Question about Pitco Frialator Kitchen Appliances - Others
Pitco fryer ignitor lights the pilot but goes out after we let go
    New Friend:
  • 23 Answers
Are you holding it in long enough? It takes between 20 seconds-1 minute.
If it still doesn't stay lit, replace the thermocouple.
Posted on Apr 05, 2016
bigg t
  • 640 Answers
SOURCE: problems with fryer
your problem is the thermostat is bad.the reason it shuts down is that it trips the hi limit.the hi limit is a saftey device that shuts the system down so the oil doesnt get too hot and catch on fire.remove all the oil from the tank and you should see 2 skinny metal bulbs one is the hi limit bulb the other is the t-stat bulb,make sure they are secured to the bracket.if the t-stat bulb isnt you will also have this issue,simply reattach it.let me know.
Posted on Nov 11, 2007
SOURCE: pitco fryer pilot out
the problem is the thermocouple , and not the gas valve or thermopile
Posted on Feb 12, 2009
SOURCE: comercial deep fryer pilot light goes out
This problem could be caused by a few different things. You should check the condition of your pilot and the thermocouple, if the pilot is weak due to being dirty you will not generate the optimum Millivolts to run the fryer, you may need to dissassemble and clean the pilot. The thermocouple needs to be correctly placed in the pilot assembly, if it has dropped down to where it is not in the flame it will not work correctly. You may need a new thermopile as it may not be generating millivolts as needed. Gas pressure can cause this as well, if the pilot goes out then the main burners come on you should check the gas pressure. One more thing to check is the hi-limit thermostat, if this is cutting out early your pilot will go out. Imperial uses a self-resetting limit, after a few minutes your fryer will relight and work until if cuts out again. If your fryer pilot stay on with the thermostat off for long periods of time and does not go out immediately when the burners come on and the pilot is clean, you may need a hi limit. This is a lot of info, I hope it helps.
Posted on May 26, 2009
  • 86 Answers
SOURCE: high limit kicks out fryer and pilot light can
Since you've mention the pilot light goes out at 400 degree F, then we are talking a gas Deep Fryer. The deepfryer usually use at 350 degree F for chips or else. Because the oil will start breaking down its quantity of frying very quickly over that temperature. Most people set at 350 degree F. Now we comes back to your problem, First you should have a deep fryer thermometer they espcially made for deep fryer, (You only mention 400 or better ) that make me think you're only guessing. Knowing the temperature is very important, most Hi limit is set at 420 degree F.
To me it seen the Hi Ltd control is working and that is why it cutting out the pilot when it reach its limit but we don't know what temperature that when the hi limit cutting out at.
When you have a thermometer, put it in the cold oil and turn the temperature to 100 degree F to see what the temperature control cutting out at. slowly increase your setting until it cutting out at 350 degree F . If you set at 250 degree F and the thermometer already reaching 350 degreen F then don't go any further , your temperature control is defective and need to be change a new one.
This is only the first step, you still have to check out the Hi ltd control to see how good its condition is,so far your information say it cutting out at 400 or better. But you've to be sure, because it is a safety control. Hope that will help you , God Bless.
Posted on Jul 27, 2009
97F350diesel
  • 1326 Answers
SOURCE: I have a Pitco 35C+S
With the thermostat on the burners are still getting gas. that's normal. If it lights with the thermostat off you do have a severe problem. (bad gas valve/Tstat). The pilot does occasionaly go out on all no electronic ignition items is normal. Follow the remommended steps for relighting and if it lights fine your ok.
Posted on Aug 15, 2009
Pilot light goes out after a few minutes it seems t b overheating! It's a pitco freestanding 35C+ gas fryer
Check the oil temp and see when the pilot goes out. Is the thermostat shutting off at the correct temperature ? A low pilot flame could also be causing low millivolts, which can cause a pilot drop out.
Aug 04, 2016 | Kitchen Appliances - Others
Pitco fryer
Hi there!
Try to check first the incoming and running gas pressure, it must comply with the rating on the unit's nameplate.
Regards
Jan 26, 2013 | Pitco Frialator Kitchen Appliances -...
When the pilot light button is released the flame goes out. (pitco propane fryer) - unsure of model number as data plate is worn. Does the thermopile need replacing ?
Try first to clean the thermopile. If it has accumulated soot/ carbon, it will not sense enough heat from the pilot flame to generate small amount of electricity to energize the pilot valve and main valve of gas valve.
May 18, 2011 | Pitco Frialator SG14 Deep Fryer
I have a pitco 35c fryer the pilot light will light but the flame is very low it goes out when i release the controll the pilot light adjustment has no effect on flame i have the right amount of fuel...
Check and clean the thermopile, it is the cylindrical piece of metal standing behind the pilot assembly.Try also to tighten its wiring connections to the gas valve and high limit.If it does not correct the problem, replace the thermopile.
Apr 06, 2011 | Pitco Frialator 35CS Deep Fryer
Pilot lights but ignitor still igniting and burners will not light.
check if pilot flame reaches the ignitor tip, if it does, check the connection of or replace the ignitor cable.if it does not, adjust he ignitor so that pilot flame will have good contact with the ignitor.
Mar 07, 2011 | Pitco Frialator SG14 Deep Fryer
My pilot light is out on pitco 35cs fryer, i cant locate it to relight it
Pilot assembly is located between the two middle burners, this is where the pilot is lighted. You have to turn the gas valve knob to pilot position then push it while lighting the pilot assembly.
Jan 27, 2011 | Pitco Frialator 35CS Deep Fryer
I have a SG14T-JS that has six burners. They all light and stay on for about 10 seconds and then they go out. I cleaned the spark ignitor and cleaned the gas valve connection. Do you have any ideas? ...
Hi there.
Make sure that the gas supply has the same rating and type as written on the nameplate.
Check also the gap of the spark ignitor to the pilot. Spark ignitor also acts as flame sensor for pilot flame proving, it if could not properly sense/ detect pilot flame (in case pilot flame weakens during operation due to low gas supply), it will shut the burners.
Regards.
Nov 08, 2010 | Pitco Frialator SG14 Deep Fryer
I am converting a pitco model 14c fryer from nat gas to propane, and am wondering where does the pilot oriface install at. It looks like a small cap with a hole in the end. Thanks Jim
The pilot light is attached directly to the front of the pot near one of the burners. You will see one small gas line and a set of wires. Loosen the nut where the gas line goes into the pilot light. You will have to hold the pilot light as well as turning the nut on the line. Pull the line from the pilot light assembly. Sometimes the pilot orifice comes out with the line and other times it stays stuck in the pilot light. If it is stuck take a small blade like a pocket knife and pry it out. put the new one in and tight it all back up
Oct 02, 2010 | Pitco Frialator SG14 Deep Fryer
Pitco Fryalator
This is caused by a failing pilot safty bypass inside the gas valve itself. You will need to replace the gas valve.
Aug 11, 2008 | Pitco Frialator SG14 Deep Fryer
Kitchen Appliances - Others Logo
180 people viewed this question
Top Pitco Frialator Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Paul Carew
Dan Webster
Dan Webster
Are you a Pitco Frialator Kitchen Appliances - Other Expert? Answer questions, earn points and help others
