Question about Fowler Measuring Tools & Sensors
Sylvac 100. Why can't I get it out of "k" mode?
Den 1254 mod 100 is 54... it shows 50?? pls help me
It's a bit convoluted, and it only works for integers. Press MODE 4 to switch to BASE-N (integer) mode. If the screen doesn't read "Dec" then press the x^2 key. Now, to calculate a mod b, calculate a-a/b*b. No shortcuts, no rearranging. That's a minus a divided by b times b. You have to enter both numbers twice, but you will get the modulus.
For your example, you want to calculate 1254-1254/100*100 . This will give you the desired answer 54.
Press MODE 1 to return to your previously scheduled calculations.
Purely out of curiosity, what are you doing to get 50?
Nov 14, 2010 | Casio FX-115MS Plus Calculator
Please tell me how to find out the mod like 2%100
The fx-115ES does not have a modulo operator. However, it is possible to compute the remainder using integer arithmetic. Press MODE 4 to shift into integer mode. Then calculate A modulo B as
A - B * (A / B). For example, to calculate 2 modulo 100, press
2 - 1 0 0 * ( 2/ 1 0 0 ) =
and get 2.
Press MODE 1 to return to real arithmetic.
Nov 06, 2010 | Casio FX-115ES Scientific Calculator
How to resolve K123 Text on screen. Volume control takes only three modes 0-50-100.It is the problem with all the other controls too.
how to resolve K123 Text on screen. Volume control takes only three modes 0-50-100.It is the problem with all the other controls too.
Sep 18, 2010 | Sharp Televison & Video
It wont go in reverse it only goes forward, the steering works fine
Hi
The ESC on this truck comes with a reverse lock out. The reason is that when you're racing, race requirements are that no reverse can be used. Now you may have accidently turned this on. Go to the Traxxas web site and download the ESC manual and follow the instructions for reverse lock out.
May 13, 2010 | Traxxas Stampede Monster Truck Rtrw/Xl 5
G959 mod meter will not work but modulation is 100% others rfine?
If its the meter on the radio don't worry about it they do go bad but it won't effect the radio. My shops in North Florida. And no I have no web site at this time.
Apr 27, 2010 | Galaxy Radios DX-959 40-Channels Base CB...
In tv mode tv shuts off message in upper right screen 100-140
Overheat temperature failure check for fan not removing heat
May 20, 2009 | TruTech PVS31170S1W 17 in. LCD Television
Limited recording time
WS-100: 64 MB
HQ mode: Approx. 4 hours 20 minutes
SP mode: Approx. 8 hours 40 minutes
LP mode: Approx. 27 hours 20 minutes
You can go to the menu of the device and change the recording mode from HQ to SP to get longer recording time. Page 7 of the instructions explains how to change this.
Mar 19, 2009 | Olympus WS-100 Digital Voice Recorder
Dont know how to turn on hourly chime timex atlantis 100
Set chime and Alarm on or off
Press MODE to select ALARM
Press START/SPLIT to change (clock sign and chime sign will appear and disappear as you keep on pressing).
Press MODE again and you are all set.
Dec 28, 2008 | Timex Atlantis 100 77517 Wrist Watch
Sirius stiletto 100 in demo mode
All you have to do is press and hold the display button for approx 30 sec with the unit powered on. It took mine right out of demo mode.
Oct 07, 2008 | Sirius STILETTO 100 MP3 Player
Service Mode
In the center of the console on the tv below the screen there should be a push button you can get to with a paperclip or something similar, however the service mode options are not exactly self explainitory
Dec 28, 2006 | Pioneer PRO-100 TV
Measuring Tools & Sensors Logo
74 people viewed this question
Top Fowler Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Fowler Measuring Tool and Sensor Expert? Answer questions, earn points and help others
