Question about Sport & Outdoor - Others
I have a Intex 18x4 above ground pool with original pump that takes type A filter cartridges. Did not set up last year and cannot find manual. The pump is leaking around the top after putting new filter in. I know I am not remembering everything I'm supposed to do with hose connecting into pump and pool when you change filters or flush pump. Can you help me?
  • 3 more comments
  • flash_rsl Jun 19, 2009
    Pump is marked The Wet Set, # 635,Krystal Clear. Pool is UPC # 078257300570, Sand N Sun, Easy Set.
    Can you access any info with the model # I gave you that is on the filter pump? (#635)
    I didn't receive a reply to last comment. Do you think you can help me? I could not find a model# on the pool itself; only on the pump.
    The only model # is Krystal Clear #635. The pump and filter is all one unit.Is made by Intex Recreation Corp., uses Type A filters. There is no other # that I can see on the unit.Got to get to bed. Will check tomorrow to see if this helped at all. I'm sorry, I have looked everywhere on the pool and filter/pump and cannot find any other #. Thanks for your help.
    Thank you so much! This is what I was needing because I had lost my manual. You are the man, manojro! Sincerely,Gina
  • 495 Answers
For manual you can visit http://www.intexcorp.com.hk/proifv/proifv_dl_client.jsp?source=intexstore
this link. Hope it will help you.
Posted on Jun 19, 2009
    Top Expert:
  • 77,186 Answers
What is the model number, can't look the info up without that.
  • yadayada
    yadayada Jun 19, 2009
    I have no way to look up UPC codes.
  • yadayada
    sorry have no way to cross reference the pump filter to the pump, sorry, need the model number please.
How do i clean and backwash my krystal clear saltwater system model cs8110 pool. Also it is very cloudy and I cant see the bottom of my pool
Hello... Is this your first pool? If so, do you have a local pool chemical supply company? They will test a sample of your pool water with way better equipment than the test strips... Than they will tell you exactly what you need and how to apply them... This is my 4th year with this salt system and 18'x 4' intex pool... Starting them up is tricky and it still takes me weeks to get it right... But the pool store told me how to start it up for next year so hopefully it won't take as long...
The phrase backwash referes to cleaning the filter... With the intex filter/pump system, that is the filter cargtridge that inserts into the pump/filter housing... Close the pool valves, open the filter cartridge housing, take the filter out and hose it down with a garden hose... Before you return the filter, dump out the nasty water sitting in the filer/pump housing... the Return the filter, screw back on the cap, open the pool valves and open the vent screw on top of the filter cartridge housing lid... This allows the pool water to flow back into the filter/pump and removes unwanted air pockets in the hoses... Once the water flows out of the vent screw, screw it back down to stop the water coming out... Now your down backwashing the filer...
Hope this helps,
Dan
Jul 13, 2014 | Intex Automatic Salt Water System for ...
Wish to upgrade cartridge filter pump to sand filter pump. Pool size 15' X 48" / pump 1000 gph - 637R /Item no 56945 Which intex sand filter is the best one?
First, understand that sand doesn't filter as finely as cartridges, so "upgrade" may be the wrong word. Cartridges filter down to about 10 microns, sand filters to 25-30 microns. (i.e.the cartridge will catch particles up to 3X smaller than sand will.)
If you still want to change, get the biggest sand filter available that you can comfortably afford. For superior results look at above ground pump/filter packages built by Hayward or Pentair. Intex products are just built to margin and are not designed for long term usage.
Aug 31, 2013 | Intex "" Metal Frame Pool Set (56998e)...
How do i connect a salt water system to the pool
if you use a salt system in an above ground pool, the steel frame work will last less than 2 years before it rusts out
talk this over with the pool experts first and then have them help you with the system needed
Oct 25, 2017 | Intex Automatic Salt Water System for ...
My intex salt water system alarm goes off and code 90 is flashing and there is little flow. If I take out the type A filter to the pump that came with my Ultra Frame above ground pool, the flow is...
What you need to do is either clean out the filter cartridge or replace it with a new one. If you have a spray nozel for your hose you can clean the cartridge by adjusting the nozel so it is a small but strong stream. Run the stream up and down on the cartridge until all the area has been covered and then install it in the system. If you still have little flow then you should replace the filter cartridge.
I hope this helps.
Jul 05, 2011 | Intex Automatic Salt Water System for ...
Pump is not turing on? Worked fine last year
These pumps are very cheaply made and getting even one year out of them is doing good. While it will be expensive in comparison to these cheap pumps, consider installing an above ground 1/4HP pump and filter skidpack instead. You can find these online and the results are far superior and the life span is years.
Mar 27, 2010 | Intex Easy Set 1500 Gph Filter Swimming...
Lopsided 18x4 intex round easy set pool
I started out with easy set pools a few years ago and finally gave up and went to their steel supported ones.
I have put up over 20 above ground Intex pools and have learned a few things in the process:
A: The larger the pool with the air ring at the top the more difficult it is to fill to its maximum potential.
B: Eventually the pool is going to collapse with people in it, especially if someone leans over the edge with their arms on it which is a perfectly natural thing to do.
C: It is virtually impossible to get an area beneath the pool level without scraping the ground and measuring it with, in your case, at least a 16' long 2"x4" on its edge with a level on it.
D: Trying to build up the ground on one side with sand will eventually result in collapse of the pool.
E: There is a type of stiff styrofoam ring that you can buy in sections to go around the bottom of the pools, but that will also result in collapse unless it is used for what it was developed, and that is a rigid wall pool.
F: Out of the three types of pools that Intex sell, the easy up with the air ring (the worst), the steel supported all the way around (next worse). and the rigid side, only the rigid side is forgiving to a tiny degree where unlevel ground is concerned.
For your size of pool everything must be exact and completely level or at one point it will collapse. There is little more discouraging than seeing all those gallons of water run out onto the grass. Once the water goes over the edge, no amount of people can prevent the collapse.
Finally I have learned that, with above ground pools, you get exactly what you pay for. My 5th above ground Intex pool was the best, but even with the ring around the edge at the bottom and the rigid side, I was still wasting my money unless the ground was aboslutely level. You just have to cut away the dirt until the level shows no angle.
I wish you all the luck. If you feel a desire, I have 5 Intex pools in my barn I will give to you if you pay the freight. Each was a dissapointment and a waste of time, energy, and above all, money.
I finally spent about $750 on one, had a professional crew level the ground, and it stays up through the winters even.
May 25, 2009 | Intex 15' X 42" Easy Set Pool Complete...
Pool Pump - keeps getting air
It sounds like you might not be getting enough suction on your pool filter. I would check all of the hose connections for cracks, loose fittings, etc. If you are getting any extra air, it will cause your pressure to decrease.
May 22, 2009 | Intex 2500 Gallon Sand N Sun Pool...
Looking for an intex filter pump
The best solution to this problem not to find a replacement intex pump/filter. I suggest getting a system with a 50 square foot cartridge filter and a 3/4 hp pump such as hayward or pentair offers. You will be amazed at the difference a little quality can make.
Apr 07, 2009 | Intex Krystal Clear Model 635 Pool Filter...
Sport & Outdoor - Others Logo
291 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
