Question about Hitachi 50VS810 50" Rear Projection HDTV
Tv will not come on.temp lite flashes.is it the lamp? wife turned off,tried to start next morning.
  • Hitachi Master
  • 1,800 Answers
Check the power supply.
and lamp aswell if the power supply is not the defected part.
Posted on Jun 19, 2009
I have a 65" mitsubishi
Did you get the lamp or the lamp and enclosure? If you had just the lamp replace, the thing to remember that it could be the wrong lamp for this set, also it could be a cheap lamp that don't work as good in this set. I would just get the lamp and housing that is made for this set. Also if lamp is good then it could be bad ballast.
Mar 07, 2011 | Televison & Video
LG RU-60SZ30 when turning the tv on the power lite changes from red to flashing amber, flashes 6 to 7 times then turns back to solid red. The tv never actually starts. Before this the tv would randomly...
I have read another solution which may indicate the light engine has failed and will likely need replacing. The cost is quite expensive. $1500 range and apparently the part is no longer available from LG. Best you might do is get an estimate to repair just to be sure.
Dec 04, 2010 | LG RU-60SZ30 60" Rear Projection...
I try to turn it on but it just blinks on stand by
Probable Lamp. If lamp hasn't bown the red Lamp Lite won't flash but other lamp issues cause stby timer light to continue flashing. If stby red lite is flashing, count the no. of times flashing - could open thermal fuse (6X flashing)
Nov 27, 2009 | Sony KDF-E42A10 42 in. LCD Television
Flashing lites
Have you tried replacing your lamp?
This may be your problem..
Delhielectronics@live.com
Sep 29, 2009 | Televison & Video
Samsung sp50L2hx no picture
You need to replace the Lamp. You have a bad lamp.
Jul 27, 2009 | Sony Grand WEGA KDF55E2000 55" Projection...
52HM95 Lamp Issue
The Tv will shut off and sho error if the ballast is bad. Replace the ballast and you should be fine.
Mar 22, 2009 | Toshiba 52HM95 52" HDTV Projection...
Sony kv-32hs500
Most probably the IC504 (Sharp PQ05RD21) on A-Board went bad. This model TV, including mine, is notorious for having this problem. The IC is rather easy to find and inexpensive (around $2.50). Your main problem will be desoldering the old one and soldering the new one.
Good Luck.
Jul 25, 2008 | Sony FD Trinitron WEGA KV-32HS500 32" TV
PT-50LC14
Hey Beestergirl, I just had my tv fixed for 385.00
Apr 21, 2008 | Panasonic PT-50LC14 50" Rear Projection...
Hot to test tthe lamp bulb Samsung tv
bad lamp will cause 90% of problems you can take it out to see if it is broken filament is usually shattered
Oct 07, 2007 | Samsung HLN617W 61" Rear Projection HDTV
Hitachi 50VS810 50" Rear Projection HDTV Logo
487 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
