I have a abit v17 mobo want to get max ram (2gb) bought kingston value ram from kingston rep said it would work. also have corsair matched memory also was told by rep that it would work. I plug them in and the system keeps rebooting.
  • 157 Answers
Your motherboard supports DDR SDRam I assume the ram sticks you bought fit in the socket correctly and are the right way round?
Try the computer with each ram stick seperately. Just because ram is new doesnt mean its not defective.
What configurations do you have?
Are you using two corsair sticks or two kingston or a mix of both and what models are they?
Posted on Jun 19, 2009
Can't install kvr800d2n6/2g x 4 on aw9d max
What you have purchased is Kingston VALUE RAM. It is budget-priced RAM for generic use. It works well in most cases. I was unable to find an actual 4x3 GB "Kit" on the Kingston site, although I found 2x2 Kits. The problem here may be in matching. The specs for RAM are fairly stringent, but they have variances, and the cheaper RAM is more likely to have such variances. I would try first installing each stick separately in the primary slot and confirming that each is detected. Next place one stick in DIMM 1 and one DIMM 3 slots. This puts one stick in each channel. Each channel operates independently so matching is not an issue. If that works, try adding one stick to one channel or the other. If it fails, swap it to the other channel. The idea is to try to get the sticks matched up as best as possible. Hopefully you will find a happy match-up. Also, check the memory voltage. These sticks operate at a standard 1.8V, but having four installed could be loading down the power supply some and you may need to manually bump the voltage up a tenth or two. Don't go over 2.0V though.
Jan 29, 2012 | Abit AW9D-MAX Motherboard
Which companies ram is supported to motherboard ?
Hi yadav,
While most any DDR2 memory sticks will work on that mother board, if you want to be absolutely sure you can check at the Kingston website. You can match up the specs to be sure. Here is a link to Kingston. . http://www.kingston.com/flash/default.asp
Hope that helps
Dec 29, 2010 | Intel Motherboard, 945GC, Core 2 Duo,...
Hi I have inherited an asus m2n mxse mobo with an unknown cpu in and fan,supposedly working. I have a stick of 1 gb kingston ram (DDR2-800 KVR800D2NG) in 1 slot. The board won't start, even into bios,it...
pj, the manual specifies, See page Viii and page
1-3. for the memory supported by the M2M-MX SE MB uses: Dual-channel memory. 2x240-pin DIMM up to a max of 2GB. Non-ECC 800/667/533 MHz
All dual channel memory comes in pairs. Also see page 1-13 before installing you're memory.
SS memory should be inserted into DIMM_1.
DS memory should be inserted into DIMM__1 and DIMM_2.
Provided below is Asus updated QVL list.
http://dlsvr04.asus.com/pub/ASUS/mb/socketAM2/M2N-MX%20SE/M2N-MX_SE_QVL.pdf
If you wish to install Kingston you'll need to buy,
KVR800D2NG not KVR800D2N5 as shown in the QVL list. Ran a search through Kingston’s site. Seems the memory you bought is not supportive for Asus MBs.
Cheers'
Mike
Feb 12, 2010 | Computers & Internet
Adding RAM causes PXE-e61
Most likely you have a slow or dieing hard drive that is why when as you state you add correct ram upgrade the unit fails to boot.
skip the ram and replace your hard drive with a new ssd (solid state drive)
https://forums.lenovo.com/t5/Lenovo-P-Y-and-Z-series/PXE-E61-Media-Test-Failure-check-cable-Ideapad-z580/td-p/1318353
Feb 16, 2018 | HP Compaq Presario V2403NR Notebook
Ram
Your motherboard can take DDR or DDR2 RAM modules.
Crucial says: "Each memory slot can hold DDR PC2700,DDR PC3200,DDR2 PC2-5300 with a maximum of 1GB per slot." No sense getting 4GB since the max is 2GB.
You can get higher speed RAM (PC2-6400) because it is backward compatible.
I would go with the 2 X 1GB Corsair from the ones listed.
Or consider the options on Crucial's site. See this page:
http://www.crucial.com/store/listparts.aspx?model=P5VDC-MX
Two 1GB modules of DDR2 PC2-5300 run about $34 US.
(PS. Your 450W power supply will handle about anything.)
Jun 03, 2009 | ASUS P5VDC-MX Motherboard
2G Memory Upgrade
I had similar problem with CORSAIR XMS2 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory
If this is your RAM:
Corsair 1024MB Value Select PC2-4200 (533MHz) DDR2 RAM, 128Mx64non-ECC, 240-pin DIMM, Unbuffered, CL4, Lifetime warranty (VS1GB533D2) Then it is high density. You need low density to work, look for one ending with an 8, not 64.
Feb 26, 2009 | PC Chips P23G Motherboard
My Abit NF7-S v2.0 only works with one memory module at a time
I have read that there are dual memory controllers (duel channel) and that when you use 2GB like that you are using 1 memory controller for each stick. Maybe one of your memory controllers is bad... maybe popped a cap? Sounds like time for a new MB. See this thread...
http://www.motherboardpoint.com/t61060-nf7s2-can-it-use-highdensity-memory-chips.html
Oct 23, 2008 | Abit nForce2 NF7-S2 Motherboard
2 GB or more RAM is not functional
try maybe theres a problem in memory compatibility...dude first try to put same memory card brand and specs
Sep 01, 2008 | MSI K8N Neo4-F Motherboard
K7VT4A-Pro Mobo
Greetings,
The motherboard will read 1GB DDR400 memory per slot only.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Jun 19, 2008 | Asrock K7VT4A-Pro Motherboard
Ram memory upgrade
1 gig is the max. Get two sticks of 512mb kingston. If you go to kingston.com you will see ways on how to find the optimized RAM for your computer. If i am correct here are the specs for the ram that you need. 512MB-DDR333 PC2700, 184p DIMM, 2.5v, Sync, CL=2.5
Feb 25, 2008 | Areca ARC-1210 Serial ATA Controller
Computers & Internet Logo
60 people viewed this question
Alun Cox
David Payne
David Payne
