Question about Planar PL1700 17" Flat Panel LCD Monitor
Big blue box appears in middle of screen - Planar PL1700 17" Flat Panel LCD Monitor
I have small blue dots and a yellow shadow in the middle of my screen
The model indicated uses what is called a Optical Light Engine, it is a very expensive part and likely is your problem---not much else will cause this trouble.
Let me know if you have questions.
Dec 02, 2011 | Sony Grand WEGA KF42WE610 42" Rear...
A small little blue box appear in the middle of my screen with OSD locked and after 10 seconds it changes to OSD unlocked and it doesn't go away!!!
hi,
please browse the following site
I have a RAZ 3, cingular service and at the top, middle of my screen is a ..... Hi, wondering what the the blue blinking icon which what appears to be 2 small white ... I notice it after Ive had my cell off for awhile and turn it back on. ... and at the top of the screen it looks like a little box with an A in it, ...
www.askdavetaylor.com/what_do_all_the_icons_on_my_motorola_razr_v3c_phone_mean.html - Cached - Similar
May 30, 2011 | Office Equipment & Supplies
Having a big yellow spot background in the middle of the picture.
Hi , it seems you are experimenting a light engine problem.Here's how your tv works: http://www.youtube.com/watch?v=ZLLHnQ4y-wo Basically there's 3 LCD chips that create the colors and image by blending together.When these chips start to melt you will get those blue spots, pixilation even vertical lines.You will need to replace the light engine. Have a blessed one!
Apr 09, 2010 | Hitachi 50VS69 50" Projection HDTV
BOW PICTURE AND HUE GREENS REDS AND BLUES LIKE SHADOWS
the tv had intermittant solder connections already but h\they appeared when the tv was moved to hook up the digi-box. The solution could be as simple as resoldering the power convergence amps.
Aug 06, 2009 | Televison & Video
''big black box that appears in the middle of the screen on certain channels''
It's your "closed captioning." Just turn that feature off, and you'll be good to go!
Jun 12, 2009 | Sylvania 6720FDG 20" TV/VCR/DVD
Red,green and blue lines across screen
I f these lines are slightly diagonal and they all showed up at the same time. you probaly have an open resistor in the ABL circuit. since your set is 13 yrs old, I would not put a penny into it.
You might take the front grill cover off and the panel behind it and find the little black box with 6 little controls 3 are for focus 3 are for screen turn the screen ones ever so slightly counter clock wise. the control in the middle is the green screen adjustment. If the green line goes away try the one labeled r for red and b for blue.
Mar 31, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Large Black Box Showing up in middle of screen.
Try and turn off the closed captioning. I had the same problem and it turned out that the closed captioning was on t1 instead of OFF. Hope this helps!!!!
Feb 19, 2009 | Zenith C27A24T 27" TV
Used TV; new to me
type in PT-47WX51 manual in your search bar and there is an online manual from fixya. It will take you through setting up your tv.
Nov 06, 2008 | Panasonic PT-47WX51 47" Rear Projection...
Planar PL1700 17" Flat Panel LCD Monitor Logo
Top Planar Computers & Internet Experts
William Miller
William Miller
Jay Plesset
syspro
Are you a Planar Computer and Internet Expert? Answer questions, earn points and help others
