Home | Toshiba | COPIERS - E-STUDIO 650 Copier | Starting controller ple...
Toshiba COPIERS - E-STUDIO 650 Copier
Problem for Toshiba COPIERS - E-STUDIO 650 Copier
Starting controller please wait and then nothing
By rmcniven40 on Jun 19, 2009
"starting controller please wait" and then nothing happens copies but won't print Toshiba estudio 550
I was told I need gl 1020 and some type of recovery - I'm totally lost Any help would be great thanks
Comments:
Jun 23, 2009
- Thanks for the info - how do I unattach the controller
Solution #1
posted on Jul 15, 2009
Not Rated)
joss2ktech
Rank: Master
Rating: 90%, 1 votes
hard drive for controller.
Comments:
Jul 16, 2009
- back side top left...if you have fax board you will need to take it off first, it sits on top of controller.. be carefull with a screw that sit inside the controller, remove controller cover and remove screws around ten screws give or take.
Was this helpful?
Yes
No
Solution #2
posted on Jun 23, 2009
Not Rated)
el2613
Rank: Apprentice
Rating: 0%, 0 votes
the printer controller isnt working correctly. it may be a bad controller, hdd or maybe a firmware issue. power down. disconnect controller . let it sit unattatched for 5 minutes .reattatch controller and power back up. may fix
Was this helpful?
Yes
No
Popular Solutions for Toshiba COPIERS - E-STUDIO 650
Questions and Unsolved Problems for Toshiba COPIERS - E-STUDIO 650
Do you recommend Toshiba COPIERS - E-STUDIO 650 Copier?
Answer
Answer
We have a toshiba e-studio 550-810 printer driver gl-1020. It will only print the "odd... (More)
Answer
Toshiba e-studio 550 is only displaying "Starting Controller - Please Wait" when switched... (More)
Answer
not rev over 4000rpm no engine lights on.no fault codes stored. uneven revs when sitting idle
Answer
how do i register the client for the toshiba estudio 3510c web service scanning (WS Scan) ??
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Toshiba COPIERS - E-STUDIO 650...:
Top Copier Experts
Rank: Guru Guru
Solutions: 1489
Experience: The Truth is a set of corrected errors. Erwin Schroedinger
Ask Me
Find more Copier Experts
Top Copier & Fax Repair
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
