Question about AlphaVision Computers & Internet
Alpha Vision AC-101 AlphaCam Plus - AlphaVision Computers & Internet
Unstable color output of monitor missing color blue and red what is the recommended software?
This sounds more like a hardware problem. If blue and red are dropping out, you likely have a poor connection. If the connectors are snug, the cable to the monitor may be bad.
May 22, 2010 | AlphaVision Alphacam PLUS Webcam
Computer does not recognize camera Emachine runing win 7
I assume you have tried to find the Win7 driver otherwise it wont work.
If not available try the Vista driver if available.
Ensure you do NOT plug it in till driver is loaded and remove previous drivers.
Dec 30, 2009 | AlphaVision Alphacam PLUS Webcam
Need to reprogram a vx 570 but don't have password, I believe it was programmed thru NorthAmerican Bancard. 1 alpha,alpha 66831 works on first entry but not for the 2nd password entry. Does anyone have a...
Try calling their support number. I had a non-standard terminal config password on an omni 3200. I called the processor's support line and they were able to give me the password.
Nov 24, 2009 | VeriFone OMNI 3200 (P092-101-10) Printer
I can't figure out the password for the settings?
If it is not - 1, Alpha, Alpha, 6, 6, 8, 3, 1 - then processor that had done a full download into the terminal had changed the password. And if you cannot get it from them, the only thing left to do with it, is to send it to VeriFone to restore the unit to factory settings.
Aug 11, 2009 | VeriFone OMNI 3200 (P092-101-10) Printer
I need to install my web cam.but my driver CD is lost.
i need to install my web cam.but my driver CD is lost
Apr 04, 2009 | AlphaVision Alphacam PLUS Webcam
How do i retrieve back-up files
for you to open the files, you have to make sure you use a system that has the softwares instlled on it i.e autocad and alpha cam and with it you won't have problem. in as much as the files are in the drive, there is no problem. and you can save a file to the backup selecting the drive in the save or saveas option. or you move/copy already saved files into the drive using explorer. good luck
Jun 04, 2008 | StompSoft BackUp My PC 2005 (05004) for PC
Computers & Internet Logo
Top AlphaVision Computers & Internet Experts
David Payne
David Payne
Are you an AlphaVision Computer and Internet Expert? Answer questions, earn points and help others
