Question about Haier HPAC99ER Air Conditioner
Shuts off after a while i noticed water was coming out with the air do i have to drain this unit
    Problem Solver:
  • 6 Answers
The drain might be backing up. You probably do need to drain the condensate water. The unit should have a small hose at the bottom in the back where the water will gravity drain out.
Posted on Jun 19, 2009
Why is my 95% rheem furnace blinking code 2
Check condensate water /drain stopped up. It will allow a start after a reset but then it shuts the combustion air fan down and that shuts the unit down this will require a service tech make sure their familiar
with 95% units
Oct 19, 2012 | Rheem Gas Furnace 60000 Btu 95% Afue. Rgrc...
There is not any condensed water coming out the back of the unit. Is this a problem?
the amount of condensate water is related to how much humidity the unit is pullling from the cooling space.
It's possible that water is actually dripping from the unit and it is so little you're not noticing it.
However, if the unit is 'cooling' ok - I would not worry about the lack of water - unless - water starts to drip "inside" from the front of the unit - in which case you will have a problem with the drain.
You could also check the unit and make sure it has a slight tilt to the outside.
Also, you could check and see if the drain hole is clogged up - preventing water from draining.
Hope this helps.
Jun 06, 2010 | Maytag M6Y12F2A Air Conditioner
Water clogged in the outlet pipe
Hello
This is the condensate drain line which drains humid water the a/c coil collects.
To clean you can try compressed air,blow through the pipe.Or take pipe apart and flush it out.
Have the unit off when doing this,also clean the collection pan out of debri.
May 12, 2010 | LG Art Cool LA121HNP Split System Air...
My unit dripps from the tubing, front fans and back pannel
Usually there should be a drain pipe connected to the back end of the unit and long enough to remove the water from the room to a suitable drain point. You should see that this is installed. If so, then check that the existing drainage outlet is not blocked. You should also make sure that all filters are clean.
Nov 01, 2009 | Vintage Keeper Interkool 300 Air...
What is wrong when my airconditioner, starts up, after a little while water starts fo come out the louvers, then after a whileI noticed that it was leaking underneath air conditioner, and water had...
there are drain holes in the tray at the bottom of the unit that should allow the water to drain outside, see if these holes are plugged or if the unit is not mounted level.
Aug 12, 2009 | Heating & Cooling
I have a samsung 1300 btu,theres a stinky stale water damp smell comin from the air an i noticed that the air conditioner does leak that much water,where is it goin
verify that the drain coming out of the back of the unit is clear, and make sure that the unit is pitched downhill to the outside, you can safely spray some bleach water in a spray bottle on the front of the indoor coil, that will ehlp with the smell after you get the drain cleaned,( you may also have some build up on the indoor coil. I would take the unit outside and thoroughly wash it.
Jul 11, 2009 | Samsung Heating & Cooling
I have an amana ac unit that is leaking water out of a hole that is right beside the drain pipe. i cleaned the drain pan out and made sure the drain pipe was cleared out.water starts coming out when the ac...
check filter or coil plugged if drain is clean or there is no vent so the fan holds the water while running then when fan shuts off it lets it go
Jun 21, 2009 | Heating & Cooling
Water leakage from internal unit of split AC
Draim pans do get dirty and partialy block drain pan. If possible take a shop vac and gently **** out the drain line. This will pull the restriction out of the line and help clean drain pan. Rusty
Jun 05, 2009 | Heating & Cooling
GE Portable Airconditioner - Model APN10AA Serial # GG509122
Ours was leaking water. After taking the covers off,cleaning it,and draining all the water out, I started getting the same problem with the light coming on every 7 minutes. I actually added some water to the system till it was too full and then drained it out through the plug. The light still came on every 7 minutes until I turned the unit off and then unplugged it for a few minutes. I plugged it back in, turned it on and reset the temperature. It seemed to reset itself and kept running normally. BB
Aug 07, 2007 | GE APN10AA Portable Air Conditioner
Haier HPAC99ER Air Conditioner Logo
270 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Vincent Schnittert
Vincent Schnittert
Level 1 Expert
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
