCE: c database with formdesigns
You are at least by looking at what you are trying to do familair with far more than the average user. On the other hand you have not supplied the names of what you are doing or as good a description of the problem as might be necessary to pose a meaningful solution. SO....my suggestion is you check faq's at your suppliers website, google the internet with your specific problem, and go to your O/S suppliers website (i.e. the Microsoft knowledge base) for more help.
Posted on Jan 24, 2008
I need to perform access database repair
The repair method attempts to recover only the tables, indexes and queries in the database. Do not attempt to repair damaged forms, reports, macros and modules. Before executing the Compact and Repair tool, please ensure the following condition:
1. Do not Open Access database must closed
2. Sufficient storage space available - minimum double in size of your Access database on that Disk.
3. Close the .mdb file related to .ldb file before you delete the .ldb file.
4. Then Run the Compact and Repair tool
Read more about Access Repair Toolbox
On:- http://www.access.repairtoolbox.com/
I tried lots of the suggestions and eventually found that this page was the most helpful http://www.filerepairforum.com/forum/microsoft/microsoft-aa/access/1385-%E2%80%8Bhardly-corrupted-access-2007-database
Feb 28, 2015 | Microsoft Office Access 2007 for PC
How to make the library managment project with VB.Net & using MS Access as for database.& please help me out what code should I use for making that project?
firstly you have to create a database and in that you have to create tables as per your requirement.
secondly, create forms in vb and connect the database, as per your requrement. it is not possible to give all the codes. use some e-books.
Nov 19, 2009 | Computers & Internet
Ms-Access
this discussion could go on for days (month? a semester at least?) but data is any piece of information you want to capture and save. a name. an address. a phone number. (actually they are examples of pieces of data - and whether you capture and save them or not they are still pieces of data). data "forms" a database when you save it (in the dataabase).
the database usually has tables representing related pieces of infomation.
Example:
the CLIENT table may have the following fields:
Client Number
Client Name
Address
Phone
Contact name
etc., etc.
the ACCOUNTS_RECEIVABLE table may have
Client Number
Invoice Number
Invoice Date
Invoice amount
etc., etc.
Notice how the CLIENTS table is "related" to the ACCOUNTS_RECEIVABLE table by the Client Number - hence the term you may have heard RELATIONAL database.
any more in depth please ask.
Mar 04, 2009 | Microsoft Computers & Internet
Database talks to code but code won't talk to database
Make sure you are connecting to the database,then just before you call your sql to insert use an echo statement to display the sql and check it for syntax:-
$sql = 'insert into table1 values('.$no.','.$no.',"block","'.$value3.'", "'.$value4.'")';
echo "SQL ==>" STARTOFSQL<br>".$sql." ENDOFSQL<br>";
Jan 18, 2009 | The PHP Group PHP
Storage of MS-Access 2007
(please refer for www.office.microsoft.com for further information)
Database specifications Attribute Maximum Access database (.accdb) file size 2 gigabytes, minus the space needed for system objects Note NOTE: Although the maximum size for a single database file is 2GB, you can work around this limitation by using a split database. A front-end database file can point to thousands of back-end database files, each of which could be as large as 2GB. For more information, see the topic, Split a database.
Number of objects in a database 32,768 Number of modules (including forms and reports that have the HasModule property set to True) 1,000 Number of characters in an object name 64 Number of characters in a password 20 Number of characters in a user name or group name 20 Number of concurrent users 255 Table Attribute Maximum Number of characters in a table name 64 Number of characters in a field name 64 Number of fields in a table 255 Number of open tables 2048; the actual number might be smaller because of tables opened internally by Access Table size 2 gigabyte minus the space needed for the system objects Number of characters in a Text field 255 Number of characters in a Memo field 65,535 when entering data through the user interface;
2 gigabytes of character storage when entering data programmatically Size of an OLE Object field 1 gigabyte Number of indexes in a table 32 Number of fields in an index 10 Number of characters in a validation message 255 Number of characters in a validation rule 2,048 Number of characters in a table or field description 255 Number of characters in a record (excluding Memo and OLE Object fields) when the UnicodeCompression property of the fields is set to Yes 4,000 Number of characters in a field property setting 255 Query Attribute Maximum Number of enforced relationships 32 per table, minus the number of indexes that are on the table for fields or combinations of fields that are not involved in relationships* Number of tables in a query 32* Number of joins in a query 16* Number of fields in a recordset 255 Recordset size 1 gigabyte Sort limit 255 characters in one or more fields Number of levels of nested queries 50* Number of characters in a cell in the query design grid 1,024 Number of characters for a parameter in a parameter query 255 Number of AND operators in a WHERE or HAVING clause 99* Number of characters in an SQL statement Approximately 64,000* *Maximum values might be lower if the query includes multivalued lookup fields.
Form and report Attribute Maximum Number of characters in a label 2,048 Number of characters in a text box 65,535 Form or report width 22 in. (55.87 cm) Section height 22 in. (55.87 cm) Height of all sections plus section headers (in Design view) 200 in. (508 cm) Number of levels of nested forms or reports 7 Number of fields or expressions that you can sort or group on in a report 10 Number of headers and footers in a report 1 report header/footer;
1 page header/footer;
10 group headers/footers Number of printed pages in a report 65,536 Number of controls and sections that you can add over the lifetime of the form or report 754 Number of characters in an SQL statement that serves as the Recordsource or Rowsource property of a form, report, or control (both .accdb and .adp) 32,750 Macro Attribute Maximum Number of actions in a macro 999 Number of characters in a condition 255 Number of characters in a comment 255 Number of characters in an action argument 255 default.aspx?assetid=za100776681033 Top of Page
Project specifications The following list of tables is specific to Office Access 2007 projects:
General Attribute Maximum Number of objects in an Access project (.adp) 32,768 Number of modules (including forms and reports that have the HasModule property set to True) 1,000 Number of characters in an object name 64 Number of columns in a table 250 (Microsoft SQL Server 6.5) 1024 (Microsoft SQL Server 7.0, 2000 and 2005)
Microsoft SQL Server database Microsoft SQL Server maximum capacity specifications are described in the SQL Server documentation. Form and report Attribute Maximum Number of characters in a label 2,048 Number of characters in a text box 65,535 Form or report width 22 in. (55.87 cm) Section height 22 in. (55.87 cm) Height of all sections plus section headers (in Design view) 200 in. (508 cm) Number of levels of nested forms or reports 7 Number of fields or expressions that you can sort or group on in a report 10 Number of headers and footers in a report 1 report header/footer;
10 group headers/footers Number of printed pages in a report 65,536 Number of controls and sections you can add over the lifetime of the form or report 754 Number of characters in an SQL statement that serves as the Recordsource or Rowsource property of a form, report, or control (both .accdb and .adp) 32,750 Macro Attribute Maximum Number of actions in a macro 999 Number of characters in a condition 255 Number of characters in a comment 255 Number of characters in an action argument 255
Zulfikar Ali
Jan 16, 2009 | Microsoft Computers & Internet
Forming new database...reset button...then nothing!
Go to the RCA website download the latest firmware.
then plug your mp3 player into usb device of your computer.
Install the firmware while its installing hold down the power button for about 15 seconds.
Jan 12, 2009 | RCA OPAL M4001 MP3 Player
Tabs/sub-form in access 2007 form will not scroll down?
open the form in design view open the properties dialog box by right clicking in the general form area not in the gray area of the detail section. In the properties click on the format tab. In the format tab goto the default view and select continuous form. This should create a virtical scroll bar once a record in the data base.
Dec 30, 2008 | Microsoft Office Professional 2007 Full...
Data storage form
If you give me a bit more detail about what you're trying to do, I would be happy to help.
I think you are interested in building a form that will add records to a database. Am I correct?
Tell me the language you are using, and the type of db. I know you are interested in SQL, but perhaps you are using Access.
If I guessed you are trying to create a web form that adds records to a database would I be correct?
The more detail you can offer, the more I can be of help.
Best Regards,
airoff (Alan)
Jul 17, 2008 | Microsoft Windows Server Standard 2003 for...
C database with formdesigns
Jan 18, 2008 | Computers & Internet
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
