Question about Garden
Starter buzzing the starter makes a buzzing noise and will not crank
5 Suggested Answers
  • 1122 Answers
SOURCE: Dryer makes buzzing noise but will not run.
that is the sign of a bad dryer motor-sorry-mike
Posted on May 08, 2009
  • 1779 Answers
SOURCE: 1966 mustang wont crank every time, but makes a
Check the solenoid which I believe is mounted on the passenger side fender, near the battery. It should have connections for 4 wires on it, 2 mounting bolts, about $15- $20 part, easy to replace. Let me know how you make out.
Posted on Jul 29, 2009
snowghost1
  • 784 Answers
SOURCE: 1993 mbz 300e won't turn over, battery full charge and buzzing noise from relay area.
hi,
the first thing that I would check is to make sure your battery is fully charged or try and jump the battery using another car battery.
if still no go then I would say that your starter solenoid is bad.
while checking the solenoid/starter double check to make sure your block to body ground cable is secure.
hope this helps,
chris...
Posted on Sep 27, 2012
  • 161 Answers
SOURCE: starter wont crank
You have to check if starter solenoid is getting 12 volts when you turn the key. If it is then the solenoid is bad. If no volts could be fuse, wire problem or ignition switch faulty.
Posted on Jan 23, 2014
My 96 jeep grand Cherokee v6 was running fine then all of a sudden won't turn over, and there's a buzzing noise coming from inside somewhere.
buzzing noise how long does it last? about two to 3 seconds is just the fuel pump which is normal. could be the starter. starter the lights will come on but no crank. dead battery nothing comes on just loud clicks.
Dec 09, 2015 | Jeep Cars & Trucks
Having a no crank no start so click issue in a 1994 murcery tracer. Need help please.
Do you get a clicking noise or a buzzing noise.
If its a clicking noise then it a power problem (battery, cables)
If it a buzzing noise -- need new solenoid (between battery and starter).
Jul 13, 2014 | 1994 Mercury Tracer
2001 Chevrolet Malibu cranks but will not start and is also draining my battery have checked the fuses and filters and battery so far nothing can anyone help me?
the motor is cranking. that tells us you have a good starter and battery. now we need to see if the fuel pump works and if you have spark. what you need to do is turn the key to the start position and see if you hear a buzzing noise from the gas tank. if you hear a buzzing noise the pump is good. have to see if you have spark. is the check engine light on
Feb 07, 2013 | 2001 Chevrolet Malibu
Buzzing noise when starting
old post
post it wont crank
or
it cranks fast but will not start.
Jan 30, 2013 | 1996 Geo Prizm
hi,
hope this helps,
chris...
Sep 26, 2012 | Cars & Trucks
Efi makes buzzing noise
glad you solved the problem
Jul 30, 2012 | 1989 Toyota Camry
Starting / Cranking is a problem: With key ignition, turn; there's a slient buzz noise. Head lights and dash board lights come on, however it doesn't respond to crank. Weak response is battery sometimes...
This could be a battery thats bad and doesnt have enough voltage or the starter is bad, easy to figure out, have the battery tested if its bad then replace it but if it tests good then i would replace the starter and also have the charging system checked to make sure the alternater is charging the battery up. hope this is helpful.
Nov 08, 2010 | 1997 Saturn SL
1966 mustang wont crank every time, but makes a buzzing noise when turning the key. Sometimes it will crank and then buzz. I replaced the starter, but apparently that wasn't the problem.
Jul 29, 2009 | Ford Mustang Cars & Trucks
May 08, 2009 | Dryers
Garden Logo
14 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
