Question about Hayward Pool & Spa
Lay z spa 54075 not heating or pumping water - Hayward Pool & Spa
    Top Expert:
  • Hayward Master
  • 5,056 Answers
Replace recirculation pump
Posted on Mar 19, 2016
SOURCE: Heater will only heat spa water to luke warm.
the water in my arctic spa hot tub took 2 weeks to get to 102 should it take that long ?
Posted on May 02, 2009
SOURCE: SPA Filter on while Spa is Heating
you have one jandy valve ( the suction valve in front of the pump) that is not working right when you press spa mode. have someone watch the valves to see if they move when you press spa mode and heat inside the house. if the one in front of the pump does not move and the switch is in operating mode then that valve is bad and will have to be replaced.
Posted on Aug 06, 2009
  • 990 Answers
SOURCE: I have an aqualink rs
If the Aqualink is calling for heat then the problem is most likley in the heater. Without more information I can't tell you much more but if nothing has changed in the last couple of days. Before you call anyone be sure to clean your filter and baskets. The heater need a set amount of pressure to run and if things are dirty it won't get that pressure. Good luck.
Posted on Mar 13, 2010
Testimonial: "The burner is lighting but won't stay on, more than a minute or so. I tend to think the problem is water flow, like you say. Thanks...DC"
  • 3 Answers
SOURCE: where can i buy a replacement heating element for ...
I got a new heating element off eBay, it was just a double straight line one like the one already in the metal tube (in the pump). It fit, i wired it up and it works!!
Posted on Jun 12, 2010
Coastsider
  • 331 Answers
SOURCE: water is pouring out the
It is possibly coming from the heat exchanger. Most heaters have a copper tube style exchanger, capped at each end by plastic or metal headers. If the tubing has been subjected to any corrosive water condition such as low PH, low calcium hardness or very high cyanuric acid levels, the tubing may have deteriorated and is leaking. You may have dismantle the heater further and check for leaking.
Posted on Sep 10, 2010
My coleman lay-z spa pump is making an intermittent loud sound. All filters are new and spa is clean. What to do?
Could be your motor, bearings going bad or whatnot, pump flow being restricted, bad impeller, or the heater. If it sounds like metal its motor, water noise is the pump flow, and heater is other? I've heard banging and cracks from heater water heating too much and not enough flow. No mater what it is call and see if you warranty is good still.
Dec 11, 2015 | Pool & Spa
Why is my lay z spa not heating?
if the heat light comes on but doesnt heat bad heater element if red heat light doesnt come on need new temp sensor
Aug 31, 2014 | Pool & Spa
Lay-Z-Spa pump impeller replacement
In order to find the proper replacement you will need to provide someone with the following information.
  • amps
  • voltage
  • discharge size pipe
  • suction size pipe
Rod
US Parts Center
Jun 01, 2013 | Home
Lay z spa pump impeller replacement
Perhaps an inquiry of Lay Z Spa will yield an answer
Jun 01, 2013 | Home
Lay z spa pump has E02 code which is water flow problem,have changed filter.flushed through ,set reset button but fault code still appears.
If this is an outdoor spa near trees, its almost a guarantee that the impeller is blocked with debris (pine needles can cause this in a hurry)
If the impeller is clean of debris and this is still happening, replace you pressure/flow switch.
Apr 27, 2011 | Pool & Spa
Water is pouring out the bottom vent of the lay z spa heater have taken apart but cannot find where the water is coming from it only seems to do this when the pump is on
Sep 05, 2010 | Pool & Spa
We have refiled our lay z sap, after it dispaly shows 3 dashes
You probally just need to break an air lock in the pipes. You can ether force water down the skimmer pipe or find your drain valve and open it for a minute or two till it runs just water and no air. This will get water to the pump and the heater. This should fix you up.
Aug 02, 2010 | Pool & Spa
Lay z spa water pump is faulty where can I get a
Hi Im Chris From BVL Elecric,
I cover Bournemouth and surrounding areas and supply solutions to most home electrical problems.
A lovely lady customer called me out today to diagnose faulty
LAY-Z-SPA
pump/heater that kept tripping the RCD.
After scouring the net and finding this same problem over and over again but no solution,I decided to get personal with the blighter!!!
RESULT:- problem solved,
Customer very happy,
no new parts fitted,
water heating fine now.
If you live in my coverage area,have a LAY-Z-SPA that is faulty,no or limited warranty then give me a ring and I will be only to happy to come on over and fix it for a small fee.
just think that dead spa/pool heater/pump could be heating your water again tomorrow and there is plenty of summer left to enjoy it.
You can find my details quite easily , just google BVL Electric Bournemouth
Dec 27, 2009 | Pool & Spa
Just got a lay-z-spa, series II spa ...which works fine, but would like to increase the temp. Any suggestions?
It is dangerous to run your heat past 104 and by law cannot go past 106. If you want go past these I can't help. Other than that ck your heat sensor or thermostat.
Dec 02, 2009 | Pool & Spa
Pool & Spa Logo
80 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
