Question about Whirlpool Washing Machines
The washer has code E1 F1
HAS CODE F1 E1 WHAT DO THAT MEAN
  • 1028 Answers
SOURCE: Trouble code F1
code usually means main control failure
Posted on Nov 27, 2008
jgwhomeequip
  • 1902 Answers
SOURCE: Whirlpool Cabrio Washer Error message code F1
Whirlpool did a recall on this problem here is there number try this first. Whirlpool 1-800-253-1301
On a number of ranges this can mean a number of things, the most common being a failed ERC(EOC, Clock assembly)or a faulty touchpad. Firstly if you are using a recent Maytag range it may pay to test the oven sensor as described above as this may cause an F1 error if faulty (may apply to some other ranges as well) this is not a common cause but is worth discounting. To check the ERC and touchpad
  1. Disconnect the power
  2. Gain access to the back of the ERC
  3. Disconnect the ribbon cable that connects the ERC to the touchpad
  4. Check nothing will short when power is reconnected
  5. reconnect the power and switch on
  6. Watch for F1 and listen for the beep
  7. If you get the F1 and the beep this means the fault is with the ERC and it will need replacing
  8. If after 30 mins you do not see the F1 error and hear the beep, replace the touchpad
Posted on Feb 14, 2009
  • 3 Answers
SOURCE: maytag bravos top load washer error code F1
Well, you're not gonna like this, but here's the deal.
Remove the three screws on the rear of the control panel and lift it up. Disconnect the rubber hose on the right side of the gray control module and blow through it to make sure it is clear and not kinked. If this check is fine then your control module needs replaced.
Note that Maytag knows this is a fairly common problem. My washer failed 9 months out of warranty with this problem.
The only good news is that it is an easy, though expensive, replacement.
Posted on Sep 25, 2009
  • 2694 Answers
SOURCE: F1 code whirlpool
whirlpool F1 code - Appliance Repair Forum THERE IS A RECALL ON YOUR WASHER,CALL THE FACTORY AND GET IT FIXED FOR FREE
Posted on Dec 13, 2009
  • 3 Answers
SOURCE: Kenmore Elite Oasis Washer Error Code F1
per sears unplug the washer for at least 10 min then plug back in and push pause or stop 2 time.
Posted on Feb 27, 2010
Haier Wine Cellar, Dual model, displays EE error code and was heavily iced on the interior back.
If the refrigerator or freezer displays error code, request a technician to check, please call the service
Different series display different error codes.
The error codes for the refrigerator: F1, F2. F3, F4, F5, F6, F7, EO, E1, E2, E6, Er, Ed, an so on
The error codes for the wine cellar: F1, F2. F3, F4, F5, H1. H2, A1, A2, E1, E2, EE, HH, LL, and so on
Notice: If you power off then power on, maybe the error code disappear, but it will display again after a few hours.
Mar 27, 2018 | Haier Refrigerators
What does E2 -F 1- mean?
It helps to know make and model in such questions.
Whirlpool Oven...what does E2 F1 mean on the clock/control panel ...
https://www.shopyourway.com/questions/1183452
Aug 27, 2012 - The "E1 F1" fault code indicates an Electronic control board malfunction. This means that the control board will need to replaced. I'm not able to provide a part number because there was not a model number submitted.I added an image of from the technical data sheet in reference to the "E1-F1" fault code. Whirlpool Gold Oven Error Code F1 E2
25 Jun 2013
Whirlpool Oven (GBS307PDQ0) Fault Code E3 (amber ...
17 Sep 2012
What does error code F1 mean on my Whirlpool ...
1 answer
14 May 2010
What does E2 F1 mean on a Kenmore electric range ...
1 answer
25 Mar 2009
More results from www.shopyourway.com
Whirlpool Oven...what does E2 F1 mean on the ... - Shop Your Way
https://www.shopyourway.com/m/questions/1183452 Aug 28, 2012 - Control panel for Whirlpool Gold double oven. 2 answers. whirlpool range, clock/oven control goes into alarm. 4 answers. Whirlpool Gold Oven Error Code F1 E2.
Whirlpool Gold Oven Error Code F1 E2 ' Shop Your Way: Online ...
https://www.shopyourway.com/m/questions/1218462 The F1 E2 error code indicates an oven control failure. Try disconnecting power to the range for 20-30 minutes, then restore the power. If this does not help, I suspect that the oven control will need to be replaced.
Whirlpool Appliance Fault Codes ' PartSelect.com
https://www.partselect.com/JustForFun/Whirlpool-Appliance-Fault-Codes.aspx Whirpool Oven/Range/Stove Fault Codes (Including 2 and 4 digit codes). Note: Depending upon the brand of appliance, there can be many different names for the 'clock' component. Electronic Range Control, ERC, Electronic Oven Control, EOC, control board, and clock all refer to the same part. 4 Digit Fault Codes. F1-E0 ...
Mar 24, 2018 | Whirlpool Ovens
What is the error mean f1 E1 on my may tag front loader washing machine
Barbara, F1 E1 error is your washer doesn't think the drain pump is working properly.bad CCU or pump.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
have E1 and F1 error code fleshing and wate Sears PartsDirect
http://forum.appliancepartspros.com/washer-repair/443358-f1-e1-error-fault-code.html
Appliance Repair Forums
Error code F1E1 null ShopYourWay
Central Control Unit CCU Maytag MHW6000XW Washer
Mar 07, 2016 | Washing Machines
What does the error code F1 E1 mean and how can i fix it
Hi.
F1 - E1 means: EEPROM Checksum error. The EEPROM is a memory chip located in the ERC (control module). The problem is communication error with the EEPROM
1. Disconnect power for at least 30 seconds.
2. Re-apply power and observe for at least one minute.
3. If code re-appears, replace control board (also called ERC or clock).
Note: Applies to all F1-Ex codes except F1-E3.
Regards.
Ginko
Aug 29, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
What does E1-F1 mean on your Kenmore
Electronic control has shorted you will need to replace. Usually most times when you see an F1 code that directly refers to the control board. If you have any further questions message me back Thanks Rick
Aug 20, 2011 | Kenmore Microwave Ovens
What does error code F1 E1 mean on a kitchenaid built in oven?
F1 - E1
EEPROM checksum error
1.
Note: Applies to all F1-E...
codes except F1-E3.
Feb 14, 2011 | KitchenAid KEMC378 Electric Double Oven
My oven is showing an F1-E1 error code. What does this mean
F1 - E1 EEPROM checksum error 1. Disconnect power for at least 30 seconds.
Note: Applies to all F1-E... codes except F1-E3.
Oct 25, 2010 | Whirlpool Accubake RF362LXTT Electric...
What does E1 - F1- mean on display?
F1-E1 - EEPROM Checksum Error - Disconnect power for at least 30 seconds and then reconnect.
Allow at least a minute after power has been restored and if error code reappears, replace control board (clock).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Aug 23, 2010 | Whirlpool GR478LXP Electric Kitchen Range
Error e1 f1
Apr 27, 2010 | Kenmore 91112 / 91114 / 91117 Electric...
Whirlpool GY396
Apr 05, 2008 | Whirlpool GY396 Electric Kitchen Range
Washing Machines Logo
78 people viewed this question
Dan Webster
Dan Webster
Sal De
