Question about Steamist SM-46 4600
I have a E4 code in the display, whats wrong - Steamist SM-46 4600
Error code E1 and E4
PDF]SERVICE Manual - Quietside
https://www.quietside.com/archives/.../Service%20ACC1800C.pdf
When error occurs in air conditioner, error code is displayed on indoor unit .... Display priority order at overlapping error : E1?E4?E5?P0?P0?P5?P6?t1? ...
Midea air conditioner error codes
airmaster.net/midea-air-conditioner-error-codes/
Midea air conditioner error codes. Indoor unit error code explanation: R series: ... E1, Indoor / outdoor units communication protection. E2, Zero-crossing signal error ... E4, Outdoor unit temp. sensor or connector of temp. sensor is defective.
[PDF]Download the Fault Error Code Booklet - Samsung
Dec 05, 2015 | Heating & Cooling
What does E 4 on display panel mean?????
Hi Noreen,
The "e4" is an error code. You need to search online for "error code e4 + your make". You should then, at least, know what the problem is.
Aug 25, 2015 | Crock Pots & Slow Cookers
Got a logik washing machine error code e4. what the problem thanks
My washing machine in a logik and is displaying a E4 error code any now what's wrong wiv it
Jan 13, 2012 | Washing Machines
Dryer turns off after approximately 20 seconds. Error code E4
E4 Tumbler rotation failure If during a cycle the tumbler rotational speed drops to 0, all outputs will be turned off and error code E4 will be displayed.
May 17, 2011 | KitchenAid KHGV01RSS Dryer
Error code E4 is on our display of our KDW243A dishwasher - what does this mean please?
Error code E4 means there is an overflow. Water is probably trapped. If you get error code E4, just tilt the machine back about 45 degrees and let the water drain out. It should come out on both sides. Then, you should be good to go.
Dec 14, 2010 | Kenwood Dishwashers
Error code Df and e4
E4 Outdoor activation of low pressure switch/ less suction pressure.
Check back pressure, which should be 60 PSI when ambient temp 98 degree.If not Short of gas- find leak and arrest. And do gas charging. Even due to indoor coil dust blocked also e4 arise. Clean the coil and reset it.
Nov 25, 2010 | Napoleon NHPS12 Air Conditioner
I have waves split air condition its cooling is good but some time in the display e4 is coming and that time my ac is not giving cold air what is this.tell me some one.
The e4 that displays on your air condition come up simply because there is an error during the operation of the system. E4 means Error 4 which is a code that is interpreted as low pressure switch.
E4 simply means there is low pressure switch, the pressure switch turns on automatically inside the air condition, so when you turn it on sometimes the switch jams and does not open so the air condition will be on but would not get cold because the switch jammed and it displays an error signal to let you know there is a problem in the system.
Take care
Jul 09, 2010 | Heating & Cooling
Kenwood dishwasher KDW12SL3A
Sounds as though the drain is blocked partially. E4 is the overfill code. Try cleaning out the drain.
Aug 07, 2008 | Dishwashers
Canon MP 145 ink reset
If i am not mistaken error E4 is printer has NO INK. Check the cartridges first.
Jul 25, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Steamist SM-46 4600 Logo
Top Steamist Electrical Supplies Experts
ray gallant
Tom Chichester
Are you a Steamist Electrical Supply Expert? Answer questions, earn points and help others
