Question about Suzuki Home Digital Piano Dark Rosewood (r21)
Suzuki 275e Digital Piano fuse replacement - Suzuki Home Digital Piano Dark Rosewood (r21)
I have a Technics PR-305 Digital Piano with very dim screen on it. I had it repaired when My digital piano blew and made a humming noise, but now it works I learned that they had parts for it.
You most likely just need a new backlight rather than the whole display. Most any competent repair guy can do the replacement or you can do it yourself if you're a good solderer. Get the backlight here-
http://www.telesisgear.com/id16.html
Aug 04, 2015 | Music
Sustain pedal does not work on brand new Suzuki mini grand digital piano..... who fixes it
I have this same issue on my Suzuki S-350 Mini Digital Grande I got in Feb 2012 and I still have never fixed it. I'm still searching the internet for an answer. I figured if I could use the middle programmable pedal, that would suffice. But I've never figured out how to program the pedal! I've searched the menus and I can't find it anywhere! Even the manual doesn't show where this supposed menu is.
Oct 18, 2013 | Suzuki Promaster Harmonica, Key of A
Suzuki ss-100 piano keys stick, won't play
I had an issue with my Suzuki GP-3 and I did a research and found a company called VMI Electronics (619)244-0006 they found me a technician in my area also there is a repair kit called Key Mod that fixes issues with the keys hanging low, here is the link to order it on ebay: http://www.ebay.com/itm/Key-Mod-Piano-Rod-Replacement-Kit-/190822310728?pt=LH_DefaultDomain_0&hash=item2c6de56348
Mar 28, 2013 | Music
I have a Casio digital piano and some keys stopped working after my daughter finished "cleaning" the piano. I'm thinking maybe a fuse needs to be replaced?? Some keys plays and some do not. Any
Old reply so hopefully it's fixed. Dust or hair can get through the gaps and land on or near the contacts of the electronic key sensors. To be on the safe side (rather than doing a diy) take it in to the technicians. They'll have it fixed in a jiffy
Feb 25, 2013 | Casio Privia Px-130 Px130 88 Key Digital...
Suzuki HG425E All the contacts for the keys are in bad condition and need to be replaced. Where can I buy such assemblies?
The contacts probably just need cleaning. Often they are conductive rubber "pills" in silicon domes that the key presses down against a circuit board under the keys. Clean the pills AND the circuit traces they press down on with ONLY 99% isoprophyl alcohol and Qtips. Be gentle in cleaning. Most of the work is accessing the contacts. Note these contacts do NOT for a low resistance contact as the electronics doesn't need a good contact. There are two per key to implement sensing key velocity. Sometimes the contacts are coencentric with a pill inside a ring of conductive rubber. The conductive rubber is always black.
Apr 21, 2011 | Suzuki S350 Mini Grande Digital Piano...
I have a Suzuki HP-97 electronic piano and the keys stick. What should I do to get them unstuck?
I called VMI Electronics and they sold me a repair kit called Key Mod, you can reach the company at: (619)244-0006 you can also orderer the repair kti through ebay: http://www.ebay.com/itm/Key-Mod-Piano-Rod-Replacement-Kit-/190822310728?pt=LH_DefaultDomain_0&hash=item2c6de56348
Jan 08, 2011 | Suzuki Music
Kurzweil digital piano unpredictable voices and volume
The contacts of various switches and keys are likely dirty. They are often conductive rubber and need cleaning with 99% isoprophly alcohol and q-tip. Clean both the conductive rubber pill and th circuit board traces they contact.
Sep 17, 2009 | Yamaha NP 30 76 Key Lightweight Digital...
The 'feet' my piano stands on broke during a move
Try www.yamaha24x7.com/yamahaoms/
Jun 20, 2009 | Music
Suzuki Home Digital Piano Dark Rosewood (r21) Logo
46 people viewed this question
Top Suzuki Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Suzuki Music Expert? Answer questions, earn points and help others
