Question about Wacom Intuos4 PTK440 Graphic Tablet
Wacom Intuos4 PTK440 drivers - Wacom Intuos4 PTK440 Graphic Tablet
Why does my intuos tablet not respond
Can you set back an older version of XP? with restore under the configuration tab?
If possible one from before you installed your driver.
Take care with XP, because "bad" guys try to get access to any XP computer, not in the last place by offering drivers you don't need.
Nov 21, 2014 | Wacom Intuos4 PTK640 Graphic Tablet
My eraser is bugging out
I'd guess your memory is filling up. Try setting your undo levels to really low, like 1 or 2, and see if that helps.
Apr 10, 2017 | Wacom Intuos4 PTK640 Graphic Tablet
Wacom Pen Pressure issues
Try hitting the pen head into your hand 5 times. Do the same with the eraser ( do it pretty hard but not too hard. I hurt my hand with the pen tip a LITTLE so you can gauge it by that). The humidity in the air causes the pen pressure to stick apparently. I had the same problem and this made it work. You should try and clean it too but if you don't want to take the pen apart this is the way to go. i hope this helps.
Mar 28, 2010 | Wacom (PTZ930AC) Graphic Tablet
Wacom tablet (Model ET-0405-U) Driver?
Wacom tablet drivers can be found at: Driver Update Software for XP Vista 7 8. Used it many times before. have a nice day
Oct 03, 2009 | Wacom Graphire Grape (ET0405UGRAPE)...
Pen doesn't work
It could be the drivers problem which does not support operating system. Please visit the vendor web site and get the drivers for 64 bit OS.
Aug 05, 2009 | Wacom (PTZ930AC) Graphic Tablet
Wacom Tablet
did anyone find that driver for the mac. Sketchboard DS-SB20G
Aug 08, 2008 | Wacom Graphire 4 "Silver" 4x5 (WMM132369)
Initial Delay of tablet pen
I had a similar problem with Vista which made the pen/cursor freeze just as the tip was placed on the tablet face.
The problem turned out to be a Vista setting.
I went to Start > Control Panel > Pen and Input Devices.
Then in the Pen Options tab highlight the "Press and Hold" pen action and then press the "Settings..." button. In the dialog box that opens uncheck the "Enable press and hold for right-clicking" check box. Hit "OK".
Worked for me.
Feb 02, 2008 | Wacom Intuos3 Graphic Tablet
Serial to usb wacom tablet problem
I just got Vista and it killed my Intuos2 w/serial to usb also, but here's a half solution:
Download Wacom driver 4.78-6 http://www.wacom-europe.com/int/downloads/driver/driver.asp?lang=en. Make sure you remove any other Wacom drivers, tablet, and reboot. Install 4.78-6 driver and select serial port when the choice pops up. Plug in your tablet with the serial to usb adapter, wait a few seconds and click retry. Complete the install and reboot.
Your Wacom tracking should work now, but certain things might not work like pressure sensitivity and you'll get annoying error "reinstall driver" pop-ups.
I think you can aslo buy a PCI-serial card for your computer and skip the serial-usb adapter since Vista doesn't support the adapter for Wacom tablets.. but I'm not sure if there's a working Vista serial Wacom driver either.. or ever will be. The age of XP and Legacy support is at an end my friends.
Dec 03, 2007 | Wacom (PTZ930AC) Graphic Tablet
Wacom Intuos4 PTK440 Graphic Tablet Logo
144 people viewed this question
Top Wacom Computers & Internet Experts
toddmat
Level 1 Expert
jasbo
jasbo
William F. Bryant Jr
Level 1 Expert
Are you a Wacom Computer and Internet Expert? Answer questions, earn points and help others
