Question about LG Televison & Video
My LG 47le5400 makes a long beeping sound on startup then the LG logo on the bottom lights up and the power button stays lit but no picture or sound. Is this a power board or main board issue?
    Top Expert:
  • LG Master
  • 74,482 Answers
It is a main board issue. Damaged IC. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magzine" will make surf easy Pull up older posts. Surf the site with patience.
Posted on Apr 18, 2014
SOURCE: JVC HD-527575 problem
We just had the same problem. The Projector lamp is burned out. You can get the lamp at Electrified.com. Their phone # is 800-678-8585
Posted on Oct 22, 2008
talknerdy2me
SOURCE: samsung hc-r5245w no power
Hello Chac c,
The reason that you are getting a 'red light' is because your lamp is burned out. There is a panel on the back of the TV that gives you access to this lamp. You can remove it and check the part# to be sure then replace it. I did a quick search for you just based on the model# which you provided. You can see it here - http://www.nextag.com/serv/main/buyer/OutPDir.jsp?search=samsung+lamp&gg_site=&gg_aid=1295966762
Hope this helps :)
Posted on Mar 17, 2008
MikeNJ1964
  • 398 Answers
SOURCE: wont power up
I have seen that symptom many times. Most likely, the little blue capacitor next to the horizontal output transistor has shorted and popped the main B+ fuse. This is very common in those Hitachi projection sets. These parts should be replaced by a tech familiar with Hitachi projection sets.
Posted on Aug 14, 2007
SOURCE: jvc tv
when both the blue light and red light are blinking it means 1 of 3 things. 1. lamp replacement. This often works everytime for the repair. TIP!!! DO NOT USE ANY OTHER LAMPS OTHER THAN JVC AUTHENTIC LAMPS. ANY OTHERS AND YOU RISK DAMAGING YOUR TV FURTHER. 2. the fans are not working properly or need to be replaced. They need to be cleaned every so often and they will stop working from burn-out if not done so. This repair will cost you less than 100 dollars. 3. The ballasts are defective and need to be replaced. The ballasts themselves run about 150 dollars. I tell you I have fixed this TV more times than I care to count, not to mention the number of lamps I have gone through. The guy at the TV repair place now knows me by name when i come to buy lamps. :(
Posted on Dec 07, 2008
electronick
  • 505 Answers
SOURCE: I have a model HD52W59
A lot of these have bad capacitors in the power board. You can see them look puffy or bulged if you disassemble and look. look for caps that look like this
If they are bad, you just need to replace with similar value caps and the issue should be solved. They should be flat on top, not bulged like the picture. If you have a convergence issue too, this can also be fixed on the same board, let me know if you get to soldering..
you will need a set of TORX bits to open up, make sure you pull the ac power first. Look @ the left side when you get inside for the bad caps, you may need to use a mirror to see back behind the U shaped heat sink (there is a big one behind there that goes bad)..
best of luck, keep in touch
Posted on Aug 16, 2010
How to fix an lg 47LE5400 tv power lights come on but no picture
If it's a led tv and if you have sound and, also, if you can see the picture with a flashlight very near on the screen in the dark, that means your backlight or your inverter circuit that control the backlight are defect. Good luck,
Serge.
May 06, 2016 | LG Televison & Video
LG 47LE5400 LED TV Wont turn on, long beep, what to do?
Dues the set have a blinking red light pattern?
If so, make note of the pattern and call LG Tech support. Or you have power board problem. Find a honest TV Tech.
Oct 30, 2013 | LG Televison & Video
No backlight no sound no picture lg 47le5400
it needs proper trouble shooting, just let me know if you will be the one to do the job.so i can give you other step to trouble shot the tv since it needs proper tools and device then make sure you have the knowledge in electronic repair.
Oct 25, 2012 | LG 47LE5400 47-Inch 1080p 120Hz LED LCD...
The screen will turn on, but after 2 seconds the screen goes black, the power button stays lit, and sound remains. What could this be?
it could be a bad CCFL lamp, inverter, power supply 24vdc output, or a main board problem. The set will need to be properly diagnosed.
Sep 18, 2012 | LG 47LE5400 47 in. TV
Lg 47le5400 size picture to fit the screen
You can fit the picture to the tv screen by clicking the buttons on the receiver. Change the setting to 1080i from 720i. It is going to work like that.
Nov 11, 2010 | LG 47LE5400 47 in. TV
Need to remove the outer cover on a Gateway
If you get power to the controls and you don’t have the startup sound or see the gateway logo when you plug it in, the main board may be bad.
If your picture was pinkish or dark at the top or bottom when it was working then you may have 1 or more of the bulbs failing.
If you have the startup sound and see the gateway logo and the screen just flashes and the power buttons stay lit, then it sounds like probably the inverter may have went.
Take the screws out of the bottom rear edge (these hold the front trim), and the 4 big black ones at the middle of the back that hold the stand bracket.
The trim then unsnaps. {Be aware of the small ribbon to the power button board on the right edge}Start at the bottom and release the trim (pulling up the trim on the screen side usually starts it off), then work your way up each side bottom to top ((a pocket knife or thin putty knife even a credit card, will help release the catches as you work your way up)
Then unsnap the top edge (rocking it while lifting helps)
Disconnect the ribbon at the power button board, (Tiny latch lifts up on a hinge and ribbon slides out)
Once trim is off, remove the 4 corner screws that hold the screen in. Then the screen will lift out with all the guts. You may have to pry up on a corner with a screw driver to get it started.
The inverter is under the medium size metal case.
The power board and main board are under the large cover.
You’ll then have to remove a bunch of screws including the usb board ones and unplug the bulbs and wire to the screen
then the power board and control board is under the center area under the metal cover
Shout if you need more info.
If you email me a good picture of the board , I may be able to get a better idea if it is the inverter from a visual.
Thanks Fran
Oct 09, 2009 | Gateway FPD2485W Television
No picture on my Gateway monitor
If you email me a good picture of the boards to bammbamm@ptd.net , I may be able to get a better idea if it is the inverter from a visual.
Thanks Fran
Aug 14, 2009 | Gateway FPD2485W Television
Televison & Video Logo
89 people viewed this question
Computer Repairing
Computer Repairing
