Question about ASUS Computers & Internet
Laptop will not turn on
My laptop won't come on. I used it last night and when I went to cut it on this morning it wouldn't come on. No lights are working on it. It is a ASUS X502C
    Top Expert:
  • ASUS Master
  • 4,740 Answers
Check your power unit check the fuse in the plug,
Posted on Apr 12, 2015
Kegtapper
  • 94 Answers
SOURCE: Dell B130 won't load up
Finding where the problem is.
Start windows in SAFE MODE
You will see the last file that it hangs at. Usually AGP440.sys
Disabling AGP440.sys
Boot the system - Hold F8 Key
before the METER BAR on the bottom starts
Go to the Recovery Mode -
When it ask for directory <1> should be shown (unless you have multiple boot partitions.
When in the console mode enter
disable AGP440 (or AGP440.sys)
***depends on SP level***
Exit the console and attempt to reboot normally
hope that helps
Posted on Dec 11, 2007
ginko
  • 19396 Answers
SOURCE: WET LAPTOP
Multicolored vertical bands means that the contacts on LCD ribbon cables are still shorting because of liquid or oxide building in consequence of liquid damage.
Also keyboard is probably not working for same reason.
When you get liquid damage you need to remove immediately the battery and the ac charger, and service the laptop, to prevent more damage caused by shorts.
The service is done by a technician, disassembling the laptop and using a cold hairdryer from distance to dry internal parts.
You must ensure the laptop has no liquid inside before starting it.
In your case I can only tell what parts are working:
If you can see the vertical bands and there is no static stain on display caused by liquid penetratrion, then the LCD is working.
You have backlight, therefore the inverter is working.
To connect to external monitor you can try starting the laptop with video cable already connected, It should start on ext. video.
If you are getting video signal on external monitor, that means that the motherboard is still working.
If you also get windows splash screen (or Linux) , then the hard disk is also fine.
If you do not want to spend any money for this laptop you can wait few more days, with battery out, and try starting it, in the meanwhile oxide can cause more internal damage, that is not the right way to proceed.
The laptop should be sent for repair.
If the laptop is less than one year it will still have factory warranty. However, factory warranty does not cover liquid damage.
If you do not mention that there had been liquid damage , they will probably not realize, and cover the repair, but that won't be really fair toward manufacturer.
To do things properly contact manufacturer and explain them what happened , so that you can arrange a repair, if laptop is fair new they will make an effort to keep quote low.
Do not forget to leave feedback.
Thanks
G.
Posted on May 21, 2009
  • 262 Answers
SOURCE: I was using mu Acer Aspire 7720G last night while
either plug in the back of the laptop is shot or you need a new hardrive
Posted on Nov 06, 2009
benwabnick
  • 2404 Answers
SOURCE: New Compaq CQ60 615DX will not turn on
Take out the battery and also take out the memory as well. If the laptop still won't turn on, then the motherboard is bad. If the laptop gives you a beeping sound, then reseat one of the memory sticks to see if you get video. If not then try another memory stick into the other slot. If you still don't get video then you'll know for sure the motherboard is bad.
Posted on Apr 22, 2010
  • 355 Answers
SOURCE: My asus laptop won't turn on and so I have it
may be the wire of the charger has got defect in it. check thoroughly. If your charger is OK it is problem with your motherboard.Replace it to get rid of the problem.
Posted on Feb 08, 2012
My Motorola electrify won't turn on or charge. It
maybe your battery or your phone os .... try a new battery if nothing happens... try re flash your phone
Jun 02, 2013 | Cell Phones
My LG portable AC Model #LP1111WXR wouldn't turn off had to unplug it. Now won't turn on.
Unplugging the unit lets the tiny computer like microprocessor reset--means problem is in the brain of the unit or its power circuit.
Jun 14, 2012 | LG 11,000 BTU PortabAir Conditioner -...
( Dell xps m1530 laptop ) Monitor blank, powers up but screen won't come on.
It ISN'T the LCD screen. Since you diagnosed with an external VGA monitor, you now know the problem is the laptop.
(When you connect an external VGA monitor to a laptop, you are bypassing the Video Cable, and LCD screen. You are connected directly to the laptop )
The basic Windows files aren't being found. The boot files. This may mean a bad Harddrive.
Do you have the Restoration CD Disk? Laptop on insert it into the optical drive tray, close the tray.
When asked choose - Repair. (Non-Destructive Installation)
If a checkdisk is done, you have bad sectors on the harddrive.
There IS a special procedure in replacing a harddrive.
[ More information on Harddrives,
http://computer.howstuffworks.com/hard-disk.htm ]
Regards,
joecoolvette
Feb 26, 2012 | Dell XPS M1530 Laptop
Received for Christmas 2010. Worked great! Few nights ago, made something to eat, and it shut off. Light, clock, everything. After a few minutes, it came back on. Used it last night, same thing. But this...
The joys of purchasing items with a bought out warranty. Check the plug and contacts on the fuse.
You could either call a microwave repairer and pay for callout and repair or purchase a new one.
May 30, 2017 | Oster OGG61403 Microwave Oven
I have a acer laptop last night I turned it on and it was updating and and all of sudden it made anoise like when a light bulb pops and went out now there is now it won;'t come on at all I tried plugging...
I believe your laptop is blown due to power unstability. You should take it the tech department for your laptop to be checked ok.
I hope this solution has been helpful.
Sep 27, 2010 | Acer Audio Players & Recorders
Dell inspiron 1525 won't turn on
Try to take out the battery and just use the adapter to power it on,
If your done with that then try just using the battery to turn it on, if it still won't give a single light.
If you can borrow an ac adapter for that laptop try it ,
If it still doesn't work. You'll need to replace the motherboard. Just make sure the ac adapter your gonna use is working good.
Feb 12, 2010 | Dell Inspiron 1525 Laptop
Laptop was working fine, suddenly went totally black.
the display of ur laptop has got damaged....if u still have doubt that it might be some software problem try formatting ur system.. Or else u should go for a change of display screen
Feb 02, 2009 | Toshiba Satelite A135-S4467 Notebook
Archos 404 not charging
Dont use the USB to charge the 404. Use a wall charger that accepts USB. Wally world (Walmart) has one for 15 dollars that has 2 USB ports. It works for me. Also the docking station will charge the 404 in no time at all. It's 80 dollars. Make sure you get the generation 4 unit
Apr 25, 2008 | Archos 404 Digital Media Player
Computers & Internet Logo
87 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
