Question about Acer Aspire L100 PC Desktop
Replacing acer l100 fuse - Acer Aspire L100 PC Desktop
I reset my surge protector and the computer wont power up. i think i need a new power supply. the power cord is working fine. Please let me know where i can find a power supply for the aspire...
The Acer Aspire L100 is a desktop computer powered by a special DC adapter and power cable. The computer's motherboard incorporates a fuse designed to prevent any power surges from damaging the computer. If the fuse burns out due to a power surge or for any other reason, the computer will no longer function. You can check the motherboard fuse for damage yourself, then take it to a trained technician for replacement if needed
Shut down the Acer Aspire L100 and turn the tower around.
Press the "On/Off" button on the front of the tower. If the computer will not boot and the fan does not turn on, the fuse may be burned out.
Unplug the power cord from the rear of the tower
Turn the tower on its side and remove the Phillips-head screws connecting the back panel to the Aspire L100's cabinet.
Pull out the motherboard assembly gently from the back of the cabinet. The internal fuse is located on the motherboard behind the DC power jack, which is to the right of the monitor jack
Let me know if this helped..
  • 2 Press the "On/Off" button on the front of the tower. If the computer will not boot and the fan does not turn on, the fuse may be burned out.
  • 3 Unplug the power cord from the rear of the tower.
  • 4 Turn the tower on its side and remove the Phillips-head screws connecting the back panel to the Aspire L100's cabinet.
  • 5 Pull out the motherboard assembly gently from the back of the cabinet. The internal fuse is located on the motherboard behind the DC power jack, which is to the right of the monitor jack.
  • Read more: Fuse Location on Acer Aspire L100 ' eHow.co.uk http://www.ehow.co.uk/how_7815704_fuse-location-acer-aspire-l100.html#ixzz1XUVwmxuA
    Sep 09, 2011 | Acer Aspire L100 PC Desktop
    I have a Acer Aspire L100 and would like to restore to factory settings please help
    If you have lost the automatic restore then you need recovery CD to restore it. To download try this link:
    http://www.user-guides.co.uk/cddownload/Acer/AcerAspire/Acer-Aspire-L100-XP-Driver-CD-Recovery-Restore-Disk-115940.html
    Apr 11, 2010 | Acer Aspire L100 PC Desktop
    No power when press the button, power plug is good?
    Good day sir/ma'am, chances are that your power supply box is the faulty part. But to make sure let us test your power supply box. here are the steps:
    1. PC is off, open the side panels of the CPU, disconnect the 20(or 24) pin molex connector from the motherboard.
    2. Get a piece of jumper wire, about 4 inches and splice the ends.
    3. On the molex connector, locate the green wire, then using the jumper wire, short it with the black wire (there are lots of black wires there).
    4. look at the exhaust fan, at this point it should be spinning (good). if not here are the other possible outcome: (1) the fan did not spin. replace the power supply box with a new one. (2) the fan spins momentarily then stops, this condition only occur once. Its either your power supply has no load (intermittent symptoms), or the switching controller stage part is faulty. Better buy a new one than have a headache. (3) blows a fuse. replace the entire box.
    If you have a good power supply, install it on your CPU and test.
    Oct 28, 2009 | Acer Aspire L100 PC Desktop
    Go back to Acer.com. The driver you want is the one that say's (Power 1000 chipset driver) that is if it's an integrated Network card. If it's not integrated then I would need the name on the card. Hope this helps.
    Nov 17, 2008 | Acer Aspire L100 PC Desktop
    Acer L100 Graphics
    The L100 has an onboard graphics card and is not upgradable.
    May 09, 2008 | Acer Aspire L100 PC Desktop
    Acer L100 memory upgrade
    you can open it up and see, take out the ram to see what kind it is
    Dec 24, 2007 | Acer Aspire L100 PC Desktop
    Acer Aspire L100 PC Desktop Logo
    47 people viewed this question
    Mohammed Ebrahim M
    Mohammed Ebrahim M
