Question about Singer 5050 Mechanical Sewing Machine
I think the timing is out on my singer 5040c..can't afford a shop 45.00 just to look at it. any service manuals available to try and fix it?
  • Paul Howell
    Paul Howell May 11, 2010
    What makes you think it's out of time? Describe the problem.
  • Singer Master
  • 1,388 Answers
It may be a tension issue going on, however if you cannot form any stitch at all, it is more likely Timing, in which case, look here for a link
Please TRY the solution BEFORE giving your considered rating.
Specific detail on bobbin case adjustment (with picture) near halfway down reply, the remainder will help you achieve a balance of top and bottom tensions.
Ensure that all is clean and free of lint and jams, this is the most likely cause....now for tension troubleshooting .......
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tesion to 4 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean
the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....
just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
i think the timing is out on my singer - 4c76dc1.jpg ...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FRONT LOADER:
....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all
back properly.
165ca5c.jpg FINISHING UP
GETTING THE BALANCE RIGHT:
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at
a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is,
and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine
case....no case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistent diameter with good thread, and less compensating to be done by your tension plates and less thread breaks
Best Wishes
Martyn
Bargain Box in Australia
Posted on Sep 17, 2009
The bobbin thread is not engaging with the top thread. I have changed the needle and cleaned the bobbin area. If the timing belt timing is not et correctly, is there a way for me to fix it or do I have...
Any sewing machine mechanic should be able to adjust the timing I would think.
There is information on adjusting timing on www.sewusa.com but I'd guess that it applies to mechanical machines.
Try this link http://www.sewusa.com/Sewing_Machine_Repair/Sewing%20Machine%20Hook%20Timing.htm and have a look at the different images, you'll need to look at the image for the rotary hook design you have (most Singers were vertical front loading).
Other possibility is to join one of the Yahoo groups for Singer owners and see if there is information available, sometimes they have files of repair info or members who share information. "Wefixit" or "Singer" is a couple of the groups but if you go to Yahoo, Groups, then type in "repair singer" there is several groups there.
Sep 19, 2011 | Singer 7422
Singer 5040c i just bought this machine it was working fine but i thought i should clean it after cleaning all of a sudden the bottom thread is looping up all over and the tension is not right. When I...
Do you have your manual? Because it is almost always the top threading, either tangled thread or a bent or dull needle causing the problem. You can download your manual at www.singerco.com for free and enlarge the detail of the diagrams for threading. I just hope that it is something simple and not your timing because that is not a do it yourself job, unfortunately. You can also call Singer customer service at 1-800-4singer. and get their advice. Good luck.
Oct 11, 2010 | Singer 5050 Mechanical Sewing Machine
I have Singer 5040c machine i was cleaning this machine it was working fine before, but machine is breaking needle all the time ,i can't sew anything, i just remove belt from bottom part cleaned it...
Your machine needs a professional to fix your timing and tune it up. You may have messed up the timing when you took off the belt. It is worth getting it fixed.
Sep 19, 2010 | Singer 5050 Mechanical Sewing Machine
I have a singer 5040c an sometimes the tensioner
You can get a users manual from the Singer Website for model 5040.
Thread the machine with the presser foot up and see if this helps.
Mar 15, 2010 | Singer 5050 Mechanical Sewing Machine
Neew schematics or repair service manual for singer 5040c or 5050
try this site:
http://www.singerco.com/support/parts_charts.html
I don't think it shows your Model by number but it says Model 9800 is the same.. This is just a parts breakdown but you might be able to fifure out how to put the nut back on, once you know exactly where it belongs.
sewman7
Apr 04, 2009 | Singer 5050 Mechanical Sewing Machine
Help with threading info for a Singer 5040c
I have the same problem. Driving me nuts. The tension dial is broken, as far as I can tell. Just craps out from time to time. Sometimes turning it on and off helps. I personally think it's a problem with the electronic controls.
Mar 04, 2009 | Singer 5050 Mechanical Sewing Machine
Singer 5050 Mechanical Sewing Machine Logo
218 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
