Question about Home
Porcher 9051 p1 - Home
Where can I find a replacement parts to rebuild a porcher Veneto one piece toilet
http://www.porcher-us.com/assets/documents/porcher/spec/SpecSheet_3362.pdf
http://www.guillens.com/POR/9712.htm
Parts breakdown.
Specs are above. Immediately below is the company site but they may only offer some support rather than directly providing any parts. I list a couple of possible sources for parts after that.
Welcome to Porcher
http://www.guillens.com/buy/product/97120-00-001/22791
Porcher Faucet Toilet Parts
Dec 19, 2017 | Porcher Home
How do I remove expansive cap holding screw so I can replace broken toilet seat?
Porcher 70018 Bathroom Toilet Seat Round Front ... - Fixya
www.fixya.com/support/...porcher_70018_bathroom_toilet_seat.../popul...
Popular Porcher 70018 Bathroom Toilet Seat Round Front White questions, problems & fixes. Find expert solutions to common issues, DIY guides, repair tips ...
Aug 25, 2015 | Porcher 70018 Bathroom Toilet Seat Round...
I need a toilet seat replacement of Porcher Veneto Toilet. The part number is 70030-00-001 and I'm told by Porcher is no longer available. They say no other seat fits. Any ideas? Where to find
I had the same issue and basically called every single american standard distributor I could find. I finally found one! They had the gold hinges but I didnt care, it fits and works fine. Make sure you know the part number. I had a good salesperson that knew to look for any color hinge so I had a seat
Jan 08, 2013 | Porcher Toilet Seat Veneto 70030.071
Where do I get porcher 83420
Hello--
That particular model has been disontinued; however, you may want to contact Customer Service to see if there are any spare parts in stock.
http://www.porcher-us.com/contact.aspx
Paul, ASB
Sep 20, 2011 | Porcher 83420-00.000 L'Expression Toilet...
LOOKING FOR A SEAL FOR A PORCHER TOILET...I HAVE A PICTURE OF THE SEAL IF I CAN SEND IT TO YOU... THANKS BASH 0799299095
If you are in the USA you can find your closest dealer here or an on-line retailer:
http://www.porcher-us.com/dealerLocator.aspx
Home Depot is one of their retailers; however the link provided is not working. Go here.
You may be able to find a universal product that is a compatible replacement.
Mar 01, 2011 | Porcher Home
Need to gt the top off of a porcher toilet we can't fogure out how to get into the tank to fix whatever continues to run
I'm not sure why this is a challenge. The lid should just lift right off unless you have a wall mount toilet. Here is a .pdf of a typical Porcher toilet and how it all goes together. There is also a handy trouble shooting guide. If the toilet is running the culprit is either a faulty flapper or fill vavle. Let me knwo if I can be of any further help.
http://www.porcher-us.com/assets/documents/porcher/install/Install_3337.pdf
Jul 31, 2010 | Home
Porcher 6.0 Lpf / 1.6 toilet. Plumber said he
Try replacing the flapper, they are cheap and so long as the tank and or bowl are not cracked you can replace all of the internal parts and basically have a brand new toilet much cheaper then replacing the entire unit. Go down to your local hardware store and everything you need is in one simple kit with very simple instructions. Good Luck.
Jul 21, 2010 | Porcher Home
Installing part 903091-9051 in a wall oven Frigidare FEB24S2ASB
YES ITS NOT SO BAD. I RECOMEND TAKING ONE WIRE OFF THE OLD AND PLUGGING ON THE NEW ONE AT A TIME SO YOU DONT MISSWIRE.
Mar 07, 2010 | Frigidaire FEB24S2AS / FEB24S2AB Electric...
Home Logo
55 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
