Question about Fuji FinePix S700 Digital Camera
Why my laptop no recognizing my SIDO card reader
My 32 GB SD card is not being Recognized for mounting, while my old 8 GB SD card works fine. How do I fix this?
The problem lies with your reader not being able to recognize sd cards over 8 gigs. A newer reader will work.
Apr 18, 2015 | RCA Digital Stream 7 inch Droid Tablet
My Asus X75A-DS51 laptop does not recognize my card reader when inserted into the usb port.
try with different card reader in the same system and old card reader in different computer
Oct 22, 2013 | ASUS X75A-DS51 17.3" LED Notebook - Intel...
How can I get the card reader to recognize sdhc cards
It's not your card reader, the SDHC mini firmware is dead that's why your reader cannot detect it. Warranty, return it to SanDisk for a new one. Every hardware you plug or attach to a PC or Laptop has what is called a firmware, a mini program that communicates with your PC and Laptop that's how they syst
Dec 30, 2012 | Gateway GT5082 PC Desktop
Sd reader does not read the card
Does it recognize any other cards? If not the reader has gone bad. You can replace it with a reader that plugs into the usb port from any computer shop for less than $20.
Mar 09, 2012 | Computers & Internet
Whenever i put the sd card my notebook dont recognize the memory card
test different cards as it can be the card itself. if your laptop card reader is not able to recognize any support card type, you may need to reinstall its driver or get a replacement for the device. Your other option is to use a USB external card reader to access the SD card. Make sure the card is not locked as well
Jan 25, 2011 | Computers & Internet
My laptop doesnt recognize fe-280 olymous
Unisntall the software that came with the camera and reinstall them. If the computer asks for drivers, insert the cd that came along the camera and install the drivers. Alternately, you can use your laptop's card reader port to transfer pictures. Just take out the memory card from the cam and put it in the card reader slot. Have any questions, write back.
Dec 21, 2009 | Olympus FE-280 Digital Camera
Compaq 6910p Notebook does not recognize a SD-MMC memory card when inserted into the slot. The memory card is fine, as I can access it using a USB card reader, but it is not recogized in the Notebook's...
If the memory card is recognized and readable in a USB card reader, the memory card is fine. If the 6910 does not recognize the memory card, either the card is not properly seated in the 6910 card reader slot, the card slot is not connected to the main board of the 6910 or you need a DIFFERENT device driver for the 6910.
Nov 25, 2009 | Compaq Hewlett Packard 6910p Notebook
Dell e1505 SD card reader issue
You installed the driver for your card reader for the laptop. If its not recognizing any cards you put in there then that means the reader is bad and since that is integrated onto the motherboard, replacing the motherboard would be the only option in order to fix that problem.
May 04, 2009 | Dell Inspiron E1505 Notebook
Acer aspire 5610z card reader
This is because your 5-in-1 doesn't support Duo Pro.
Feb 04, 2008 | Acer Aspire 5100 Notebook
Recognize SD Card
You didn't say which model of camera it is but can you connect the camera by USB and read the files that way?
Oct 21, 2007 | Computers & Internet
Fuji FinePix S700 Digital Camera Logo
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
