Question about Husqvarna Garden
Transmission oil change
How many litres do we use in an oil change for transaxle husqvarna ride one mower please?
  • Husqvarna Master
  • 2,478 Answers
What model
Posted on Apr 18, 2014
panilling9
  • 284 Answers
SOURCE: what kind of oil for a husqvarna riding mower?
Yes Briggs and Stratton recommends sae 30 in most all their engines even overhead valve (OHV)
Kohler uses 10w-30 in most of their overhead valve engines
Briggs has their own bottled oil with their label and additives and can find at lowes
Kohler the same
Posted on Jun 14, 2009
  • 302 Answers
SOURCE: change oil in riding lawn mower
look at the side of the engine down low. There should be a pipe plug screwed in that has a square head. Put a drain pan under the area and remove this plug and the oil will drain out. It's best if the engine is warm. You should get 1 1/2 quarts of oil out of it. Let it drain for about 5 minutes and then re-install the pipe plug. Add 1 1/2 quarts of 30W oil and then cut the grass !
Posted on Aug 27, 2009
Testimonial: "Thanks. It worked!"
  • 11 Answers
SOURCE: how to reset oil change indicator on my husqvarna
depends on how old the mower is, for the past 3-4 years, Husqvarna made it so that you have to replace the unit, unable to just reset it.
Posted on Sep 06, 2010
ginko
  • 19396 Answers
SOURCE: Husqvarna riding mower w/20 hp
Hi.
There is gas smell in the carburetor because the engine is not starting and carburetor is flooding.
As first thing ensure that there is spark, pull the spark plug wire and put the end near to engine block while cranking. You will see the spark. If there is no spark, check distribution coil and wires.
If there is spark, check if there is fuel pressure, if there is smell from carb, then the fuel pressure should be Ok.
Once you are sure that the pump is doing its job, and that there is pressure, check the carburetor settings. The mixture is probably too rich or too lean, and for that reason it is not igniting.
If it is not a matter of carburetor settings, then the carb must be taken apart to check carburetor filter.
To get parts and diagrams see: Outdoor Distributors - Lawn Mower Parts
Posted on Sep 26, 2010
  • 2239 Answers
SOURCE: I own a Husqvarna 54"
Depens wheather its a Tuff Torque unit or a Hydro gear unit, the Tuff Torque unit has the bypass lever on the top of the box, it will normally have a rod connected to it back through the back plate, it is usually bronze in colour, the Hydro Gear box has the bypass arm on the side next to the externall brake caliper
Posted on Jun 29, 2011
How to add and change oil in transaxle on husqvarna yth20k46
IIRC,these are sealed units,you don't need to change the oil !
Aug 15, 2014 | Husqvarna Garden
Husqvarna YTH 180 transaxle fluid
If it is not leaking there should be no need to add oil, if it does not have an external resivoir you would fill throught the filler and leave a 1/4" air gap to allow for expansion.
Aug 10, 2012 | Husqvarna Garden
Tractor moves fine when cool but after using for a while transaxle barely moves I have a Husqvarna YTH 150
This is the sign of worn internal components, as the unit heats up so the oil gets thinner and leaks internaly, this is a rebuild or new transaxle, you could try changing the oil but this does not always help, and if it does it is usualy short term.
Jul 11, 2012 | Husqvarna Garden
I have a Husqvarna 42"
You should have the Oil & filter changed per this manual:
http://www.managemylife.com/mmh/owner_manuals/10223/CRAFTSMAN-Lawn-Tractor-L0304249?
To make sure you have the correct manual go to this link and enter your model number:
I tried this model number and it did not work: 960.50002 I think you are close though.
Make sure that it is warm if you can before changing oil. One Procedure calls for removing the transaxle to change oil... It takes 80 oz of 20-50W oil. It is important to FLUSH the transaxle if you are experiencing problems. There is a product caled engine Flush that you can purchase to flush the transaxle.
Mose transaxles that experience motion problems are caused by contaminated oil. Flush.. flush... flush.., then wait for it to drain out... and then finally re-service with 20-50W oil.
Change the Filter too.. if your unit has one. All of them have the internal metal mesh screen which is why it is so important to flush out the debris.
Thanks for choosing FixYa,
Kelly
May 16, 2011 | Husqvarna Riding Lawn Mower 42 Inch Cut...
No manual for Husquvarna ride on mower model 4140H
Don't know if this helps but the owners manual for my Husq YTH2148
indicates that the transmission fluid is not to be changed, ever. If there is a problem, the whole unit is to be replaced.
These mowers, along with many craftsman rider mowers, are actually made by Roper. Perhaps if you googled around a bit you could get more info relating to service of the transaxle.
Apr 05, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Husqvarna, GTH2454T Hydrostatic power loss.
It sounds like the oil in transaxle is degraded.The transaxle is supposed to be a sealed unit requiring no service but over time the oil will get dirty enough to cause problems like you are describing.Remove the back hitch plate and look at the transaxle it will have a rubber vent hose or a 1/4 alllen wrench fitting on top. You will need to purchase a battery suction bulb from sears automotive and use it to remove as much oil from transaxle as possible. Warm the transaxle up first by running it around,then suction the oil out.Refill with a good synthetic motor oil 15w-50 or 20w-50 like Amsoil or Mobil 1.Do not use transmission fluid or hydraulic fluid. When adding the new oil back fill it to within 1.5 in from the top,be sure to allow this amount of air space in top of transaxle for expansion.
Jun 29, 2009 | Husqvarna Garden
How do I check fluid level on YTH150 Hydrostatic Transaxle?
My Husqvarna hyrdrostatic transmission is sealed, and yours may very well be also. That means no changing the fluid.
May 13, 2009 | Husqvarna Garden
Change hydrostatic transmission oil
we have tractors and, yes any of those drain bolts will work (for best results do both) then after its drained, put the drain bolts back in and top up the level
Oct 27, 2008 | Husqvarna Garden
Garden Logo
104 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
