Question about Proview Computers & Internet
Provew LCD Monitor FV926W driver downlod - Proview Computers & Internet
Where can I find driver?
Normally I go to the manufacturer website for the device I need a driver for. They have the updated drivers and are usually tested.
Nov 23, 2011 | Computers & Internet
E151FPp (Gray) 15 in. Flat Panel LCD Monitor: I am not able to get DIplay Driver for my LCD moni...
The 32bit color has nothing to do with monitor driver, that the video card driver issue, it sounds like you do not have correct driver for you video card.
http://s807.photobucket.com/home/budm/allalbums
May 18, 2010 | Dell E151FPp 15" Flat Panel LCD Monitor
Lcd monitor hp model l1506 is not giving out put 5v/12 v . voltage at primary of xformer is ok .mosfet k2645 is ok.no switching is taking place.is ic sc6841s is defective
This monitor is made by AOC, you can downlod the service manual here: http://elektrotanya.com/?q=showresult&megnev=hp&megnev2=%20L1506%20&kategoria=&kat2=all
It can be in the protection shut down mode because it may be sensing too much load like short circuits. I test power supply by connecting a 12v 500ma lamp to the 12v output to see if the lamp will be flashing. Another test you can try is to use the hair dryer, heat up the small electrolytic cap by the opto isolator (a component with 4 pins) to see if the lamp will stay on solid.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Apr 09, 2010 | HP L1506 15" LCD Monitor
Need new drivers for Hyundai Monitor Drivers IT
Try connecting the LCD monitor to a notebook computer.
Set the notebook's video to 800-by-600 and 60 Hz,
to see if the LCD monitor will accept these settings.
Set the notebook's video to 1024-by-768 and 60 Hz,
Set the notebook's video to 1280-by-1024 and 60 Hz,
Restart your desktop computer in "Safe Mode",
after reconnecting the LCD monitor, and use the settings that work
when the LCD was connected to the notebook.
Nov 09, 2009 | Hyundai Electronics ImageQuest N91S 19"...
Darker fatter letters every 2 inches apart from top to bottom
it is called phase you can attempt to let the lcd monitor auto set or you can disconnect the power over night then plug in and then do not auto set this default usually seems best some times
Nov 29, 2008 | Proview PL926WBi 19" LCD Monitor
Streaks make letters fatter every 2 inches apart across screen
this is called phase it can be set auto by the button or you can disconnect the power and next day reconnect and leave it in default which can be better than letting the monitor try to set the phase.
LCD display Proview
If the screen is pinkish chances are the panel is defective.Should follow-up with Company Proview and do some correspondence.
Samir
May 23, 2008 | Proview PL926WBi 19" LCD Monitor
19 inch wide Tftlcd monitor FV926w comes on then goes black
There is power problem in your monitor maybe in the high voltage section. maybe there is capacitor that leaky that cannot hold the power. Need to bring this to the expert technician to fix it
Apr 15, 2008 | X2Gen MG19MY 19" LCD Monitor
Screen goes dark
it indictes problem with ur crt tube in monitir
Dec 02, 2007 | Proview PL926WBi 19" LCD Monitor
Computers & Internet Logo
42 people viewed this question
Top Proview Computers & Internet Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Diego Zenizo
Diego Zenizo
Level 1 Expert
Are you a Proview Computer and Internet Expert? Answer questions, earn points and help others
