Question about Campbell Hausfeld 1,350 Psi Electric Pressure Washer With Auto Detail Kit #PW1350
Sprayer doesn't spray, deteregent leaks out
I haven't used mine in a couple of years. I turned it on this spring, the motor runs but nothing comes out of the sprayer. Plus my detergent leaks out of the plastic tube. I lost my manual. Any help would be appreciated.
Spray nozzle leaks
That would be your best bet very well could be a bad sprayer housing
Jan 23, 2018 | Rohl Plumbing
Frigidaire Model FDB780RCB0 I am getting water in the machine but it seems the arms are not turning what can I do to get that fixed?
The pump in the dishwasher is supposed to provide enough water pressure to turn the spray arms and make them rotate. The pump is faulty and not giving enough pressure or the arms are stuck.
Try spinning the arms, if they rotate smoothly, you will need to replace the pump.
Aug 03, 2008 | Frigidaire Dishwashers
I have a Vigo Faucet with a commercial spray arm. When I depress the spray lever it sprays for a second then stops and then when I try to use the regular faucet nothing comes out. Then if I turn on the...
Clogged sprayer.
take apart the screen on the sprayer and clean it out. run the water through the faucet without the screen for a minute and then reassemble.
Sep 13, 2013 | Plumbing
My graco xr5 sprays when i turn tip to spray position
If paint comes out of the spray gun after you release the handle, your problem is inside the gun. If the needle tip or seat are damaged or the spring that holds them closed is broken, paint will be able to get past the the needle and will come out of the gun even when the handle isn't held open. The stock spray gun that comes with the the XR5 doesn't have any servicable parts inside it so if it isn't working properly it may be garbage fodder. If you have an aftermarket gun, rebuild kits may be available.
Jun 13, 2012 | GRACO INC Magnum Xr5
Weee killer leaks from my Gilmour sprayer finger
Im pretty sure that is all it is. The pressure is by how many times you pump it up. Its just on or off. Sounds like It needs to be cleaned real good, and put soap in it befor you put it bak together. Also there is a screen if you hold the handle and turn the trigger part and unscrew it.
May 10, 2010 | Gilmour 1 Gallon Lawn & Garden Spray Tank...
I purchased the Wagner power tex and loved it, recently it doesn?t spray with the ease as it did when I bought, I haven?t used it a lot only to do fill in?s, seems like it only releases the texture once...
Your sprayer is self powered? you don't use a separate compressor? I have one with a compressor and it has to be taken apart " the gun" everytime or the trigger becomes stiff. If it's self powered, I would say your mixture is too stiff and water and it should be fine..If not and if it's self powered, then your motor may not work properly.
Mar 17, 2010 | Wagner Power Tex Texture Sprayer #0520000
I have a ortho tree & shrub spray-ette hose end sprayer. The instructions say to add product and fill to gallon mark, then attach to hose and turn on water and spray. It isn't plugged the water comes...
sound like the inside suction hose is loose or not fitting correctly. i had a similar problem and wrapped some duct tape around the tube then snugly fit it inside the cap. no outside air suction and it works fine. i've had mine going on 15 years and use it constantly.
May 06, 2009 | Ortho Garden
Clogged and can't get the weed killer to pass through the power wand
EASY FIX!
Hold the sprayer lower than the tank and run it until it sprays. You're done. They seem to lose prime, it usually happens to me when I run it completely out and/or first use (almost year round for us). Mine works fine every time I do this.
If that doesn't work, check the filter on the end of the hose in the tank, blow compressed air through it - NOT BY MOUTH!! Also check for any leaks/pinholes/kinks in the hose - they will **** air instead of solution!
I've had mine for 3 seasons in Phoenix and love it! I've n never had any of the other problems I listed personally. Handle the liquids like you handle gas for your lawn mower, etc:
1) Don't let any dirt to get in the solution.
2) Wash the system before storage ESPECIALLY AT END OF SEASON by spraying clean water through It for a couple of minutes or so and rinsing the tank. STORE INSIDE FOR THE WINTER if it freezes, it may trash it. Leaving anything stronger than Roundup (TM) in it for more than a week or so may eventually damage the plastics and/or seize the pump too.
Apr 30, 2009 | Cepia "" Hands Free Power Sprayer
Hello, We purchased a FIMCO sprayer last year, used it twice and stored it indoors. Now the motor will not work. My husband tested it with his meter and power is getting to the motor and past the...
Pull the side cover off the pump of there will be small shaft, turn the shaft it will free it up. You need to make sure that the pump is cleaned out after each use, you can get a cleaning material that you want to run through the hole system, relief valve, spray nozzle etc. it will lubicate everything up. If you did not clean it out it will seeze and you will needs to be freed, chemical will freeze the moto.
Apr 27, 2009 | Garden
Sprayers Will not work.
so what is the problem fills but wont spray
Dec 10, 2008 | Maytag MDB9600A Jetclean II Built-in...
Campbell Hausfeld 1,350 Psi Electric Pressure Washer With Auto Detail Kit #PW1350 Logo
89 people viewed this question
Top Campbell Hausfeld Garden Experts
John Trevino
Tim Venetis
Steve
Are you a Campbell Hausfeld Garden Expert? Answer questions, earn points and help others
