Question about Cuisinart DCC-1200 Coffee Maker
Cuisinart coffee carafe leaks when pouring - Cuisinart DCC-1200 Coffee Maker
  • 142 Answers
SOURCE: Cuisinart DCC1000 coffee maker
At the bottom of the reservoir there is a hole the water flows through to the heater. When my coffeemaker did what yours does it was because a little valve that sits in that hole had popped out, and after tamping it back in it solved the problem. The valve is supposed to keep the hot water from going back up into the reservoir. Without it the water backs up, causing the steam to shoot up as you know, and heats up the water in the reservoir. This causes the thermostat to turn it off prematurely. The valve can come out of the hole either if the coffeemaker is turned upside down, or if there is a major buildup of mineral deposits that need to be flushed out -- they can overheat and cause too much back-pressure to the valve. Flush it with vinegar and push the valve back in as tight as you can, then be careful if you turn it upside down.
Posted on Jan 26, 2008
  • 6 Answers
SOURCE: Water leaking from the base of the unit.
Water leaking in the DGB-600 is mainly caused by heated water escaping from its proper path. There is a rubber grommet on the underside of the upper part of the coffeemaker. (It contacts the lid over the filter basket when the front door is closed.) The design in this area is very poor; the grommet does not seat properly in the fixed part of the coffeemaker, and heated water seeps out. Also, the heated water tube that comes up through the cold water reservoir is actually in 2 pieces. One goes inside of the other, but there is no seal. It is a loose enough fit that some steam escapes, condenses on the inside top surface of the coffeemaker, and then finds its way down to add to the leaking. I completely disassembled my coffeemaker (3 of the screws in the upper compartment are hidden under small circular plugs that look like they are part of the plastic surface), and used high temperature automotive RTV sealer to help the rubber grommet seal better, and to seal the 2-piece hot water tube. Works great now! But I must say that I have seen better engineering in childs' toys!
Posted on Aug 12, 2008
SOURCE: Leaking cuisinart grind and brew
Our Cuisinart grind and brew was leaving a puddle under it after making a pot of coffee. I called Cuisinart this week and it turns out the handle of the carafe has to be lined up in the middle of the opening for the carafe. It will be under the word Cuisinart, in the middle.
We have now made several pots with NO residual puddle of water or coffee. It also seems to be making the pots quicker.
Before trying this I had run 2 pots of water with 1/2 cup white vinegar in it also. But it still puddled until we lined up the carafe as noted above.
Posted on Jan 16, 2009
SOURCE: Cuisinart DGB-300 coffee maker brew pause valve
I just called Cuisinart and they will send me another brew basket for my DCC-100 (it has a Brew Pause valve also) for $9.14 (part + S&H). Did you try to contact Cuisinart?
Posted on Feb 03, 2009
  • 13 Answers
SOURCE: Cuisinart coffee maker turns on but will not brew.
Well, you could try unplugging for an hour. Sometimes that helps, but these have been having a lot of problems (but don't ask their customer service that, they can't admit it but I'm pretty sure they all know it!). I would say call customer service anyway if it's under 3 years old (800-726-0190) after you've unplugged it and let them know what's going on (model and serial # are both located on the bottom of the unit, stamped in the black part). If it's under warranty they can offer you a replacement and from what I hear Cuisinart has been getting in new coffee on demand units (like the one you have) that have fixed the problems. They're on back order right now though, so there will be a wait. Other than that, I would say you don't have many options, unless the store is willing to take it back, because this one is pretty much a goner. Not the first time I've seen it. :(
Posted on Aug 28, 2009
Coffee spilling over the top , not dripping
The caraffe lid must be on the Coffee maker while making coffee.
The lid pushes a opens the hut-of valve in the filter.
If the lid is not on the caraffe, the valve will prevent coffee from dripping out of the filter.
This is to prevent coffee leaking on the lower carafe heating element when you remove the caraffe to quickly pour some coffee. the water accumulates while you do this, so if the machine is still brewing, you should put the carafe with lid back in the cofee maker, to release the accumulated liquid in the filter.
Jun 08, 2012 | Cuisinart DCC-1200 Coffee Maker
Carafe dribbles coffee no matter what you do. Pour fast, pour slow, dry the outside etc. Can't believe they can't make a pour spout that doesn't dribble. Any suggestions?
I often ask why we can put a man on the moon, but not make a coffee maker that doesn't dribble when I pour. I have the same trouble, and what I have found works for me is to be very careful that I am pouring with the spout dead center, and pouring fairly slowly. A little off to the side of the spout, and I'm cleaning the floor. But if I pour so the flow is right through the center, it works for me.
Good luck. And if you design the perfect carafe before I do, let me know. I'll buy one!
Dec 04, 2010 | Cuisinart DCC-450 Coffee Maker
Coffee leaks all over the counter every time coffee is made. coffee appears to be coming out of bottom of machine Coffee pot lid is on correctly.
I had this problem after about a year of use. The thermal carafe lid had become clogged enough with coffee sludge (fine grounds/oil) and hard water deposits to slow the flow through the lid. I soaked the lid in a bowl of 2 cups hot soapy water + 2/3 cup white vinegar for a few hours, agitating the lid in the mixture every 1/2 hour or so.
Then, I rinsed the lid and packed baking soda in every opening and dropped it back into the mixture - hoping the fizzing action of the baking soda+vinegar would help loosen any remaining sludge.
I rinsed it again, and whacked it against the side of the sink for a final effort to loosen sludge. Repeated the baking soda + rinse + whacking a couple of times. No more problems.
In the future, I plan to do the soak at every Cleaning cycle/every couple of months.
Or, if you don't want to deal with it, replacement thermal carafe lids are available from Cuisinart for $6 + shipping.
Jul 29, 2009 | Cuisinart DCC-1200 Coffee Maker
BUNN BT10B carafe leaks from spout down side while pouring
I emailed the company again and they are replacing the thermal carafe at no charge. Thanks!
Nov 15, 2008 | Bunn BT10B Coffee Maker
Dcc1100 carafe
You can get them at www.cuisinart.com or by calling Cuisinart
Oct 25, 2008 | Cuisinart Coffeemakers
Waring Pro WC1000: Pour over 12 cup coffee maker
Waring Pro WC1000 coffee maker replacement carafe is Waring WC1000CRF glass replacement coffee pot. Black lid and black handle.
http://www.bestreplacementpart.com/waring-pro-wc1000-replacement-carafe/
Feb 20, 2008 | Waring Pro WC1000 Coffee Maker
Water is leaking from bottom of base.
I just had good luck pulling the grinder bottom piece forward while pulling directly up on the blade mechanism. Hope this helps.
Dec 25, 2007 | Cuisinart DGB-600 Coffee Maker
Nov 30, 2007 | Cuisinart Coffeemakers
Aug 30, 2007 | Cuisinart DGB-300 Coffee Maker
Cuisinart DCC-1200 Coffee Maker Logo
118 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
