Question about Husqvarna Garden
Husqvarna 435 ignition coil gap - Husqvarna Garden
  • 376 Answers
SOURCE: We have a model 435 husqvarna 16
Yes, no problem
Posted on Jun 13, 2009
  • 13 Answers
SOURCE: ignition coil
Here you go. If the price seems high there are likely several more to be found on this page. Good luck with it.
http://cgi.ebay.com/36-136-137-41-141-142-HUSQVARNA-SAW-IGNITION-COIL_W0QQitemZ270389321883QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item3ef475a09b&_trksid=p3286.m20.l1116
Posted on Jul 16, 2009
  • 2239 Answers
SOURCE: new coil being fitted on
The air gap should be set at 0.3mm.
Regards.
Posted on Mar 10, 2011
philwalker78
  • 608 Answers
SOURCE: What is the coil gap on a Husqvarna 36 chainsaw?
Hi 8 thou is the correct gap. Regards Phil.
Posted on May 30, 2012
  • 2239 Answers
SOURCE: Husqvarna Chainsaw #41
The air gap should be set to 0.3mm, the spark plug gap should be set to 0.5mm
Posted on Jul 07, 2012
What is the gap supposed to be between the flywheel and the ignition coil on a Husqvarna YTH20K46 Ride-On mower?
Put a business card between them and push coil up against card. Tighten screws or bolts. Remove business card. This is the best way without a gauge. PS Proper name is magneto not ignition coil. FYI :-)
Jun 03, 2016 | Husqvarna Garden
Husqvarna 435 chainsaw starts easy and revs up fine. Hold it wide open and has uneven miss. Changed spark plug and cleaned carb. New saw, 1 tank of gas. Also checked seals. Any Ideas
Have you checked the timing gap between the flywheel and ignition module.? If its a NEW saw it should be covered under warranty, take it back to where you got it from and get them to fix it. Are you running it with Husqvarnas bluey green oil.?? That's the first thing your dealer will recommend you use.
Mar 29, 2016 | Husqvarna Garden
How do I adjust the air gap on the ignition coil
The best way is with an air gap tool. Most Husqvarna saws run a 0.3 mm or .012" air gap.
May 01, 2014 | Husqvarna Ignition Coil 55 257 245 51 254...
How do I adjust the air gap on aignition coil on a husqvarna 240 chainsaw
Use an air gap tool. Clean the area where the coil mounts on the engine with emory cloth to make sure you get a good ground. install the coil and lightly tighten screws (just over finger tight) slide in the air gap tool and align the coil, make sure both legs of the coil are even on the tool. Snug the screws and recheck the gap.
HUSQVARNA Chainsaw 435 no spark to plug
The 435 has a single peice electronic ignition unit bolted to the l/h side of the cylinder, if there is no spark you will have to replace the unit, the air gap should be set to 0.3mm with the new unit the part no of the unit is 573935701 check out the local dealer for a price or the web., i have had to replace quite a few units on this model, i do not think its the best unit in the world.
Mar 25, 2013 | Garden
It's about Husqvarna 345 chainsaw. I would like to know the resistance value between spark plug wire and blue wire from ignition coil, and between spark plug wire and the ground and finally resistance...
The easiest way to test is on the machine. Remove the ignition switch wire from the module coil. Check the pole gaps of the module by inserting a thin business card into the gaps after turning the flywheel magnets under the module. Loosen the module mounting screws to allow the module to contact the magnets, tighten the screws, and turn the flywheel slightly to release the card. Turn the flywheel one full turn to make sure the gaps don't close up further. Use a fresh spark plug gapped at 0.020" and try for spark. If nothing, replace the module. This gets around measuring resistances while trying to evaluate the module. Hope this helps!
Nov 21, 2010 | Husqvarna 350 18 Inch Gas Chainsaw 52CC...
Husqvarna 435 xtorq chainsaw will not start. you flip the start stop switch prime the gas and pull until its supposed to turn over and does nothing. switch it off of choke and does nothing. thought maybe...
Remove the spark plug and check for blue, snappy spark. If nothing, try a new plug--set gap at 0.020". If still nothing and machine is still under warranty, take it back to your dealer for free repair. The problem could be the ignition switch or the ignition module. Hope this helps!
Apr 14, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
HUSQVARNA model 435 Difficult starting
the problem is in the ignition coil.it needs to be replaced.it is under warranty.its warranty is life time.call husqvarna and they will either send you a new one or send you to a husqvarna dealer to fix the problem.that is at no cost to you..............let me know if this helped.................
Jun 06, 2009 | Husqvarna Forest & Garden No.967012396 345...
What are the timing specs on a Husqvarna 36-r string trimmer
there is no timing spec . the air gap is .010 to .012. or .254 mm to .305 mm.open the gap all the way up and tighten the screws.bring the flywheel magent to the coil making sure that both sides of the coil is on the magnet.slide the gapping tool in and the magent will hold it in place.once it's there release the screws holding the coil and the magents wiil pull the coil to it.once it's there retighten the screws and your done.
Mar 12, 2009 | Husqvarna Garden
Garden Logo
226 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
