Question about Xante Ilumina Digital Color Press Printer
Toning on background - Xante Ilumina Digital Color Press Printer
My Motorola C1211A is gone dead.The blue screen is lit up but no dialling tone.
Josephine
1-888-331-3383
Mon-Fri 7:00AM-7:00PM CST
Or email support@motorolacordless.us
Mark
Motorola Mobility Support
Dec 07, 2014 | Motorola Lands Phones
I keep a dial tone, even when I dial a phone number...can't make an outgoing phone...I keep getting the dial tone. can you please help?
1) make sure is the phone is working good
2) there are tone dial
3) see the steps before o.k see ,if there are another phone having the same problem. The problem is service provider.
4) eliminate any background noise., mute the cordless handset before dialing.
God bless you
Sep 26, 2012 | Lands Phones
I was cleaning my phone and I pressed on something and now there is music playing that i can not stop,I don't know how to stop the music,my phone is panasonic KX-T7730
Here are two methods to turn off background music, one of these should work depending on which Panasonic phone system your phone is connected to.
1) With phone idle, press the 1 key on the dial pad (turns off background music when it is on and turns on background music when it is off).
2) With phone idle, press intercom button then dial *751 on the dial pad followed by 0 on the dial pad to turn off background music(confirmation tone will be heard) and end by lifting handset and replacing in cradle. To turn background music on, press intercom button then dial *751 on the dial pad followed by 1 or 2 on the dial pad to select the background music source(confirmation tone will be heard) and end by lifting handset and replacing in cradle.
Feb 05, 2011 | Panasonic KX-T7730 Corded Phone
Good day I have a Xante Ilumina 502, when i print on 300gsm and up there is a magenta background. How do i solve this
Your settings are incorrect, adjust media type and media weight. This settings adjust the temperature of the fuser. If fuser to cold you will have ghosting and fuser to hot image will stick to fuser.
Mar 31, 2010 | Xante Ilumina® 502 Laser Printer
Problem
in photoshop or MS word just increase the contrast of the image and all dirty gray background will disappear and if u need our technician support contact http://tinyurl.com/mtgjzz
Jun 22, 2009 | Xante CL30 HSE Laser Printer
Degen DE1103 background tone
the background tone is due to frequency static...the design of the stereo is not good... it lack of noise destortion cirquit..and almost all stereo that is analog usually poor in in design..change the stereo.try stereo that is digital in design..
Oct 13, 2008 | Kaito KA1103 SW/FM/AM Radio
'Keypad tones' option unavailable
change profile mode to custom sttings may be u are using the factory defalult profile setting
Dec 04, 2007 | Samsung SGH-D900 Cellular Phone
Help
try using different 12 pt stocks....they are many different kinds of paper
Oct 25, 2007 | Xante Ilumina Digital Color Press Printer
Dialogue vs. background music and sound
The on-screen menu appears only when the selected source is DVD or VCD on the DVD/VCD/CD player and the disc is in the slot and NOT PLAYING. On the remote control ONLY: 1. Press CHOICE (it should work now) LANGUAGE menu appears. 2 Press Cursor to move to the menu you want? which is AUDIO Selected item changes its color to green. THEN: 1. Display EXPERT SPEAKER SETTING menu. 2. Press Cursor to select ?TEST TONE,? then press ENTER. ?TEST TONE? changes its color to green and test tone comes out of in the following sequence?left front speaker, center speaker, right front speaker, right rear speaker, and left rear speaker. ? Test tone is output only when the tray loaded with a DVD is selected, but not playing. 3. Press Cursor to move to ?C.SPK? LEVEL? or ?R.SPK?LEVEL,? then press ENTER. 4. Press Cursor to adjust the output level, then press ENTER. ? You can adjust the output level from ??6 dB? to ?+6 dB.? 5. Repeat steps 3 and 4 to adjust the other speaker output level. 6. Press Cursor to select ?TEST TONE,? then press ENTER. Test tone stops. 7. When finished, press Cursor to move to ?EXIT,? then press ENTER. EXPERT SPEAKER SETTING menu disappears. I hope this helps you, please let us know. Best regards, nightdiver
Jun 13, 2006 | JVC MX-DVA9 Shelf System
Top Xante Office Equipment & Supplies Experts
Ottoniel
Dudeman321
CheckitRight
CheckitRight
Are you a Xante Office Equipment and Supply Expert? Answer questions, earn points and help others
