Question about Whirlpool Calypso GVW9959K Top Load Washer
Clothes wrapping around agitator Maytag washer
  • 130 Answers
SOURCE: Clothes mover of whirlpool top-loading washer is loose. Agitates.
You need to replace the agitator dogs inside the clothes mover (agitator). take of the top then the cover, remove th bolt and take the top half off. you should see four "dogs" that need to be replaced.
Posted on Jan 26, 2009
  • 20 Answers
SOURCE: Clothes are wrapping tightly around agitator and slows it down.
is the agitator broken are they getting caught on an edge? are you using enough water? the machine is suposed to agitate even tho the lid may be open, it will not spin.use soap...
Posted on Feb 13, 2009
TheMobilian
  • 8220 Answers
SOURCE: maytag washer wont agitate
Well if it does it in all cycles you can rule out the timer. I would say the agitator is maybe striped out.
Posted on Jun 09, 2009
  • 49 Answers
SOURCE: Clothes wrapping under agitator
Somewhat inherent in this design. You can try to carefully unwrap the clothes by gently rocking them back and forth to see if you can release them, or gently spin the drum while you tug (not too hard!) on the stuck clothes. The wash plate seal might be compromised, but if you start taking the inner workings apart you have to replace the gasket set. I have not tackled this on my unit yet though I have replaced the old pump motor with the improved one (single piece instead of 2 pieces), and I have gotten adept at taking the unit apart from the bottom to remove draw strings which get sucked into the pump impeller, jamming or clogging it. The wash plate seal might be getting old - I think mine probably needs to be replaced but doing that will require more extensive repairs than just putting in a new seal. The service manual warns several times about replacing the proper seals, gaskets o-rings and/or grommets if you remove the outer or inner wash plates, to avoid compromising the water tight seals and causing damage to the U-joint assembly that gives the washer its characteristic wash motion.
Posted on Jun 13, 2009
MaMa Jams
  • 94 Answers
SOURCE: Clothes sometimes get under the agitator requiring
Sounds like your agitator is not assembled correctly. It should not have things getting stuck constantly and it should definitely NOT be so easy to remove. Feel around the bottom edge of your agitator. If there is more than a 1/8 - 1/4 inch gap (roughly), it's not being snapped all the way down. Take a towel and fold it to where it is nice and fluffy. Lay it over the top of the cone part of your agitator. Get a hammer and hammer over the towel (as not to damage the agitator top). A rubber mallet could also be used. Tap firmly until you hear a click or until the gap between the agitator and wash tub reach 1/4 -1/8 of an inch. This should solve the problem.
Hope this info was helpful to you. Good Luck!
Posted on Jan 29, 2010
Washer not agitating properly.
Try looking under it as I've had that problem and found it was build up of dust
Jul 11, 2015 | Kenmore Washing Machines
How can I remove clothing wrapped around bottom of agitator?
Try to pull out with pliers or Vice gip. May need to unwind around the agitator.
Jul 27, 2014 | GE GTWN3000MWS Washer
Clothes wrapped around the agitator at end of cycle
Can you describe the problem more better? Does it still agitate properly? Have you checked the balance of the tub? I believe you have a bent agitator shaft.
Mar 13, 2014 | Frigidaire FWSB7800DS Top Load Washer
One piece agitator wraps cloths
When loading the machine, load towels, sheets or jeans with an accordion fold instead of putting the laundry in a circle around the agitator. It helps to put the clothes in at the twelve o'clock position, then six o'clock, then nine o'clock and then three o'clock. Repeat this sequence until the washer is full.
The laundry can circulate much better and get cleaner too.
Feb 08, 2014 | Washing Machines
Kenmore 90 tub spins excessively clockwise during wash cycle.
there should be 2 or 3 springs that hold it, they mite have broke, take off back panel an check.
Jan 04, 2010 | Kenmore 24032\24036 Top Load Washer
My Maytag Ensignia washer is not spinning well. It bangs side to side with even the smallest loads. It seems like something is loose. Is this something I can fix myself or do I need a repair mans help....
Try leveling the washer... If the washer is level, then don't wrap the clothes around the agitator...drop the clothes straight in, on top of each other evenly around the agitator. The Ensignia washer has a Dual action agitator... That means the clothes roll over them selves, instead of moving side to side, as with a traditional agitator. wrapping the clothes around the agitator will cause the load to be un balanced and then cause the "banging" noise... this should take care of the problem...
Jul 31, 2009 | Maytag Ensignia MAV4758AWW Top Load Washer
Agitator making clicking noise when washing clothes; clothes wrapping around agitator
If this a whirlpool brand washer, there are sone parts bad in the agitator it's self. These parts are called dogs and they make the agitator rachet so that the top half only goes one direction. Does this sound like what you are experiencing? If so, let me know and I can assist you further.
Thanks
Vic
May 13, 2009 | Washing Machines
Clothes wrap around agitator and stops the washer
GE spacemaker washing machine . cloths wrap around the agitator . how can i solve this problem .
May 22, 2008 | Washing Machines
Series 70 prob: Recently started wrapping clothes around agitator
some fabrics are known to do that you have on wrong cycle setting there should be a setting for delicates and clothing and blankets and things when loaded to close to agitator will attract each other together so its wise when loading machine load in a circle leveled out till desired fullness away from agitator they shouldnt attract as much
Nov 19, 2006 | Kenmore 24902 Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
91 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
