Cannot connect to internet
Ocean netbook
Forgot password for my ocean netbook
Hi there, my name is Lisa and I'd be happy to do my best to help.
The only thing I can think to suggest is a fresh install.
To do a fresh install (you will lose files) try tapping /holding the F11 key immediately after powering on the laptop to boot into Recovery partition on HDD to start over with a fresh Factory settings. If you are offered System Restore at any point, decline and choose System Recovery instead.
You can take a look at the following ink to see if you can find an alternate solution. I didn't read through the entire article but it looks like it might be helpful:
Review PC Login Now The Fastest Password Cracker Ever
I hope this helps.
I work on behalf of HP.
Jul 04, 2015 | HEWLETT-PACKARD Hewlett Packard HP Ocean...
Are there coaxial cables on the ocean floor connecting the US and Europe?
There are transatlantic coaxial cables under the ocean much like the fiber optic cables that connect the world to the internet. The coaxial cables were first laid down in 1956.
Dec 23, 2013 | Electronics - Others
Ocean netbook keyboard frozen
Have you rebooted the Laptop? Can you remove the battery, after unplugging, of course, and rebooting with only the AC cord plugged in? Do you think it's a hardware or software issue? Loose connection of the Keyboard? Can you plug in a USB keyboard to verify the software driver. I'm not familiar with the Laptop? I can't find anything?
Apr 16, 2013 | Computers & Internet
Hi I have just tried to set up my son's ocean netbook. I seem to have locked the keyboard somehow!! Any assistance would be greatly appreciated.
Locked as in it doesn't accept input? Some laptops will have physical buttons on them for disabling the touchpad and keyboard. Please list the make and model if you need further help.
Thanks
Jan 26, 2013 | Computers & Internet
The keyboard on my ocean netbook is frozen can any one help
go to the vendor, maybe your keyboard need a replacement. but if you willing to use your netbook, if you have any external keyboard, just plug it and use it, that will override your netbook keyboard
Jun 17, 2012 | Cell Phones
Can not connect to internet
People often get confused about how to connect their netbooks (or laptops) to the internet. It's the same for cheap netbooks or expensive netbooks - you can connect pretty much all netbooks to the internet in four ways.... And it's really easy once you get past the jargon.
1 - Wired netbook connection using your home ISP
The first way, and one I use a lot, is just plug your netbook into your router at home, using the netbook's Ethernet port and the cable supplied with your router.
This way works every time, gives a fast and secure connection, but means that you need to use your netbook within cable distance of your router. Any internet usage will be part of your normal broadband usage with your home ISP, but isn't the point of netbooks that you can be mobile with them? Who wants to have nice new netbooks tied up by a cable?
2 - Wireless netbook connection using your home ISP
Another way to get online with netbooks if you're at home is to connect wirelessly to your home router.
It's a very easy process - just turn the netbook on and it will seek out your router. You get a fast connection, good security (if you tell your router to use WPA encryption) and it will usually work anywhere in your house or garden. Several netbooks, laptops or other computers can use your internet connection this way from the same router, so your family and friends can use their netbooks at the same time.
3 - wifi netbook connection out and about
A really cheap way to get online when you're out and about is wifi. Many busy locations - pubs, hotels, shopping malls - have "wifi hotspots" which are simply powerful wireless routers that you can use to connect your netbooks wirelessly to the net.
Some are free and can be used by any computers that are nearby. Others are owned by telecomms operators like BT Openzone or mycloud and you need to pay to use them. Monthly subscriptions or pay as you go are available. So are these free and cheap choices ideal for using with cheap netboks?
For anything other than general browsing on netbooks, beware of wifi. The free ones have no security at all, and the others have password protection, but the data you send and receive is not encrypted. This means anyone in the vicinity could snoop and listen in on what you were doing. I don't bother with wifi for this reason.
See our separate feature on wifi for more about this.
4 - Your 3G netbook connection - at home or away.
netbooks.org.uk/wp-content/uploads/g3-dongle-300x164.jpg" width=240 height=131>
netbook dongle for 3G wireless internet
The final way to connect netbooks to the net - (and yes there are only four ways - I told you it was easy) is using the latest mobile phone network - 3G short for Third Generation. Just like a mobile phone, you can pay as you go or take out a monthly subscription with one of the phone companies to suit your needs. Then, using a little device like a USB stick called a USB modem, or a "dongle" plugged into your netbook, you can connect quickly and securely to the net in most of the UK and lots of places overseas. Some netbooks even have a slot to put your SIM card straight in
If you can use a mobile phone where you are, you can probably connect to the internet using 3G. Many people use 3G to connect netbooks to the net even at home and don't bother with a normal ISP.
Your pc could have a phone line input for built in modem DO NOT use that.
Use the lan inlet connector.When you connect the lan cable it should gain access at once.
Unless your connection is protected by a code.
If you have a wire less connection its probably protected with a code when you set the router up.
You have to enter the code to gain access to your network.
Here is a link that shows you how to repair the connection:
http://www.microsoft.com/windowsxp/using/networking/maintain/repair.mspx
And if you have wire less:
http://compnetworking.about.com/od/windowsxpnetworking/a/automaticwifixp.htm
Good luck.
Mar 11, 2011 | Sylvania G-Netbook
My acer aspire one wont connect to internet. it says it is connected to wireless, and i have wired it to modem but the problem still persists. please help.
Based on your description, the following is assumed.
1. The service to your Internet Service Provider is through a cable or DSL modem.
2. Internet service was initially set-up with your netbook directly connected to the modem.
3. A wireless router was since added and is using the direct wired connection to the modem.
4. The netbook is connected to the wireless access point being provided by the router.
5. The netbook says it is connected to the wireless access point but still no internet access.
The problem is likely due to the modem capturing the MAC address of the netbook when access to the internet servce was initially set up using the netbook directly connected to the modem and now the modem will only allow access with the netbook directly connected to it. You can check this out by reconnecting the netbook directly to the modem. It may be possible to "flush" the captured MAC by unplugging the AC power to the modem, waiting a few minutes and then powering back up with the router connected in place of the netbook. To make it easier, you may want connect your netbook directly to the router's LAN side to check if you now have internet access through the router. If you still don't have internet access, you will need to use your netbook to log onto the router to clone your netbook's MAC address for the router's WAN connection. The router's user guide/manual has directions on logging in and doing the MAC address clone. It will also have an explanation as to what is a MAC address.
Jan 30, 2011 | Acer Aspire One Netbook 8.9" Notebook
How to unlock helio ocean?
no..you cant unlock it at all..your just going to have to get a cricket or boost..OC phone have a locking on the web and pic java program to were fly genie is unaccessable..
Oct 14, 2008 | Helio Ocean Cellular Phone
Computers & Internet Logo
11 people viewed this question
David Payne
David Payne
