Question about Jarden Home Environment Borg Digital Bath Scale - BDL928KD-53
Need instructions for BDM161KD-53
Replaced batteries but still will not register weight and comes up with E
My conair model th300 is giving me a reading of 288.8 then it goes to err.
I was thinking there were too reasons for this, but I can't find the specs on this scale. One reason may be that its upper weight has been exceeded, but I think that is unlikely. My other thought is that the battery is failing. It is enough to make it come one, and to register your weight, but not enough to continually display it. The instructions indicate it has a 3 volt lithium battery in a compartment in the back.
http://www.google.ca/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=0ahUKEwjintjyt97RAhVU1mMKHdGnCQQQFghCMAY&url=http%3A%2F%2Fwww.conairscales.com%2Fcatalog.php%3Fproduct_id%3D428%26ib%3Den&usg=AFQjCNEp2iyMiCxDasXeoxeI_3r1no7RTA
Jan 25, 2017 | Conair Health & Beauty
Just replaced battery - trying to reset the scale to 0.0
PDF]Instructions for use of ThinnerĀ® Bathroom Scales
www.conairscales.com/catalog.php?product_id=428&ib=en
Scales for the way you liveĀ® ... Tap on the scale and wait until "0.0" appears; press Set button, ... button to change the goal weight if necessary, once the ... NOTE: 1. When the scale traps zero error, "Err" will show. Please try again. 2.
How to Set a Digital Health O Meter Scale to 0.0 - Livestrong ...
www.livestrong.com > Weight Management
Aug 12, 2015 - The scale may not register at 0.0 when starting out... ... The Differences Between Balance Beam Scales & Electronic Scales ... 10 High-Tech Health Tools toTry This Year; Are You in Need of a Digital Detox? How to Start Doing Parkour. References. Healthometer.com: FAQs; "Health o meter User Manual" .
Jan 05, 2016 | Health & Beauty
Need proof of gross combination weight to register in PA
Take it to a weight scale. The scales can be found at truck stops and are called CAT scales. They are used to weight 18 wheelers and other equipment and give a certified printed ticket that will show the gross weight and axle weights. The truck stop will be able to provide instructions on use.
Dec 30, 2015 | Cars & Trucks
I replaced the batteries and followed the instruction.
You need to initialise the weighing process by tapping your foot on to the scale to start it...but wait for it to zero...then step on it.
Jul 02, 2015 | Taylor 7404 Ultra Thin Lithium Scale with...
Need to reset the weight on the conair th300m. already replaced the battery
Actual weight is detected by a pressure transducer which may have failed. The constantly changing readout indicates there may be a problem with the internal circuitry.
Jun 16, 2014 | Weight Watchers Glass Electronic Scale
Weight does not register
The scale is low on battery. That's the most likely answer.
Dec 05, 2013 | Ohaus ES50R ES Low-Profile Bench Scale
Have had the BS 365 scale for 6 years and love it. However, it has stopped giving accurate data and instead registers different weights that fluctuate and are much lower than accurate. Would love to...
Not sure if you knew this but you can change the batteries. I had the same problem and had forgotten to change the batteries. However, the weights may still fluctuate because you need to reprogram the settings. Unfortunately, i do not remember ever having an instruction manual...
Jan 16, 2011 | Rowenta BS 350 Ultra Slim Bathroom Scale...
Negative weight on Salter Stainless Steel Kitchen Scale
make sure the battery your getting is a good one longlastig and if that doesnt work then how nout the motor
Aug 21, 2009 | Salter 2001 electronic kitchen scale
I have a Tanita scale. It will not register weight.
Sounds like somehow it was calibrated to your weight as zero instead of 0. I would contact manufacturer here is the contact info.
http://www.tanita.com/en/contact-us/
Mar 16, 2009 | Health & Beauty
Jarden Home Environment Borg Digital Bath Scale - BDL928KD-53 Logo
107 people viewed this question
Top Jarden Home Environment Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you a Jarden Home Environment Exercise and Fitnes Expert? Answer questions, earn points and help others
