Question about Ricoh Office Equipment & Supplies
Printer prints portrait landscape setting
Printer reduces image to fit half sheet, whether letter or larger format. cant get landscape to print full sheet
    Novelist:
  • 140 Answers
Are you confirming the settings in both the PC/User settings and the defaults on the Ricoh device? The printer will normally only follow the commands given by the user/PC. If somehow the properties or page settings are set for 2 images to a page, it will produce such results.
Posted on Jan 18, 2016
HOW DO I CHANGE BETWEEN LANDSCAPE/PORTRAIT?
most printers do not have an automatic preference but a requirement to set it prior to printing
at the print stage go to properties , select the landscape or portrait button and apply
that makes it a default setting for all future printing
Nov 09, 2017 | PRINTER Office Equipment & Supplies
How to copy legal to letter on copystar CS 4005i
Make sure your default settings are for AUTO paper selection and 100% magnification to start. That is the most common default settings. Then, under "Zoom" change to AUTO magnification and under PAPER SELECTION specify Letter (either landscape or portrait). Now when you copy a legal original (8.5" x 14") it will be reduced at 78% to fit it on an 11" sheet. An alternative is to use "X-Y" zoom. Now you can stipulate 78% for the "X" dimension and leave the "Y" dimension at 100%. You will want letter size paper to be feeding lengthwise (portrait). Now you can copy legals and the image is reduced top-to-bottom only, leaving it much more readable.
Mar 16, 2015 | Copystar Office Equipment & Supplies
Only half the picture is printing?
The printer may be runnung out of ink or requires alligment adjustments to fit into the printing paper. select portrait or landscape printign formats to fit pictures. esle, attempt to print small size pictures instead.
Jan 29, 2011 | Kodak EASYSHARE Plus Series 3 Thermal...
At college we have a w7200, how can we print across the paper rather than down it, for example a panoramic image across the width of the paper and say 20cm high
Try selecting LANDSCAPE as opposed to PORTRAIT by using the proper print menu in your application rather than the simple print icon from most tool-bars.
You can usually find it in the FILE menus
Apr 20, 2010 | Canon imagePROGRAF W7200 InkJet Printer
Will not print landscape.
Set your file up as a landscape, set your printer as portrait. Setup you width and height to be a half inch larger in each direction (unless you are doing borderless) and try with preview (so you dont waste time, ink & paper) see if this helps
Apr 27, 2009 | Epson Stylus Pro 9800 InkJet Printer
PDF files only print in landscape
Found it! The problem was that Adobe was set to print with page scaling set to Tile. Even though you see the preview as portrait (with page setup AND printer setup also in portrait), for Tile, it prints in landscape.
User said this fixed it.
Mar 25, 2009 | Adobe Acrobat® 8.0 Standard Full Version...
HP Color laserjet 4700 is printing in landscape
check paper settings in paper handling to set
at plain paper/ letter. or reset factory defaults.
check paper size on tray if app, set to standard or
letter ,not custom
do cold reset . must reinstall network info afterwards.
Jan 20, 2009 | HP LaserJet color laser printer
Printing on half-sheets
adjust your image to landsape and choose the paper orientation as portrait in printer properties and also choose fit to a page.
Oct 24, 2008 | HP Officejet Pro L7680 All-In-One Printer
Epson Rx420
Click Start - Printers and faxes
Right click on the printer icon and select properties.
Click on Advanced tab. Enable the option print directly to printer.
Click apply n OK.
Check for the result.
Dec 22, 2007 | Epson Stylus 1400 InkJet Photo Printer
268 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
