Question about Hayward H-series Electronic Gas Pool Heater H400
Po code on hayward h400idl2
UNIT INITIALLY FIRES THEN SHUTS OFF AFTER 15 SEC. FLASHES BOTH PO AND AO CODES. CODE LABEL IS TOO BADLY WEATHERED TO READ.
    Top Expert:
  • Hayward Master
  • 8,502 Answers
Check flame sensor
Posted on Mar 19, 2016
  • 8 Answers
SOURCE: I just installed a new Hayward H400FDN and it will not stay lit.
I had the same issue...you don't have enough gas pressure.
Posted on May 12, 2009
  • 990 Answers
SOURCE: Hayward H400 heater won't light and service light
This is a code for what is called a prover switch. What it is a circut for the air pressures. Depending on model you can have one or two of these. Their will always be one for the exaust perssure and this will often be the culpret. If the sensor is good a sooted exchanger, rat nests on the exchanger or in the exaust can cause this. If you have a second switch it will be for burner air pressure and you will look for the same problems only inside the burner cabnet. Good luck, I'm sorry I can't be more help. But at least you know to look to the vent system.
Posted on Dec 29, 2009
  • 4 Answers
SOURCE: I had code AO displayed on my hayward H250IDE. I
Check your wiring again on all the safety devices - Water pressure switch and both Hi- limits in the header.
Posted on Mar 01, 2010
Testimonial: "Thank you very much for the assit. I did find a kink in the vent safety switch. Thanks again."
john224
  • 1378 Answers
SOURCE: My hayward heater fires up and then turns off
Thank you for posting your question here on Fixya.com.
The basics are covered in this excerpt from your owner’s manual. If you need direction or additional information about these steps please post your specific questions.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Posted on Apr 13, 2010
  • 64 Answers
SOURCE: H Series Pool & Spa Heater 400k Btu Propane Gas Milivolt Ignition H400p1: how do i fix the AO code on my hayward heater?...
AO will apply to your blower, blower tubing, or blower vacuum switch. You need to check these items.
Posted on May 20, 2010
Ao & po codes on hayward h400idl2
check gas and ignitor if ok pressure switch or safety circuit
Apr 17, 2014 | Hayward H-series Electronic Gas Pool...
Mustang codes
Where are you reading this code?
Jun 17, 2008 | 2005 Ford Mustang
What is code 168 on 2000 plymouth voyager
Most codes start with PO then the code
When you get a good code just Google
OBD2 Code & the PO #
Mar 07, 2013 | Cars & Trucks
06 vw passat with code po 2098 possible problem and a possible fix
If you mean P2098 read on, Po 2098 is not a vaild code, all codes for OBD2 have one letter (P, B, etc.) and four numbers 0-9.
P2098 VOLKSWAGEN - Post Catalyst Fuel Trim System Too Lean Bank 2
Possible causes- Low fuel pressure
- Engine misfire
- Large vacuum leak
- Blocked converter
- Faulty O2 sensor bank 2
Read more: http://engine-codes.com/p2098_volkswagen.html#ixzz2BxcAojuy
Nov 11, 2012 | Cars & Trucks
Po316, po 300, po301, po305 2004 ford freestar
These codes are making me lean towards the ignition coil pack.My stepson's 2001 Sable 3.0 v6 had one cylinder misfiring(5-code P0305),which shares a coil with cylinder 1(code P0301).I diagnosed it by trading wire 1 and 5 at the coil,and the code changed to P0301.You have codes for the two cylinders on the same coil,so this is most likely it.(these codes would also trigger P0300(Multiple Misfires Detected) and P0316(Misfire Detected First 1000 Revs)).
Oct 14, 2012 | 2004 Ford Freestar
Error codes po 134 po 153 po 154 po 155 po 171 po 174
PO 134 = 02 SENSOR CIRCUIT NO ACTIVITY DETECTED (BANK 1 SENSOR1)
PO 153 =02 SENSOR CIRCUIT SLOW RESPONSE (BANK 2 SENSOR 1)
PO 154 =02 SENSOR CIRCUIT NO ACTIVITY DETECTED (BANK 2 SENSOR 1)
PO 155= 02 SENSOR HEATER CIRCUIT MALFUNCTION (BANK 2 SENSOR 1)
PO 171= SYSTEM TOO LEAN (BANK 1)
PO 174= SYSTEM TOO LEAN (BANK 2)
I WOULD SAY YOU HAVE FAULTY OXYGEN SENSORS CAUSING THE ENGINE TO RUN TOO LEAN REPLACE THEM AND YOU SHOULD BE BACK IN BUISNESS
Feb 23, 2011 | 2004 Suzuki Grand Vitara
Car codes Dodge Caravan 2002
new spark plugs basic tune up this will fix it ,then fine the small vacuum leak fix it this should take care of it.
May 10, 2010 | 2002 Dodge Grand Caravan
I have a error code reading of PO 743, Torque converter clutch, what does that mean?
It sounds like the convertor in the exhaust system is partly blocked. You will need to have this checked at a shop. Frankster016
Oct 26, 2008 | 2000 Ford Expedition
Mustang codes
Go to your local dealer and ask him to re-store your software, it should work.
Hayward H-series Electronic Gas Pool Heater H400 Logo
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
