Question about Benchmark 11065 Popcorn Maker
Kettle does not heat up
All lights and switches operate normally. kettle stirrer also works, but kettle does not get hot... is there a fuse that i could replace or something?
Re: kettle does not heat up
Just had the same problem. One of the thermostats is probably bad. In my case I replaced both and the heating elements because it was more cost effective. Aside from the drive motor not much else can go wrong. In my case it was worth the $200.00 to replace these items instead of $825.00 for a new kettle.
Posted on Oct 04, 2012
  • 22 Answers
Yes the coil that heats up needs to be replaced....
Posted on Nov 17, 2007
0 characters
3 Points
Why is my gold medal popcorn model # 2552 machine not heating to pop popcorn anymore?
A kettle not heating is either a switch, kettle wires, thermostat, or kettle heater.
Check that the kettle is plugged in tight, notice if the switch lights up when switched, then contact your local gold medal dealer for repairs. It is always cheaper to repair a gold medal kettle than replace.
Oct 01, 2014 | Gold Medal Popcorn Makers
Popcorn maker worked great for a matinee then for the evening show the kettle no longer heated up
Your kettle has had a ground fault, and damaged the switch in the process. Do not Continue to Try and use.
Take the kettle to a gold medal dealer, and replace the switch in the cabinet.
Jul 20, 2014 | Gold Medal 2003 Whiz Bang Popcorn Maker
Will thermostat stop kettle from overheating and blowing thermal fuse
The thermostat built into the kettle stops the kettle from heating at a prescribed temperature. usually around 425 F. This is hot enough to smoke and cause instant burns, but is the required temp for popping popcorn.
I do not know of a "thermal fuse" built into popcorn machines. Mechanical thermo stats are not flawless. they can and do malfunction, either too cold or too hot. the model popper you have is not adjustable, or repairable.
If you are tripping a electrical circuit breaker that is a different problem not related to kettle heat. It is a symptom of an overloading problem of your outlet, or a ground fault in the popcorn popper.
Jan 09, 2014 | Nostalgia Electrics KPM-508 Popcorn Maker
Gold medal 2404 won't heat
Double check that the kettle is plugged into cabinet.
Does the Switch light up? if not it is the switch is bad.
If it does, than either it is the kettle lead wires, or themostat, or the heat element that is bad. In that order.
Oct 06, 2012 | Gold Medal 2404 Funpop Popcorn Maker
I have an econopop 14 and the stirrer gears jump erratickly and dont turn the stirrer when popcorn is put into the pot . everything seems to turn free . What would you suggest doing ?
This is a really old question, but.
Check to verify that the needle bearing is not missing. I is a small round part above the gear on the agitator shaft. Also see how worn the crossbar bushing is. There should only be a minimum of loose play in the shaft moving it side to side.
Make sure the lid assembly is not installed backwards on the kettle casting. The lip part of the kettle is the front or left side, and the cord should come out of the bottom towards the doors/operator side.
Jul 27, 2012 | Gold Medal 2121 Econo Popcorn Maker
Popcorn sticking in the kettle
Make sure you use CORRECT oil and amount and that STIRRER is moving.
Aug 31, 2009 | Paragon Thrifty Pop 4 oz - Domestic with...
The kettle will not get hot! The light comes on and the #1 and #3 switch both light up, but no heat!?!?!
We disassembled the kettle and noticed that the black wire had been disconnected from the base connector which is attached to the heating element. We re-attached the wire clip to the harness and it heated up on the first try. Please note that you may need to crimp the wire connector to the base for a stronger hold. My guess is that as we were moving the unit back and forth the wire connector had seperated.
Aug 11, 2009 | Maximatic Deluxe Popcorn Trolley Popcorn...
The washer that holds the stirrer. has pins
Sounds like you need a new kettle. You can purchase one for $40 from Nostalgia Products by calling 920-347-9122.
Jul 10, 2009 | Nostalgia Electrics CCP-509 Popcorn Maker
Motor turns but gears seam to be slipping
I would look for screw that has loose up and that's proablly why the stirrer will not turn.
Mar 21, 2009 | Nostalgia Electrics CCP-509 Popcorn Maker
School concession popcorn machine
There are many ways that this could have caused your problem! Too much popcorn kernels put into bucket!....somthing in the bucket that is causing it too stick! (I would never put salt or any other seasoning in the maker untill popcorn has dropped) anso the heat from the maker itself can cause warping of the metal parts inside over time! I cant tell you what parts to order because i dont know the model number,But If you have all the pats somone of little skill should be able to fix it for you by bending it back into place and putting it back together and trying it! If not come back with the model # and we can help with the parts!
Please rate my response
Jan 14, 2009 | Gold Medal 2003 Whiz Bang Popcorn Maker
Benchmark 11065 Popcorn Maker Logo
991 people viewed this question
Top Benchmark Popcorn Makers Experts
Richard Roth
Richard Roth
Are you a Benchmark Popcorn Maker Expert? Answer questions, earn points and help others
