Question about Minolta EP4000/5000 CS/PRO Copier
The section indicated is open - Minolta EP4000/5000 CS/PRO Copier
  • Minolta Master
  • 6,696 Answers
DO you have extra paper draws? In the back of the machine is a plug for the extra paper draws is it installed? Also check all the doors that can open do you have a finisher/ ensure plug in
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on Dec 30, 2014
The section indicated by is open
What Model sir.
Apr 17, 2014 | Minolta Office Equipment & Supplies
Ar 5618
The blinking CH means that the Developing cartridge not installed.
Here is how to correct the issue:
1)Turn OFF the power of the machine.
2)Open the front cover.
3)Install the developer unit and toner cartridge.
4)Turn ON the power of the machine with the cover opened.
5)Enter Sim25-02. (Entered value display section: "CH" is displayed. Start LED: OFF)
6)Close the front cover. (Entered value display section: "--" is displayed. Start LED: ON)
7)Press [START] key to execute Sim25-02.When [START] key is pressed, the main motor rotates for 3 minutes to determine the toner sensor reference value and clear the developer rotation time as well as to clear the developer counter.When the operation is completed normally, the ATC sensor reference value is displayed on the entered value display section. If an error occurs, one of the following indicators is lighted. LED Misfeed indicator Paper required indicator This simulation must be executed only immediately after installing developer, Do not execute this simulation for any developer which has been used. If the machine goes into the warm-up state before completion of this simulation, there is a possibility that toner may be supplied to the developer during warm-up. In such a case, therefore, the developer must be replaced with new one.
Jun 14, 2013 | Office Equipment & Supplies
Everything is freezing in the vegetable drawer
For this problem, its indicating towards problem with damper assembly.----------
The working procedure of this unit is as follows: --- The compressor starts then it cools the freezer section. When the freezer reaches its cooling level the defrost cycle starts functioning. In this cycle the fan in the freezer section starts running and the cool air in the freezer section is passed to the fridge section and the fridge section gets cold. The air from freezer to refrigerator passes from the section, in that section the damper is located. ----------- The damper is operated by a motor.Its a complete damper assembly with motor included in it.--The damper has door.Which closes and open with the help of motor.In your case the damper door is remained open, its not closing.Due to this the cool air from freezer section is running in to fridge section non-stop.Due to this the vegetables and other food in the bottom drawer freezing.--------- In this problem the damper assembly needs to be replaced.---------------
This should help.Thanks.Helpmech.
Oct 31, 2011 | Kenmore Refrigerators
In the lcd indicate close section properly, ; the sections is wher are the synchronizing roller, duplex unit transport, manual feed paper. I have cheking all sensors in this section they are oK, the ...
you might disconnect all power and reconnect to perform a power on reset. Then if the switch that detects the section is open or closed is working properly, then the circuit board that reads the switch is defective. Replace components as needed. the switch should be checked with a volt/ohm meter.
Dec 23, 2017 | Konica Minolta bizhub 250 All-In-One Laser...
I just got home earlier and when i want to watch TV i opened the TV and after 4~5mins it starts to blink and then it turns off and even if i unplug and keep on powering the TV it wont open anymore...its a...
In most cases the standby light might blink with different rapidity to indicate a fault relevant to the processor. It is possible that most of these indicate that there are errors in the processing section . Since there is a possible short or leak in the circuit the output driver section can take in huge current to trip the SMPS or from advice from the micro processor. Remove the power plugs and make sure that high voltage sections are discharged of the potential stored in capacitors. Look for visible signs of leak or of busted capacitors. Look for bulged capacitors or damaged components- burnt or busted. Use a multimeter to check the continuity or shorting in components, if so detach from circuit and test . If the voltage builds up and the set power ON and then shuts up then the suspected section must be checked in detail.
The processor must have the +5 voltage to the function properly , the +B and secondary voltages also must be checked to infer the fault. Trace with caution and in running through the signal path , circuit trail.
If tapping the top of the set brings back the picture then it can be that the main board has dry soldering.
Jul 12, 2011 | Televison & Video
The meat and veg drawers freeze the meat and veggies no matter what setting the temp. is on.
Freezing meat,vegetables. Problem with damper.
You can get required parts from online sites like: --- www.repairclinic.com or from searspartsdirect online site.
----------- This should help. Thanks.Helpmech.
Jul 08, 2011 | Kenmore 56829 Side by Side Refrigerator
The freezer section of my whirlpool double door refrigerator becomes too cool while refrigerator section does not cool lower than 56 deg F. Setting of Freezer section is at minimum cool (extreme left)...
when you open the freezer door you should hear a fan running, that's what cools your refrigerator section. If you don't hear that fan, that may be the problem. Also if there is frost on the back panel of the freezer that also may indicate a defrost problem, which could cause the same problems
Aug 22, 2010 | Refrigerators
Blinking red and green
How to connect the Bluetooth device to the computer loadTOCNode(3, 'moreinformation');
  1. Press and hold the Connect button on the bottom of the mouse. If your device has a battery indication light, it will blink and alternate between red and green to indicate that the device is discoverable.
  2. On the computer, open the Bluetooth software. The Bluetooth software is typically located in Control Panel. For more information about opening the Bluetooth software, see the "How to open the Bluetooth software" section.
  3. Click the Devices tab, and then click Add.
  4. Follow the instructions that appear on the screen.
Oct 28, 2009 | Microsoft Bluetooth 5000 Mouse
My DCR-HC30 Mini DV Camcorder keeps giving me the "cover not open" indication when the cover is actually open. What can I do to resolve problem?
There is small switch located at front circuit board that is not working properly and causing "cover not open" message.
Take off LCD cabinet section then remove front cabinet section, remove screws on circuit board and turn it to see that switch.
There can be lose connection on switch terminals or switch is not being pressed properly with lens cover lever. Please check it carefully.
Thanks.
Oct 22, 2009 | Sony Handycam DCR-HC30 Mini DV Digital...
22 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
